Full Version: skin helper service
(2019-06-08, 11:39)Angelinas Wrote: [ -> ]
(2019-06-08, 09:57)nomnom27 Wrote: [ -> ] Is there a way to make the skin helper to organize by sort tittle instead of year? Because right now it's basing its sorting perimeters by date and year instead.
Yes....but if you want to set all your sets by title you will have problem with all other sets.
https://github.com/kodi-community-addons...ils.py#L79
change in this
    movieset_movies = sorted(movieset['movies'], key=itemgetter("title"))
I don't know if I'm doing anything wrong but there's no change. It's still basing it by year and date.
Delete simplecache.db in folder "c:\Users\*\AppData\Roaming\Kodi\userdata\addon_data\script.module.simplecache\"
Your Kodi SHS show old cached info.....
(2019-06-08, 21:45)Angelinas Wrote: [ -> ]Delete simplecache.db in folder "c:\Users\*\AppData\Roaming\Kodi\userdata\addon_data\script.module.simplecache\"
Thanks for the help. It worked
However, it doesn't work for the description just like before. Is there a way to make it organized like the animation above?
Extended plot for me is all ok....see image.
You have isue with title of movie, too menu blank spaces in name.....corect this and delete again simpleecache.db.
https://en.wikipedia.org/wiki/Star_Wars
(2019-06-09, 00:02)Angelinas Wrote: [ -> ]Extended plot for me is all ok....see image.
I eliminated spaces and deleted simplecache. There's no change. Are you using kodiflix view or using another view? I used set view and it looks like your picture but there's another description instead of the list you have.
Does the list description work for you on kodiflix view? Are you using aeon mq 7 with "set" view? or are you using something else?
Hey there,
I've got a small issue with the Skin Helper Backgrounds script that I'm using alongside the Skin Helper and the Skinshortcuts script to get the option for individual backgrounds per home menu item working. I've added the option to the script.skinshortcuts.xml when adjusting home menu items via the Management Dialog (button 310). The only issue is: I'd like to see the SkinHelper.AllMoviesBackgroundRandom, SkinHelper.AllTvShowsBackgroundRandom, SkinHelper.AllMusicVideosBackground, etc. choices to pop up.
I've added the following to my overrides.xml:
<background label="smartshortcuts">||BROWSE||plugin://script.skin.helper.service/?action=backgrounds</background>
<backgroundBrowse>True</backgroundBrowse>
Therefore I get the choice between None, Single and Multiple Image just fine. But the rest doesn't show up.
What am I missing to get the library background fanart to show up for movies, TV shows and music videos?
For people having issues with skin helper backgroun and Bello 7, do this:
"After some investigation I found out, that in your 'Home.xml' the line containing 'Skin.SetString(SkinHelper.RandomFanartDelay,10)' was commented out. The creator of the script marcelveldt noted that this string ist necessary for rotating images. After removing the comment characters the backgrounds created by 'script.skin.helper.backgrounds' are available."
Source: https://forum.kodi.tv/showthread.php?tid=335209&page=3
(2016-09-27, 20:54)marcelveldt Wrote: [ -> ]
Quote:https://letterboxd.com/visdave34/list/th...s-updated/https://www.cinesift.com/#/
Looking at those sites it doesn't seem they provide an API to access their data from this script.
sure: http://api-docs.letterboxd.com/#auth
(2019-06-16, 22:46)chrissix Wrote: [ -> ]
I like this site and their layout...
Hello all,
Has anybody experienced the issue with skin helper widgets, when grouping episodes in the recently added episodes widget, that when you click on an item, the latest episodes starts playing, instead of going to the season? Is there any way to fix that? Has anybody found a viable workaround that can be used in widgets? Any help would be greatly appreciated.
Regards,
Bart
hi, how can i set multiple clearlogos in multiple containers?
i tried to use this method SkinHelper.ListItem.Art.Clearlogos in multiimage control not working.
its works only on one container with single image control what i' am doing wrong?
When using the skin Estuary Mod v2 in conjuntion with a MySQL database, I notice a fundamental bug with Skin Helper Service. After a little while the service starts a series of queries which keep repeating endlessly. This leads to enormous congestion of the local network, especially if the client is connected via Wifi. The traffic generated will use between 5 MB/s and 8 MB/s, leading to stuttering of HD video and music streaming.
I have taken great pains to deactivate all my add-ons one by one and it always came down to Skin Helper Service being the culprit. What triggers these queries I don't know, or if this only happens with Estuary Mod v2, but they look like this:
https://paste.kodi.tv/zevaxofoxi
Once these queries start, they will never stop until I terminate Kodi - which most often is not possible because of these background activities. I'm sure many users of the skin mentioned will be stumped how to get rid of stuttering, as the described behaviour is only visible in Task Manager / Resource Monitor on Windows (possibly iperf on Linux, as it also happens on LibreElec / CoreElec etc, I'm sure, when that skin is used).
I'm using TV shows Next Aired(with country.db file installed) displays TV shows airing dates depending on your region.
About two years ago, skin helper widgets also use to display the widgets(tv shows airing today)depending on your region. now it's a day ahead. anyone know of a workaround e.g add a Timeshift option.
I have requested this option on git-hub but I think skin helper has been abandoned.
Thanks in advance Smile
Hi !
I use KODI on Windows and Android devices
Before, I used to configure Mimic skin on my PC and then I made a backup of its configuration (via "Skin Helper Skin Backup Service") that I restored on other devices
But since the switch to KODI 18 (and therefore LyreBird that replaces Mimic), the backup of the PC works (See https://we.tl/t-HqxOCO1O6u) but not the import in Android : any idea ?
Kind regards
Hi, I'm trying to set up fallback ratings through skin helper in a Dialogvideoinfo.xml in case there is no local metadata.
I can see all the skinhelper Listitem properties here https://github.com/kodi-community-addons...ideo-items
Since apparently this link is not updated, I wanted to know if there are similar skinhelper Listitem properties available for:
Rating PERCENT TMDB
Critics' No. of total reviews Rotten Tomatoes
Audience Rating Rotten Tomatoes (not critics' rating)
Audience No. of Votes Rotten Tomatoes
I'm using Helper version 1.1.24.
Thanx!
