Full Version: skin helper service
Hi Marcel,
I still have not no extrafanarts on items who are collection in library. I have no rotating fanart images from movies in the set when I select them.
I use $INFO[Window(Home).Property(SkinHelper.ListItem.Art.ExtraFanArt)], it's working on movies items.
See :
Image Image
And what about extrafanarts not working on episodes library and with widgets contains episodes ?
(2016-11-30, 22:09)Guilouz Wrote: [ -> ]I still have not no extrafanarts on items who are collection in library. I have no rotating fanart images from movies in the set when I select them.
ExtraFanArt
Working for Movie set in "Movies" and "MovieSet", Confirm for episodes that not working - ExtraFanArt
I have errors when I browse my library :
When I browse faster my library Skin Helper look like crash, SkinHelper.ListItem.Duration.Hours, SkinHelper.ListItem.Duration.Minutes, rotten tomatoes, metacritic etc... stop to work.
03:34:12.702 T:123145535860736 WARNING: Skin Helper Service --> Traceback (most recent call last):
                                              File "/Users/Cyril/Library/Application Support/Kodi/addons/script.skin.helper.service/resources/lib/listitem_monitor.py", line 276, in set_listitem_details
                                                listitem = extend_dict(listitem, self.artutils.get_moviesetdetails(listitem["dbid"]))
                                              File "/Users/Cyril/Library/Application Support/Kodi/addons/script.module.skin.helper.artutils/lib/artutils.py", line 154, in get_moviesetdetails
                                                self.studiologos_path)
                                              File "/Users/Cyril/Library/Application Support/Kodi/addons/script.module.skin.helper.artutils/lib/helpers/moviesetdetails.py", line 141, in get_moviesetdetails
                                                result["art"]["extrafanart"] =  efa_path
                                            NameError: global name 'result' is not defined
03:34:12.702 T:123145535860736   ERROR: Skin Helper Service --> Exception in resources.lib.listitem_monitor ! --> global name 'result' is not defined
Hi Marcel,
Just a head up on a couple of errors that have appeared this morning after updating everything from your repo:
09:11:36.849 T:13512   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.ImportError'>
                                            Error Contents: No module named thetvdb
                                              File "C:\Kodi Portable\Kodi\portable_data\addons\script.skin.helper.service\plugin.py", line 10, in <module>
                                                from resources.lib.plugin_content import PluginContent
                                              File "C:\Kodi Portable\Kodi\portable_data\addons\script.skin.helper.service\resources\lib\plugin_content.py", line 17, in <module>
                                                from artutils import KodiDb, Tmdb, get_clean_image, process_method_on_list
                                              File "C:\Kodi Portable\Kodi\portable_data\addons\script.module.skin.helper.artutils\lib\artutils.py", line 28, in <module>
                                                from thetvdb import TheTvDb
                                            ImportError: No module named thetvdb
09:11:36.863 T:12152   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.skin.helper.service/?action=nextairedtvshows&limit=25&reload=
09:11:38.479 T:1208   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
09:11:38.484 T:1972   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.skin.helper.service/?action=recommendedmovies&reload=
09:11:40.296 T:236   ERROR: XFILE::CDirectory::GetDirectory - Error getting
Mike.
Mike, You dont have instaled or enabled Modul
https://github.com/marcelveldt/script.module.thetvdb
You also use old code for widget: plugin://script.skin.helper.service/?action=recommendedmovies&reload=
Now is changed:
https://github.com/marcelveldt/script.sk.../README.md
Marcel as we speak about widget, what is right info for reload ?
1.) https://github.com/marcelveldt/script.sk.../README.md write: $INFO[Window(Home).Property(widgetreload-episodes)]
2.) https://github.com/marcelveldt/script.sk...properties write : $INFO[widgetreload-episodes)]
Thanks Angelinas. will update and correct.
Do the new paths in the wiki need & or should it be &amp;? I'm getting XML errors just lifting the example in the wiki?
(2016-12-01, 12:49)Mike_Doc Wrote: [ -> ]Thanks Angelinas. will update and correct.
I changed all of the ampersands to &amp; to make them work.
How to display MPAA rating without the words "Rated"? plz help
Is it possible to see the cast icons (just the icons/ images of actors will be enough) in the views? like showcasse view, posterlist view, etc etc ..?
Marcel one request for PVR.
I don like resultats for finding info for PVR.You set default serch engine to TMDB tvshow.
And first condition you set is "genre",mine PVR simpleIPTV player and dont have that number for genre.I have ganre as label "name"(action).
# Kodi defined movie genres
        kodi_genres = [19500, 19507, 19508, 19602, 19603, ]
All of mine movies now are TVShow Info.When I look art manual if that name of movies, have only one TV show with that name I cant change info to a movie.
-Manual Look for art just show search dialog but dont find nothing, just back to list,if is Auto lookup find as tvshow.I want to find manual to set content as movie, but I cant Sad.
In images in list is Webservice and this service give me 99% regular Art.Situation for PVR.Art is all wrong for all evants.
Can you add in settings for pvr prefer button (movies or TV show)a and change code for that.
(2016-12-01, 18:18)VikkiXavier Wrote: [ -> ]Is it possible to see the cast icons (just the icons/ images of actors will be enough) in the views? like showcasse view, posterlist view, etc etc ..?
Yes Smile
Mod AoenMQ6 Krypton
thank you Angelinas
is that screenshot from ur mod aeon mq 6?
Hi Marcel.
Similiar movies is coming up as 'Select busy spinner' in widget selection and widget label, looks like label 32006 might be incorrect?
Also still no music lisitems, i.e. tracks. Got all latest scripts and have bool set to true but no luck. Anything else to try or look into?
Edit: saw these in the log, are they connected to skin helper or something else?
17:42:30.588 T:8324 WARNING: Invalid media type "album/compilation/soundtrack"
17:42:30.607 T:6828 WARNING: Previous line repeats 3 times.
17:42:30.607 T:6828 WARNING: Invalid media type "album/soundtrack"
17:42:30.620 T:8324 WARNING: Previous line repeats 1 times.
17:42:30.620 T:8324 WARNING: Invalid media type "album/compilation"
17:42:30.622 T:6828 WARNING: Previous line repeats 1 times.
17:42:30.622 T:6828 WARNING: Invalid media type "album/compilation/dj-mix"
17:42:30.623 T:8324 WARNING: Invalid media type "album/compilation"
17:42:30.625 T:6828 WARNING: Invalid media type "album/compilation/soundtrack"
17:42:30.626 T:6828 WARNING: Invalid media type "album/compilation"
17:42:30.628 T:8324 WARNING: Previous line repeats 1 times.
17:42:30.629 T:8324 WARNING: Invalid media type "album/soundtrack"
17:42:30.637 T:8324 WARNING: Invalid media type "album/compilation/dj-mix"
17:42:30.638 T:6828 WARNING: Invalid media type "album/compilation"
Hi guys i got a lot of errors since last update......
I try Aeon Madnox and now the alphabetical search bar won´t work any more and the list has some incredible lags on scrolling!!
Any idea?
Greetz Stealth
Edit:
Can´t find any option to insert .jpg from local hdd!?!
Mike best way to find right code for widget is to enable "debug logging" in kodi, and start "open" in addon settings for "Skin helper widgets".
Almost all widget in plugin://script.skin.helper.widgets/?action=albumslisting are populated...missing for me only
action=favourite&amp;mediatype=movies
action=favourite&amp;mediatype=tvshows
action=favourite&amp;mediatype=artist
action=favourite&amp;mediatype=songs
action=recommended&amp;mediatype=songs
All working like this
plugin://script.skin.helper.widgets/?action=random&amp;mediatype=songs&amp;reload=$INFO[widgetreload-music]
