Just try to open your Db in database/video96.db and find streamdetails like in my picture.
You will se what are I talking about,when Kodi Show resolution for movies its different then Marcel script do.
He just take info from colon "heigh" and show as propertie .Resolution.
From my colon this 11 movies never have icon,just label. Better to have HD or SD then nothing)
1: 800 (for image it will be 800.png)
2:352 (for image it will be 352.png)
3:320 (for image it will be 320.png)
Working good for number regular resolution (Movies 1,2 1080,576 - have image ; movie 3 is 800 I don't have image)
Maybe your proposition is best solution
new properties CodecDefinition #>720 HD ; #<720 SD
And keep old Resolution.....Let skiner decide what will they want to use in code for skin....
(2015-09-12, 01:16)marcelveldt Wrote: [ -> ]Will do within a few days. Basically you want me to round the resolutions to real values ?
Great work ..........big tnx again
This will be like you decide
and see what is with codec ,right now showing label AudioCodec (aac,mp3),this is ok but you need to add videocodec too.
For pvr widget ,just tested its ok,little slow but working .I put limit 500 and widget counter show number 407 ?!?
Poster,thumb working perfect,
Can't link widget with
PHP Code:
<content>plugin://script.skin.helper.service/?action=getcast&movie=$INFO[Container(510).ListItem.Title]</content>
to show textbox
PHP Code:
<label>$INFO[SkinHelper.ListItemCast]</label>
but have some free time,I will figureouthow this working.
