Full Version: Wrong structure, but working on WIN10
Hello,
I have the following addon coded that shows me some video streams. Problem is it works fine on my PC (Windows10) and my old Raspberry PI1, but on my Raspberry PI2, it tells me "wrong structure".
The zip folder is setup as its supposed to, I have tried naming the zip with "-1.2.3", nothing works.
Can anyone figure out what is wrong with this script?
I have to say this is NOT my addon, and I haven't got a lot of coding experience, hence why I am asking for help here.
Log file here:
http://paste.osmc.io/fetehofobe
and zipfile here:
http://www.filedropper.com/
addon.xml Wrote:<?xml version="1.0" encoding="UTF-8"?>
<addon id="plugin.video.nameofaddon" version="6" name="nameofaddon" provider-name="nameofcoder">
<requires>
<import addon="xbmc.python" version="2.1.0"/>
</requires>
<extension point="xbmc.python.pluginsource" library="default.py">
<provides>video</provides>
</extension>
<extension point="xbmc.addon.metadata">
<summary lang="en">none</summary>
<summary lang="da">none</summary>
<platform>all</platform>
<language>en</language>
</extension>
</addon>
default.py Wrote:import sys, urllib2, xbmcaddon, xbmcgui, xbmcplugin, json, cookielib
class nameofaddon(object):
def listTVChannels(self):
username = settings.getSetting("username")
password = settings.getSetting("password")
cookiejar = cookielib.CookieJar()
opener = urllib2.build_opener(urllib2.HTTPCookieProcessor(cookiejar))
opener.addheaders = [('User-Agent', 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/39.0.2071.71 Safari/527.36')]
login_url = "https://login.viaplay.dk/api/login/v1?deviceKey=androidv2-dk&returnurl=https%3A%2F%2Fcontent.viaplay.dk%2Fandroidv2-dk%3Fdtg%3Dfalse&username={0}&password={1}&persistent=false".format(username, password)
opener.open(login_url)
token_url = "https://play.viaplay.dk/api/stream/byguid?deviceId=dsFdsfds&deviceName=Galaxy&deviceType=Mobile&userAgent=Viaplay%2F4.3.1%20%28Android%205.0%29&deviceKey=androidv2-dk&guid=TV3DK"
r = opener.open(token_url)
token = json.loads(r.read())['_links']['viaplay:playlist']['href'].split("m3u8")[1]
channels = {
"DR1": "http://dr01-lh.akamaihd.net/i/dr01_0@147054/master.m3u8?b=100-2000",
"DR2": "http://dr02-lh.akamaihd.net/i/dr02_0@147055/master.m3u8?b=100-2000",
"DR3": "http://dr03-lh.akamaihd.net/i/dr03_0@147056/master.m3u8?b=100-1600",
"DR ULTRA" : "http://dr06-lh.akamaihd.net/i/dr06_0@147059/master.m3u8?b=100-1600",
"RAMASJANG": "http://dr05-lh.akamaihd.net/i/dr05_0@147058/master.m3u8?b=100-1600",
"DR K" : "http://dr04-lh.akamaihd.net/i/dr04_0@147057/master.m3u8?b=100-1600"
for name, url in channels.items():
xbmcplugin.addDirectoryItem(HANDLE, url + token, xbmcgui.ListItem(name))
xbmcplugin.endOfDirectory(HANDLE, True)
if __name__ == '__main__':
HANDLE = int(sys.argv[1])
settings = xbmcaddon.Addon(id='plugin.video.nameofaddon')
a = nameofaddon()
a.listTVChannels()
you're not likely to receive any help without a Debug Log from your rPI2 and a link to the zipfile.
Alright, Log file here:
and zipfile here:
Quote:18:54:28 T:1957142528 NOTICE: CCurlFile::Stat - Content length failed: No error(0) for ftp://USERNAME:[email protected]
18:54:28 T:1957142528 ERROR: GetDirectory - Error getting zip://ftp%3a%2f%2fweb20.gigahost.dk%3a21%2fwww%2fmandesvin.dk%2fraspPI%2fplugin.video.viahack.zip/
iirc you can't install addons from a remote source, you need to copy the zipfile to the device.
(2015-08-15, 00:18)ronie Wrote: [ -> ]
I have been installing other addons from remote sources, which has worked fine.
However I put it on the PI, and now it installed so thank you. Smile
I now have a problem with the stream not working, but I guess I'll make a new thread for that:
http://forum.kodi.tv/showthread.php?tid=...id=2080351
Smile
