guys,
not sure if this is the right forum? if not sorry!!!
i have installed a couple of emulators and within xbmc, when you go to the icon it lists them as vice64x etc. is there anywhere i can change this description to say c64 and maybe change the icon
thanks in advance
stace :d
yes you can, but not with xbmc (avalaunch is able to do it).
moving to "feature suggestions"
you can change the icon. simple place a default.tbn in the same location as the default.xbe.
as for changing the name, isn't there a win32 xbe editor of sorts?
ts
hullebulle,
are you suggesting i could do it within avalaunch for use with xbmc
don't suppose i can be cheeky enough to ask you how to do it in avalaunch?
:d :lol:
out of interest, what size should i make thumbnails and folder.jpgs if i were to create them?
thanks in advance
stace :d
Quote:you can change the icon. simple place a default.tbn in the same location as the default.xbe.
i didn't know you could do this - very interesting. is a .tbn still just a renamed jpeg file?
and more importantly (for me anyway) can you also do this to select a custom icon for shortcut (.cut) files?
and if not, regard it as a feature suggestion!
cheers,
t
