(2016-11-25, 01:04)Guilouz Wrote: [ -> ]I have many errors with :
plugin://script.skin.helper.widgets/?action=nextaired&mediatype=episodes&reload=$INFO[Window(Home).Property(widgetreload2)]
plugin://script.skin.helper.widgets/?action=unaired&mediatype=episodes&reload=$INFO[Window(Home).Property(widgetreload2)]
Thanks for reporting, just fixed that. New version available within 30 minutes on my repo.
(2016-11-25, 01:04)Guilouz Wrote: [ -> ]And what about of : plugin://script.skin.helper.service/?action=nextairedtvshows&reload=$INFO[Window(Home).Property(widgetreload2)] ?
Does not exist in new addon ?
No that is replaced by nextaired episodes (as it's the same)
Got this errors when closing kodi.
NOTICE: Skin Helper Service --> Shutdown requested !
DEBUG: Skin Helper Service --> ListItemMonitor - stop called
DEBUG: Skin Helper Service --> WebService - stop called
DEBUG: Skin Helper Service --> Webservice --> [24/Nov/2016 15:52:57] "QUIT / HTTP/1.1" 200 -
DEBUG: Skin Helper Simplecache --> Closed
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'setProperty'
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/service.py", line 11, in <module>
MainService()
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/main_service.py", line 70, in __init__
self.close()
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/main_service.py", line 75, in close
self.artutils.close()
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.skin.helper.artutils/lib/artutils.py", line 64, in close
self.cache.close()
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.simplecache/lib/simplecache.py", line 43, in close
self.win.setProperty("script.module.simplecache.cacheobjects",
AttributeError: 'NoneType' object has no attribute 'setProperty'
(2016-11-25, 01:56)xodiuser Wrote: [ -> ]Got this errors when closing kodi.
Thanks for reporting, will be fixed in next update.
(2016-11-25, 01:49)marcelveldt Wrote: [ -> ] (2016-11-25, 01:04)Guilouz Wrote: [ -> ]I have many errors with :
Thanks, working now but ListItem.Property(airday) return nothing. ListItem.Property(airtime) is working.
I have do mistakes with my french translation with script.skin.helper.skinbackup :
At ligne 25 must be : msgstr "Chemin par défaut de la sauv
egarde"
At line 33 must be : msgstr "Veuillez entrer un nom pour la sauv
egarde"
At line 41 must be : msgstr "Le fichier de sauv
egarde a été créé avec succès !"
I can't send you a pull request because I don’t have write access to. Submitting a change to this file.
Hi Marcel,
A small problem for the radio stream (only stream - library is ok).
Property
SkinHelper.Player.Art.XXXXXX (all Listitem Properties Music items) appear and disappear every 5s (approximately 5 seconds).
In version 1.0.120 was correctly
JB
PS. Small tests.
Maybe this will help:
set_music_properties function overrides variable
self.last_title
I added a new variable
self.last_title_stream for testing and working properly
PHP Code:
class KodiMonitor(xbmc.Monitor):
'''Monitor all events in Kodi'''
update_video_widgets_busy = False
update_music_widgets_busy = False
all_window_props = []
last_title = ""
last_title_stream = ""
PHP Code:
def monitor_radiostream(self):
for radiostreams we are not notified when the track changes
so we have to monitor that ourself
while not self.abortRequested() and xbmc.getCondVisibility("Player.HasAudio"):
#check details every 5 seconds
cur_title = xbmc.getInfoLabel("$INFO[MusicPlayer.Artist]-$INFO[MusicPlayer.Title]").decode('utf-8')
if cur_title != self.last_title_stream:
self.last_title_stream = cur_title
self.reset_win_props()
self.set_music_properties()
self.waitForAbort(5)
With skinhelper beta x.119 - x.121 the webservice for music artist clearlogo is not working with AeonNox Silvo skin. Going back to x.100 fixes it
Hi Marcel,
Where can I set a minimum resolution of downloaded images (for music artwork)?
Hi Marcel,
SkinHelper.XXXXXXX.
TrackList does not work for the music
JB
Such a big code refactoring always leads into "troubles"
Another issue:
"Jump to Letter" function is broken with the latest beta repo release. After selecting a letter the busy dialog cames up for 1-3 seconds and nothing is happen.
Quote:20:19:23.229 T:14852 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
20:19:23.231 T:14852 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Skin Helper Service('plugin://script.skin.helper.service/','21','?action=alphabetletter&letter=H')
20:19:23.231 T:6284 DEBUG: Thread LanguageInvoker start, auto delete: false
20:19:23.231 T:6284 INFO: initializing python engine.
20:19:23.231 T:6284 DEBUG: CPythonInvoker(33, D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service\plugin.py): start processing
20:19:23.250 T:6284 DEBUG: -->Python Interpreter Initialized<--
20:19:23.250 T:6284 DEBUG: CPythonInvoker(33, D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service\plugin.py): the source file to load is "D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service\plugin.py"
20:19:23.250 T:6284 DEBUG: CPythonInvoker(33, D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service\plugin.py): setting the Python path to D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.arrow\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.beautifulsoup\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.dateutil\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.musicbrainz\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.requests\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.simplecache\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.simplejson\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.six\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.skin.helper.artutils\lib;D:\Kodi\Kodi Krypton\portable_data\addons\script.module.thetvdb\lib;D:\Kodi\Kodi Krypton\system\python\DLLs;D:\Kodi\Kodi Krypton\system\python\Lib;D:\Kodi\Kodi Krypton\python27.zip;D:\Kodi\Kodi Krypton\system\python\lib\plat-win;D:\Kodi\Kodi Krypton\system\python\lib\lib-tk;D:\Kodi\Kodi Krypton;D:\Kodi\Kodi Krypton\system\python;D:\Kodi\Kodi Krypton\system\python\lib\site-packages
20:19:23.250 T:6284 DEBUG: CPythonInvoker(33, D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service\plugin.py): entering source directory D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service
20:19:23.250 T:6284 DEBUG: CPythonInvoker(33, D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service\plugin.py): instantiating addon using automatically obtained id of "script.skin.helper.service" dependent on version 2.13.0 of the xbmc.python api
20:19:23.251 T:11248 DEBUG: Thread scriptobs start, auto delete: false
20:19:23.452 T:14852 DEBUG: ------ Window Init (DialogBusy.xml) ------
20:19:23.502 T:6284 DEBUG: Skin Helper Simplecache --> Initialized
20:19:23.502 T:6284 DEBUG: Skin Helper Service --> plugin called with parameters: {u'action': u'alphabetletter', u'letter': u'h'}
20:19:25.528 T:6284 DEBUG: Skin Helper Simplecache --> Closed
20:19:25.528 T:6284 INFO: CPythonInvoker(33, D:\Kodi\Kodi Krypton\portable_data\addons\script.skin.helper.service\plugin.py): script successfully run
20:19:25.530 T:6284 INFO: Python script stopped
20:19:25.530 T:6284 DEBUG: Thread LanguageInvoker 6284 terminating
20:19:25.533 T:11248 DEBUG: Thread scriptobs 11248 terminating
20:19:25.547 T:14852 ERROR: PlayMedia could not play media: plugin://script.skin.helper.service/?action=alphabetletter&letter=H
20:19:25.547 T:14852 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
20:19:25.851 T:14852 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
20:19:26.581 T:14852 DEBUG: CWinEventsWin32::WndProcWindow is active
(2016-11-25, 10:03)JohnyBee Wrote: [ -> ]A small problem for the radio stream (only stream - library is ok).
Property SkinHelper.Player.Art.XXXXXX (all Listitem Properties Music items) appear and disappear every 5s (approximately 5 seconds).
Thanks, will be fixed in next update.
Hello you may want to have a look at this
http://forum.kodi.tv/showthread.php?tid=297885 because I was having issues with Kodi 16.1 it was having an issue where Kodi would crash with a visual runtime error when I exit Kodi however this issue no longer happens after I uninstall skin helper service all information including logs can be found there and my computer information but if you need more information or more logs I will try to help because I would like this skin helper service issue to be fixed
(2016-11-25, 04:22)Guilouz Wrote: [ -> ]Thanks, working now but ListItem.Property(airday) return nothing. ListItem.Property(airtime) is working.
OK, will be fixed in next update.
(2016-11-25, 04:22)Guilouz Wrote: [ -> ]I have do mistakes with my french translation with script.skin.helper.skinbackup :
Changed it, thanks. Available in next beta.BTW: you should be able to fork and do a PR for my new Github repos too
