Full Version: skin helper service
(2020-05-16, 18:08)AnonTester Wrote: [ -> ]@nonJon fix added to the PR
Saw that. Much obliged!
Hi, I have a lot of problems with the entire SKIN-HELPER set
Non stop problem
If the skin helper widget works correctly, the skin heper service does not work and vice versa
Can anyone help me solve this problem
Log: https://paste.kodi.tv/yeyecepoho.kodi
Thank you.
Need a Hint!
Problem with Remote Extrafanart. Did waist hours nd couldnt get this to Work.
i've set as recomended '
<onload condition="true">Skin.SetBool(SkinHelper.EnableExtraFanart)</onload>
in Home.xml
and
$INFO[Window(Home).Property(SkinHelper.ListItem.Art.ExtraFanArt)]
in a multiimage Control.
In Theory easy. But This way i get only Extrafanart from the Local "Extrafanart-Folder".
so i've added
<onload condition="true">Skin.SetBool(SkinHelper.EnableExtendedArt)</onload>
to,
but noch change.
i've added the SkinHelper property to a Label controll, to see what it returns. And it returns only the Path to the Local Folder! (no Remote Extrafanart)
i had a look at other skins where Remote Extrafanart works, but couldnt finde out what them do differenttly(?/!)
does it have to be so hard? What do i have to do, to display Remote Extrafanart? (Kodi Leia 18.5/18.7 and Skinhelper from the beta repository)
so why? doesnt that work?
Try,
$INFO[Window(Home).Property(SkinHelper.Player.Art.ExtraFanArt)]
<variable name="YourExtaFanarVar">
     <value condition="!String.IsEmpty(Window(Home).Property(SkinHelper.Player.Art.ExtraFanArt))">$INFO[Window(Home).Property(SkinHelper.Player.Art.ExtraFanArt)]</value>
     <value condition="!String.IsEmpty(Window(Home).Property(SkinHelper.ListItem.Art.ExtraFanArt))">$INFO[Window(Home).Property(SkinHelper.ListItem.Art.ExtraFanArt)]</value>
     <value>$INFO[ListItem.Art(fanart)]</value>
</variable>
Hi
Novice looking for some help
I'm trying to get script.module.metadatautils working with Matrix
In one case I get the following error:
TypeError: 'iconImage' is an invalid keyword argument for this function
I understand that iconImage has been replaced by setArt in Kodi 19.
What I can't fathom out is how to change the line of code above to work.
Any help appreciated
(2020-06-01, 01:08)Atamans Wrote: [ -> ]Hi, I have a lot of problems with the entire SKIN-HELPER set
Non stop problem
Thank you.
Try this out that fixes the last error from your log. https://forum.kodi.tv/showthread.php?tid...pid2933557
thanks dude,
I will check it immediately
(2020-07-06, 10:50)berkhornet Wrote: [ -> ]Hi
Did you not try
listitem = xbmcgui.ListItem(label=label, label2=item["overview"])
scott s.
(2020-07-06, 16:29)scott967 Wrote: [ -> ]
Did you not try
scott s.
Many thanks for tip. Why didn’t I think of that?
That’s moved me along a bit.
Hey
I downloaded this through the add_ons section on Kodi. I love it, thanks so much! I just have one problem, but I might be being stupid. I was using it perfectly fine and it was showing under next episodes the episode after the one I had most recently watched even though I had not watched the first season on Kodi but then I cleared my library completely, cleaned it and reupdated it but it now seems like it no longer works the way before. If for example you start watching season 2 of a tv show and you finish episode 1, before it would have season 2 episode 2 under next episode now instead it tells me that the next episode is in fact season 1 episode 1. Obviously I can mark all episodes before my point as watched (and did do that in the end) but it doesnt work very well for a lot of shows, where I might dip in and out. This could also just be the way it is supposed to work but I remember pretty clearly it working the other way before. Any help would be greatly appreciated! Thanks again for this basically essential add on.
I should note also that I am using Kody Leia 19.
Thank you!
Please can anyone help with what I am sure is a simple problem. I have just upgraded to Kodi 18 and MQ8 skin but I cannot seem to export the skin settings.  I get the following message "Skin Helper Backup      Error while executing, please check Kodi.log"
The full log is here egefaqeqoj.kodi (paste)
Any help would be appreciated
(2020-09-29, 17:58)perspicacia Wrote: [ -> ]Please can anyone help with what I am sure is a simple problem. I have just upgraded to Kodi 18 and MQ8 skin but I cannot seem to export the skin settings.  I get the following message "Skin Helper Backup      Error while executing, please check Kodi.log"
You use some bad version of skin helper skinbackup 1.0.22. ?!Huh?
Use version 1.0.19 from https://github.com/kodi-community-addons that version working on mine Android.
I have some free time, and will do some maintenance in https://github.com/kodi-community-addons .
I will close all "issues" and pull request to create version with some fixes in new branch "leia".
Master branch will be ready for python 3 (base will be new leia branch,) and open for pull request.
Some of fixed part will be part of new branch:
- Usage: $INFO[Window(Home).Property(NAME-OF-PROPERTY)] for pvr and music widget don't show cache when open dialogs.
- $INFO[Window(Home).Property(SkinHelper.Player...don't show art and info for internet stream.
- alow info from theaudiodb using part without api keys (now is restricted only for patron user)
- add some new art and label in scrapers
- pvr will use all cache info and art, not just art.
(2020-10-01, 10:10)Angelinas Wrote: [ -> ]
Thanks for the advice. Unfortunately uninstalled and then installed v1. 0.19 but still have same problem
(2020-10-01, 19:29)perspicacia Wrote: [ -> ]
Hi Guys. Awesome addon, but I'm having exactly the same problem with Kodi 18.8 on Android 9 on my Air96 box - get a Skin Helper Backup error ;-(
I've tried different versions, but always get an error - cannot backup or restore.
Try the version of the PR I opened back in February with various fixes and Kodi19 compatibility. It should be compatible with both Kodi 18 and 19, but I don't use Kodi 18.
Source v1.0.25:
https://github.com/AnonTester/script.ski...skinbackup
Also in my repo:
https://github.com/AnonTester/kodi-repo/...anontester
@Angelinas if you've got some time to look at the various kodi-community addons, plese don't just close all PRs and invalidate the work put in by others, but look at them and merge where appropriate. I spent quite some time on several to get them working again, all PR'd.
