(2016-10-12, 00:57)marcelveldt Wrote: [ -> ] (2016-10-11, 20:20)Leoje Wrote: [ -> ]Hi Marcel
Can you, please, create code for
Window(home).Property(SkinHelper.PVR.ClearLogo)
Window(home).Property(SkinHelper.PVR.ClearArt)
For use inside seasons and episodes addons windows.
Already there, take a look at the documentation"--> enable artwork lookups for addons
Not work for seasons and episodes containers inside addons...
Work for series container on addons.
What i miss??
BUG: The PVR - Recent Recordings widget lists the recordings in reverse in *.114 with the oldest on top. Had to downgrade to 1.0.100 to fix. Tested in Titan BETA Jarvis v3.6.89 & MIMIC.
(2016-10-12, 06:18)Leoje Wrote: [ -> ]Not work for seasons and episodes containers inside addons...
What i miss??
I will add it tomorrow, currently only supported for tvshows
You can use the workaround with the webservice as Angelinas suggested or wait for my fix
Any progress with Rottentomatoes reviews, marcel?
Sent from my XT1068
(2016-10-12, 20:28)jsnj Wrote: [ -> ]BUG: The PVR - Recent Recordings widget lists the recordings in reverse in *.114 with the oldest on top. Had to downgrade to 1.0.100 to fix. Tested in Titan BETA Jarvis v3.6.89 & MIMIC.
will be fixed in next version, I've just fixed it on git.
(2016-10-12, 21:01)VikkiXavier Wrote: [ -> ]Any progress with Rottentomatoes reviews, marcel?
No, unfortunately not. I did not yet receive any reply to my request to obtain an api key
(2016-10-12, 03:35)Guilouz Wrote: [ -> ]Yes both are fixed but there is strange things (I think it regroup in a tvshow when many episodes of a same tvshow are added in same time) with :
This is actually a feature ;-)
If you add many episodes of the same season at the same day it assumes you added a whole new season and te prevent that you're entire recent episodes widget is filled with that, it will group them into a season item. So the item you're looking at is in fact a season. The label will be set to the season name and you will also have the counts available for how many episodes.
The year isn't available at that level. I can add it but it will require another call to get the tvshow details which will probably make the listing slower.
Let me know if you want me to add the year in there.
(2016-10-12, 03:35)Guilouz Wrote: [ -> ]And this two contents not working, they show nothing (I have aired episodes today) :
plugin://script.skin.helper.service/?action=nextairedtvshows&reload=$INFO[Window(Home).Property(widgetreload2)]
plugin://script.skin.helper.service/?action=unairedepisodes&reload=$INFO[Window(Home).Property(widgetreload2)]
Keep in mind that the very first time you try to load those nextaired widgets it can take a long time because a cache has to be built for all your running shows.
This is one time only, after that it has a database. Did you try to wait a while to see if they work ? If not, please look in yoour kodi log for any errors.
(2016-10-13, 00:48)marcelveldt Wrote: [ -> ] (2016-10-12, 03:35)Guilouz Wrote: [ -> ]Yes both are fixed but there is strange things (I think it regroup in a tvshow when many episodes of a same tvshow are added in same time) with :
Is it possible to have only episodes like before ?
I think it was better before because episodes can't be play directly from widget when they are grouped and episode thumb is one of épisode inside.
And cause the non-recovery of infos :
When we are on episode infos are correct
When we are on grouping episodes, posters and cast thumbs are not displayed and play button have no effect
Yes I have wait many time and it's working before your changes last days.
This is the log :
03:14:59 T:140736076874688 NOTICE: Running database version Addons26
03:14:59 T:140736076874688 NOTICE: Running database version ViewModes6
03:14:59 T:140736076874688 NOTICE: Running database version Textures13
03:14:59 T:140736076874688 NOTICE: Running database version MyMusic60
03:14:59 T:140736076874688 NOTICE: Running database version MyVideos107
03:14:59 T:140736076874688 NOTICE: Running database version TV29
03:14:59 T:140736076874688 NOTICE: Running database version Epg11
03:14:59 T:140736076874688 NOTICE: start dvd mediatype detection
03:14:59 T:140736076874688 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
03:14:59 T:140736076874688 ERROR: JSONRPC: Unable to parse JSON Schema definition for ""
03:14:59 T:140736076874688 ERROR: JSONRPC: Invalid JSON Schema definition for method ""
03:14:59 T:140736076874688 WARNING: Trying to add unsupported control type 1
03:14:59 T:123145524162560 WARNING: Previous line repeats 50 times.
03:14:59 T:123145524162560 ERROR: GetDirectory - Error getting
03:14:59 T:140736076874688 ERROR: Previous line repeats 17 times.
03:14:59 T:140736076874688 NOTICE: UpdateLibraries: Starting video library startup scan
03:14:59 T:140736076874688 NOTICE: UpdateLibraries: Starting music library startup scan
03:14:59 T:140736076874688 NOTICE: initialize done
03:14:59 T:140736076874688 NOTICE: Running the application...
03:14:59 T:140736076874688 NOTICE: starting zeroconf publishing
03:14:59 T:140736076874688 NOTICE: starting upnp client
03:14:59 T:123145540874240 NOTICE: ES: Starting UDP Event server on port 9777
03:14:59 T:123145540874240 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
03:14:59 T:123145529069568 NOTICE: script.grab.fanart: Grab Fanart Service Started
03:15:00 T:123145530142720 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
03:15:00 T:123145529606144 NOTICE: Skin Helper Service --> skin helper service version 1.0.115 started
03:15:00 T:123145529606144 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
03:15:02 T:123145542483968 ERROR: Skin Helper Service --> ERROR Preparing ListItem --> 0
03:15:02 T:123145532289024 ERROR: Previous line repeats 60 times.
03:15:02 T:123145532289024 ERROR: GetDirectory - Error getting
03:15:02 T:123145524162560 NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 609 channels.
03:15:02 T:123145524162560 NOTICE: VideoInfoScanner: Starting scan ..
03:15:03 T:123145532289024 NOTICE: Start - EPG thread started
03:15:05 T:123145524162560 NOTICE: CleanDatabase: Starting videodatabase cleanup ..
03:15:06 T:123145534971904 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:06
03:15:07 T:123145524162560 NOTICE: CleanDatabase: Cleaning videodatabase done. Operation took 00:02
03:15:07 T:123145524162560 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:04
03:15:29 T:123145542483968 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
And I send pull request to update french language file on git
With the latest git version, there are two "Skin Helper Service" icons are added to the Video Addons and Music Addons. Is this expected? I didn't see them before. It should be just background service, shouldn't be in there.
Hi Marcel
Is there option to cache rottentomates and IMDb ratings and data when viewing library offline then only refreshing ratings when online?
Currently browsing offline shows blank ratings for all movies.
