Full Version: skin helper service
(2017-03-28, 00:21)marcelveldt Wrote: [ -> ]
(2017-03-15, 14:36)wags1 Wrote: [ -> ]I haven't seen version 1.0.15 yet so guessing you are still working on it. I am still seeing this problem with current version 1.0.14. Thanks!
Why not installl my beta repo ? I don't know how often that brazil repo is updated ?
I did install your beta repo, and also checked github. 1.0.14 is the latest version I can find anywhere.
Question regarding PVR-Art:
Do I have to use
$INFO[Window(home).Property(SkinHelper.PVR.Art.Poster)]
or
$INFO[Window(home).Property(SkinHelper.Player.Art.Poster)]
when I want to show the Poster etc. for the actual playing PVR-recording?
Of course, I enabled PVRThumbs Wink
SkinHelper 1.1.11 (MV's Beta repo)
Some infolabels don't work on PVR like last episode pilot or last episode plot. maybe there are others that don't work but only tested these.
A request that I have is a Cast and Role list (vertical list) that works on pvr
(2017-03-28, 09:37)Solo0815 Wrote: [ -> ]Question regarding PVR-Art:
Do I have to use
or
You have to use listitem instead of PVR on the first one. the second is correct
Hi Marcel, there is a problem with latest Skin Helper update and Extrafanarts enabled.
When I focus a collection in my library, it kill other fanarts and they replaced by fanarts from this collection.
Before focus movieset, OK :
Image On home OK
Image On library OK
When I focus a collection, OK :
When I focus a movie, problem, it keep rotating fanarts from last collection focused :
Image Image
That happens when item have no extrafanarts.
It's working with 1.1.10 and not working with 1.1.11/12/13.
This is my variable :
<variable name="MediaFanartVar">
        <value condition="Skin.HasSetting(no_fanart)"></value>
        <value condition="Skin.HasSetting(SkinHelper.EnableExtraFanart) + !String.IsEmpty(Window(Home).Property(SkinHelper.ListItem.Art.ExtraFanArt)) + !ListItem.IsCollection">$INFO[Window(Home).Property(SkinHelper.ListItem.Art.ExtraFanArt)]</value>
        <value condition="Window.IsActive(musicinformation) | Window.IsActive(movieinformation) | Window.IsActive(addoninformation) | Window.IsActive(pvrguideinfo) | Window.IsActive(pvrrecordinginfo) | Window.IsActive(pictureinfo) | Window.IsVisible(script-script.extendedinfo-DialogVideoInfo.xml) | Window.IsVisible(script-script.extendedinfo-DialogInfo.xml) | Window.IsVisible(script-script.extendedinfo-VideoList.xml)">$INFO[Window(home).Property(infobackground)]</value>
        <value condition="Container.Content(genres) + Window.IsActive(videos)">$INFO[Skin.String(MovieGenreFanart.path)]$INFO[ListItem.Label]$INFO[Skin.String(MovieGenreFanart.ext)]</value>
        <value condition="Window.IsActive(pictures) + String.IsEmpty(ListItem.Art(fanart))">$INFO[ListItem.FolderPath]</value>
        <value condition="!String.IsEmpty(ListItem.Art(fanart))">$INFO[ListItem.Art(fanart)]</value>
        <value condition="!String.IsEmpty(Container.Art(tvshow.fanart))">$INFO[Container.Art(tvshow.fanart)]</value>
        <value condition="!String.IsEmpty(Container.Art(artist.fanart))">$INFO[Container.Art(artist.fanart)]</value>
        <value>$INFO[Container.Art(fanart)]</value>
    </variable>
(2017-03-28, 21:54)KODser Wrote: [ -> ]Some infolabels don't work on PVR like last episode pilot or last episode plot. maybe there are others that don't work but only tested these.
Do I have to use
or
I can't get $INFO[Window(home).Property(SkinHelper.Player.Art.Poster)] to work. PVRThumbs are enabled
The http-request with
http://localhost:52307/getpvrthumb&amp;title=$INFO[VideoPlayer.Title]&amp;type=poster
is working instantly after reloading the skin.
Do I have to make something different or is it just a bug? I thought you have to use the http-request only on lists?
Edit:
I get a error, if the requested movietitle has a colon in the name.
Sin City 2: A Dame to Kill for or
21:05:59.298 T:1345418144   DEBUG: Skin Helper Service --> Webservice --> [30/Mar/2017 21:05:59] "HEAD /getpvrthumb&action=getpvrthumb&type=poster&title=Sin+City+2%3A+A+Dame+to+Kill+For HTTP/1.1" 404 -
21:05:59.299 T:905966496   DEBUG: GetImageHash - unable to stat url http://localhost:52307/getpvrthumb&title=Sin City 2: A Dame to Kill For&type=poster
21:05:59.300 T:1345418144 WARNING: Skin Helper Service --> Traceback (most recent call last):
                                              File "/storage/.kodi/addons/script.skin.helper.service/resources/lib/webservice.py", line 272, in handle_request
                                                self.send_error(404, 'No image was found')
                                              File "/usr/lib/python2.7/BaseHTTPServer.py", line 365, in send_error
                                              File "/usr/lib/python2.7/BaseHTTPServer.py", line 407, in send_response
                                              File "/usr/lib/python2.7/BaseHTTPServer.py", line 412, in send_header
                                              File "/usr/lib/python2.7/socket.py", line 328, in write
                                              File "/usr/lib/python2.7/socket.py", line 307, in flush
                                            error: [Errno 32] Broken pipe
21:05:59.300 T:1345418144   ERROR: Skin Helper Service --> Exception in resources.lib.webservice ! --> [Errno 32] Broken pipe
21:05:59.301 T:1345418144   DEBUG: Skin Helper Service --> Webservice --> [30/Mar/2017 21:05:59] code 500, message Exception occurred: [Errno 32] Broken pipe
21:05:59.301 T:1345418144   DEBUG: Skin Helper Service --> Webservice --> [30/Mar/2017 21:05:59] "HEAD /getpvrthumb&action=getpvrthumb&type=poster&title=Sin+City+2%3A+A+Dame+to+Kill+For HTTP/1.1" 500 -
Skinhelper 1.1.12
Is there a way using toggle Kodi setting to change the position of auto update in dialogaddoninfo.xml button 13? I want to use a different layout but radiobutton 13 will not allow me to sendclick or change the label.
Any help would be appreciated.
Hi marcelveldt,
Could you add artist (music) rating from internet?
It would be cool to see the artist's rating for radio streams.
Thanks for the great work.
(2017-04-03, 14:00)JohnyBee Wrote: [ -> ]Could you add artist (music) rating from internet?
This Property working for Album (if script find rating for album name from http://musicbrainz.org) in Stream Radio...
try this
$INFO[Window(home).Property(SkinHelper.Player.Rating)]
Another thing, just see forced view not working for movies inside a set.
(2017-04-03, 17:28)Angelinas Wrote: [ -> ]
try this
Thanks Smile
(2017-03-15, 01:20)marcelveldt Wrote: [ -> ]
(2017-03-13, 02:40)Edworld Wrote: [ -> ]Not sure if you checked the cost of a rottentomatoes API, but read 60K USD Sad
Yes, I know. They emailed me that when I asked if we could have the reviews...
Anyway, no need to worry, the RT ratings will be back on OMDB, he's just restructuring it all a little
Are the RT ratings still WIP, ie. not working until OMDB updates. This is cool, just checking for my sanity Smile
(2017-04-07, 15:20)badaas Wrote: [ -> ]
Here is info of Omdb owner about making changes to RottenTomatoes workaround https://www.patreon.com/posts/rating-changes-8417367
60K for api Shocked
Using splitstring charstring can I separate ffffffff in to FF FF FF FF or even better 4 separate values ?
Hopefully this make sense
Sorry guys, been busy lately with some other stuff at home.
I'll take care of the various reports within the next days. Thanks for the patience.
