sudo apt-get update
apt-cache policy kodi
(2015-08-10, 17:18)fritsch Wrote: [ -> ]sudo apt-get update
after I run the above it says;
N: Unable to locate package kodi
I want the damn output :-) of this command.
sudo apt-add-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install kodi kodi-bin
Copy and paste everything you see in the terminal and paste it to paste.ubuntu.com after that add this link in your response.
(2015-08-10, 17:53)fritsch Wrote: [ -> ]I want the damn output :-) of this command.
sudo apt-get update
Ok, here you go. thank you for the help
http://paste.ubuntu.com/12048962/
I'm having trouble installing other stuff now to: is this the reason;
files[source.file] = open(source.file, "w")
FileNotFoundError: [Errno 2] No such file or directory: '/etc/apt/sources.list.d/team-xbmc-ppa-trusty.list'
Should I have a sources.list.d directory? I don't have one
Quote:[sudo] password for matrixebiz:
More info: https://launchpad.net/~team-xbmc/+archive/ubuntu/ppa
Press [ENTER] to continue or ctrl-c to cancel adding it
File "/usr/bin/apt-add-repository", line 163, in <module>
if not sp.add_source_from_shortcut(shortcut, options.enable_source):
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 750, in add_source_from_shortcut
self.set_modified_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 484, in set_modified_sourceslist
self.save_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 650, in save_sourceslist
self.sourceslist.save()
File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 415, in save
gpg: keyring `/tmp/tmpos2lvxre/secring.gpg' created
gpg: keyring `/tmp/tmpos2lvxre/pubring.gpg' created
gpg: requesting key 91E7EE5E from hkp server keyserver.ubuntu.com
gpg: /tmp/tmpos2lvxre/trustdb.gpg: trustdb created
gpg: key 91E7EE5E: public key "Launchpad PPA for XBMC for Linux" imported
gpg: no ultimately trusted keys found
gpg: Total number processed: 1
gpg: imported: 1 (RSA: 1)
OK
Does your provider censor https traffic?
do:
sudo echo "deb http://ppa.launchpad.net/team-xbmc/ppa/ubuntu trusty main" > /etc/apt/sources.list.d/team-xbmc-ppa-trusty.list
And then:
sudo apt-get update
If it asks about untrusted packages, tell them "yes" to install.
Thank you. It's all working now. I recreated the sources.list.d folder and was able to install it now.
I tried to do a manual compile of it yesterday which also failed but do not need all that anymore. Where can I go to delete all the stuff I do not need now?
If it's running keep it running :-) Good Luck
