Full Version: skin helper service
Latest 1.1.15:
Properties for Recordings, when they are played:
e.g.
$INFO[Window(home).Property(SkinHelper.Player.Art.Poster)]
does not work, when you play a recording.
The http-request does when playing the same recording:
http://localhost:52307/getpvrthumb&title=$INFO[VideoPlayer.Title]&type=poster
And please add the ChannelLogo for Recordings actually playing, it does work for ListItems Wink
e.g.
$INFO[Window(Home).Property(SkinHelper.Player.Art.ChannelLogo)]
does not work, if you are playing a recording.
All ListItem.Art images are working for Recordings, but not when they are played Confused Can you please make the Player.Art images work for playing Recordings?
Thx
(2017-04-28, 20:26)Angelinas Wrote: [ -> ]
(2017-04-20, 12:04)badaas Wrote: [ -> ]Hi marcel, is tv next aired details suppose to be available at episodes level? As I don't see them, and also occasionally get random info not relating to current tvshow at epsiodes level, or just the status of show etc. but no other infos.
Tvshow/season level is fine.
All working
Not here, Container.Content(episodes) == no data.
(2017-05-01, 01:33)marcelveldt Wrote: [ -> ]
(2017-03-22, 20:51)Angelinas Wrote: [ -> ]Marcel ..now i have question for LastFM scraper....
I have similar artist from LastFM , but only Label in one row with postfix "/"
I dont have images from lastfm.similarartist your script.module.simplecache collect all data . but for me ...missing Art
Will be fixed in next update, see updated wiki how it looks like
Almost perfect....but missing some litle code.
Please add this and all will working % count
["lastfm.similarartists.%s.name" % count]
["lastfm.similarartists.%s.thumb" % count]
Marcel Your TMDb Api key is suspend .....this importent part of your script...
Meny string in mine skin mod have dependance of "media_type" this dont working without TMDb
status_message    "Suspended API key: Access to your account has been suspended, contact TMDb."
please check and bring back Api key for user who dont have own key Smile
(2017-05-03, 20:34)Angelinas Wrote: [ -> ]Marcel Your TMDb Api key is suspend .....this importent part of your script...
Hope this will be fix soon...
I confirm too, plots for moviesets, clearlogo for moviessets, rating from TMDB not working.
OMDB api for RottenTomates are back.....
Marcel can you add this new insted of old (who have" N/A")
I change (add new properties) omdb.py and have info.
SkinHelper.ListItem.Ratings.0.Source
SkinHelper.ListItem.Ratings.0.Value
SkinHelper.ListItem.Ratings.1.Source
SkinHelper.ListItem.Ratings.1.Value
SkinHelper.ListItem.Ratings.2.Source
SkinHelper.ListItem.Ratings.2.Value
Ratings.0.Source - "'Internet Movie Database" ##/10
Ratings.1.Source - "''Rotten Tomatoes" ##
Ratings.2.Source - "'Metacritic" ##/100
elif data.get("Ratings"):
                Ratings = []
                for count, tag in enumerate(data["Ratings"]):
                    Ratings.append(tag["Source"])
                    result["Ratings.%s.source" % count] = tag["Source"]
                    if tag.get("Value"):
                        result["Ratings.%s.value" % count] = tag["Value"].replace("%", "")
(2017-03-23, 22:31)meowmoo Wrote: [ -> ]is it just me, or is SkinHelper.ListItem.SongCount broken?
Seems to be working fine for me. You do know it's only returned at album level ?
Most likely someone hijacked my key again. Happened more often in the past.
I will contact them if I can have a new key but be aware that it could happen they shut me down.
In that case TMDB access will only be available for users with their own key
Hi marcel,
$INFO[Window(Home).Property(SkinHelper.ListItem.Plot) for artists/albums seem to be broken on info dialog with widgets, ok on library.
Same with :
- $INFO[Window(Home).Property(SkinHelper.ListItem.AlbumCount)]
- Extrafanarts (ok when focus item on widgets but not working on dialog info when press i on widgets, ok on library)
Where would I enter my own TMDB key , I got one for learning some dev's and would like to also enter it into Skinhelper
(2017-05-08, 21:36)marcelveldt Wrote: [ -> ]
hi Marcel,
meanwhile can you tell us how to use our own key ?
cheers
yes, how do we use our own key?
SkinHelper.ListItem.Budget or SkinHelper.ListItem.Budget.formatted doesnt seem to be "no longer available" too. Same thing with SkinHelper.ListItem.Revenue and SkinHelper.ListItem.Revenue.formatted. Also, SkinHelper.ListItem.Popularity stopped functioning.
Looks like will have to use the old skool REGEX on HTML webpages for getting movie infos Tongue
/justkidding Big Grin
