I wasn't have Flo Rida in mine library:
-download album "My House Album Leaked [2015]"
-put in mine music folder
*Flo Rida*
(no thumbs)
********** *My House Album Leaked [2015]*
***********(just thumb for cover "folder.jpg")
Scan library with kodi
Kodi add artist Flo Rida,(have Disc with shs-automatic write in Album folder)
Open Dialog info and have this info only with SHS and extended info script
but didnt serach with Kodi...Style,genre and mods are empty
Scan "query info for all artist" and I have all info and image
just to se how see is art adress open artwork mannual and all adress is from internet.
Now Just set to automatic artwork....and all images are saved in mine artist folder.
Sorry about images....but its better for you to understand, that all working like charm
Mine Artist folder is now full
Only stay to p l a y y y
(2017-05-31, 18:05)Angelinas Wrote: [ -> ]I wasn't have Flo Rida in mine library:
*Flo Rida*
(no thumbs)
And then you fall exactly in the case I already said it was working: shs fetching artworks from internet!
What does not work for all artists is directly using artworks already put by me in the artist folder
Even on brand new kodi and skin install. I let kodi create the library: shs will never find artworks localy stored for some artists but find them for others
Folder structure is exactly the same for all artists in my music folder...
Here is an exemple:
You can see that folder structure and file naming is exactly the same for both artist but:
-shs will always find gorillaz artworks localy stored
-shs will NEVER find flo rida artworks localy stored the same way
try to rename your simplecache.db in addon folder
c:\Users\#####\AppData\Roaming\Kodi\userdata\addon_data\script.module.simplecache\simplecache.db
in
c:\Users\#####\AppData\Roaming\Kodi\userdata\addon_data\script.module.simplecache\0simplecache.db
start kodi and shs will create new simplecache.db
open and see with sqlitebrowser your database for data
music_artwork.artist.flo rida
I open mine and all info are local
day for expires is "1498840103" hex 30.6.2017. 18:28:23 afther this time will change automatic (30 days)
roll back your file.....no need to rescan all info
(2017-05-31, 18:45)Angelinas Wrote: [ -> ]try to rename your simplecache.db in addon folder
in
Will do this as soon as possible and report back right after
Angelinas : just to be sure, which music scraper do you use?
I use theAudiodb Artist scraper
music scraper is irrelevant in this case...shs use own I think music brainz as first.This is setings for metadata and artwork module.
Gorillaz and G n' R works 100% with SHS
the Url pointing to my NAS, where all the MusicArtwork is
@ marcelveldt
I requested Trakt.tv Support a few month ago, I know your a busy Guy, but would be great if we get some basic Trakt support in the future.
in
As expected... does not work!
First try: shs does not use local artworks
Second try: shs still does not use local artworks
Both simplecach.db files show they use artworks from internet
It seems that...
Window(Home).Property(SkinHelper.ListItem.SongCount)
...doesn't work in artists level anymore.
@ Gracus and Angelinas
It is working fine for me. Kodi Leia has had some updates to the music section. Could it be a Krypton vs Leia Issue or a tagging issue with the mp3's?
(2017-06-01, 03:46)Mr. V Wrote: [ -> ]@ Gracus and Angelinas
I'm on kodi leia but as far as I remember, it was already not working when I was on kodi krypton
I only have flac files tagged with musicbrainz picard
Almost sure that this one does not come from SHS neither:
(2017-06-01, 13:47)Gracus Wrote: [ -> ]Almost sure that this one does not come from SHS neither:
Same problem for me since I have deleted my simplecache.db to create a new one.
I know the RottenTomatoes portion has been broken (any time line on it's fix?) but is MetaCritic also broken? I run Titan skin and I've noticed MetaCritic ratings no longer show even though I have it enabled in the skin.
