Full Version: \addons\skin.confluence\720p Folder location on Android
Anyone know where the \addons\skin.confluence\720p folder location on Android so I can modify the MyVideoNav.xml file? I found it on windows at C:\Program Files (x86)\Kodi\addons\skin.confluence\720p, but can't find the location on Android.
I have the same problem. I have a HiMedia Q5 IV running Android and I can't find the skin.confluence folder. All other skins I have installed are in org.xbmc.kodi/files/.kodi/addons but skin.confluence is strangely missing. Any help would be appreciated.
(2015-08-17, 16:10)BigPines Wrote: [ -> ]I have the same problem. I have a HiMedia Q5 IV running Android and I can't find the skin.confluence folder. All other skins I have installed are in org.xbmc.kodi/files/.kodi/addons but skin.confluence is strangely missing. Any help would be appreciated.
After doing a little more googling I did end up finding the location, but you will need to be rooted to traverse to the location. My G-Box Q is rooted so I was able to find and edit the MyVideoNav.xml file. The location is on the root drive:
/data/data/org.xbmc.kodi/cache/apk/assets/addons/skin.confluence/720p
I rooted my box but there is still no dir at: /data/data/org.xbmc.kodi/cache/apk/assets/addons/skin.confluence/720p. The only dir I can find is Android/data/org.xbmc.kodi/files/.kodi/addons but skin.confluence is not in there.
Do they put stuff in different places based on the different boxes? My box is running Android KitKat 4.4.2.
