Hi Marcel,
It is a performance issue for the 'Skin Helper Service' list (artists)
and /or
'Skin Helper Service' is not running at the windows DialogAlbumInfo.xml DialogSongInfo.xml.
Short tests:
TEST 1:
- I'm on the level of Artists,
- I choose one artist - (artist does not have a set properties by 'Skin Helper Service' )
- I quickly press the button <I> - (artist does not have a set properties by 'Skin Helper Service' )
- I open a window DialogAlbumInfo.xml - (artist does not have a set properties by 'Skin Helper Service' )
- 'Skin Helper Service' does not receive properties of the artist, when I'm in the DialogAlbumInfo.xml (no matter how long) - 'Skin Helper Service' properties are 'empty'
- I go out of the window DialogAlbumInfo.xml
- I wait a moment
- 'Skin Helper Service' gets the property of the artist.
Proposal:
'Skin Helper Service' doesn't receive properties of the artist, when I'm in the DialogAlbumInfo.xml (even when nothing download before)
Request:
Could you add a feature that the windows DialogAlbumInfo.xml and DialogSongInfo.xml checks for downloaded properties for the selected item to the ListItem if the lack of this it download them.
and / or
Could you add a function (tool), which is used at skin level (additional command) read all the properties for the parameter data.
eg.
RunScript (script.skin.helper.service, action = .....................)
TEST 2:
I have a library of 400 artists. (Artist1 ... Artist400)
Simplecache.db base is filled with data.
- I'm on the level of Artists (vertical list)
- I choose Artist1
- I press the key 'down arrow' and I hold it,
- Quickly I move to the other artists.
- Stops the Artist65 and press the button <I>
- I go to the window DialogAlbumInfo.xml
- Item from KODI shows Artist65
- unfortunately 'Skin Helper Service' has collected data for Artista7 and shows them in the window DialogAlbumInfo.xml.
- 'Skin Helper Service' doesn't update data in the DialogAlbumInfo.xml.
- I wait a moment
- 'Skin Helper Service' gets the property Artist65.
Proposal:
'Skin Helper Service' can not keep up with the refresh data based on changes in the list.
'Skin Helper Service' does not refresh the property of the artist, when I'm in the DialogAlbumInfo.xml or DialogSongInfo.xml (left any previously read).
I open up listitem_monitor.py and replace line 78
old:
elif xbmc.getCondVisibility(
"System.HasModalDialog | Window.IsActive(progressdialog) | "
"Window.IsActive(busydialog) | Container.Scrolling"):
new code:
# "System.HasModalDialog | Window.IsActive(progressdialog) | "
"Window.IsActive(progressdialog) | "
... works for me correctly
If you find a little time, check it please.
