Full Version: skin helper service
https://github.com/kodi-community-addons
Is there a particular sequence to install the modules required (which?) to finally install the skin helper service?
I am sorry, but I am a little bit confused by now. Smile
Thanks anyway for your efforts! Smile Smile
Use this lnk and that order for installation
https://forum.kodi.tv/showthread.php?tid...pid3017145
(2021-02-26, 13:22)Angelinas Wrote: [ -> ]Use this lnk and that order for installation
We agree on that these are scripts/moduls for Matrix, right? (Just to be sure.)
(2021-02-26, 15:17)Ipaddle Wrote: [ -> ]We agree on that these are scripts/moduls for Matrix, right? (Just to be sure.)
Eek be sure....yes, for Matrix Kodi 19
Thanks and credits to @Angelinas!
After first installations sequence, som of the scripts and modules will not install due to missing dependencies, but second installation sequence with the first failed scripts and modules everything went fine. Now the skin helper service works. Thanks a lot!
(2021-02-26, 02:04)Maxi Wrote: [ -> ]
(2021-02-25, 06:19)djhifi Wrote: [ -> ]@Angelinas  Installed everything in your mega .zip (cherry.py I downloaded from the github since it's version 12 and zip is not) and skin helper backgrounds is throwing the following error in the log:
Quote:2021-02-25 04:15:44.036 T:6504    ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                   Error Type: <class 'NameError'>
                                                   Error Contents: name 'traceback' is not defined
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.backgrounds/resources/lib/wallimages.py", line 24, in <module>
                                                       from PIL import Image
                                                   ModuleNotFoundError: No module named 'PIL'
                                                   During handling of the above exception, another exception occurred:
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.backgrounds/service.py", line 9, in <module>
                                                       from resources.lib.backgrounds_updater import BackgroundsUpdater
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.backgrounds/resources/lib/backgrounds_updater.py", line 25, in <module>
                                                       from .wallimages import WallImages
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.backgrounds/resources/lib/wallimages.py", line 29, in <module>
                                                       log_exception(__name__, exc)
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.backgrounds/resources/lib/utils.py", line 28, in log_exception
                                                       lines = traceback.format_exception(exc_type, exc_value, exc_traceback)
                                                   NameError: name 'traceback' is not defined
Yeap, same error I reported some da back
PIL is a Python 2 module/library. It has to be replaced with PILLOW
See here: https://pillow.readthedocs.io/en/stable/about.html
And Wikipedia:
Development appears to be discontinued, with the last commit to the PIL repository coming in 2011.[2] Consequently, a successor project called Pillow has forked the PIL repository and added Python 3.x support.[4] This fork has been adopted as a replacement for the original PIL in Linux distributions including Debian[5] and Ubuntu (since 13.04).[6]
Yeah, I've read your post only after making mine Tongue
We have to wait for Angelinas to push it, it seems?
I've installed the script anyway, but disabled it, since Aeon Nox:SiLVO (the one I'm using) doesn't need this one.
(2021-01-17, 00:03)Angelinas Wrote: [ -> ]
(2021-01-16, 23:00)melons2 Wrote: [ -> ]Is there a "script.tv.show.next.aired" for Matrix?
I thought that script was still in python 2?
 Try mine version, I didnt try in tvguide, its ok for Shs part .......working for Matrix
https://mega.nz/file/DEgBwSBC#peVdf4m18p...P4i5Avs-xs
I've tested this version on Aeon Nox: SiLVO and it doesn't seem to be doing anything. It's also not giving any errors, but when I run it to populate my .db, it gives a quick popup and nothing.
And of course, skin isn't populated with the information as well.
(2021-02-28, 06:45)djhifi Wrote: [ -> ]
That is skin problem...
remove this two n xml in skin, or assq author to fix dialog for script.tv.show.next.aired
script-NextAired-TVGuide.xml
script-NextAired-TVGuide2.xml
Ahnd you have something like this:
Edit: In log :
WARNING <general>: Skin has invalid include: TVGuideItem
WARNING <general>: Skin has invalid include: TVNextAiredListCommonLayout
from github:
Remove support for TV Show Next Aired and use plugin.video.themoviedb…
https://github.com/mikesilvo164/Aeon-Nox...748ba33268
(2021-02-28, 09:39)Angelinas Wrote: [ -> ]
(2021-01-17, 00:03)Angelinas Wrote: [ -> ] Try mine version, I didnt try in tvguide, its ok for Shs part .......working for Matrix
Edit: In log :
from github:
You're awesome, always on top of things. Yes, I reported the issue in the skin too, since I thought it was indeed a skin issue. Thanks for posting a quick fix but I think the developer has changed to TMDB helper to populate the next episode airing etc.
I will keep using this one too, because I like the TV Guide.
@Angelinas I think I've found out an issue with skinhelper backup. When I run it I get:
Quote:2021-03-01 01:04:10.961 T:18903   ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.skinbackup/default.py", line 26, in __init__
                                                       BackupRestore().backuprestore()
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.skinbackup/resources/lib/backuprestore.py", line 123, in backuprestore
                                                       listitem = xbmcgui.ListItem(label=label, iconImage="DefaultFolder.png")
                                                   TypeError: 'iconImage' is an invalid keyword argument for this function
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.skinbackup/default.py", line 120, in <module>
                                                       Main()
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.skinbackup/default.py", line 34, in __init__
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.skinbackup/resources/lib/utils.py", line 31, in log_exception
(2021-03-01, 03:06)djhifi Wrote: [ -> ]@Angelinas I think I've found out an issue with skinhelper backup. When I run it I get:
                                                       Main()
That was fixed in last year...
Please use script and module from github....version is 1.0.19
Angelinas Wrote: [ -> ]For now just install from zip....in next days I will upload all needing module on Marcel repo, for "Install addon Automatically"....for Matrix
Don't want to nag too much, but has there been progress on pushing the python v3/Matrix changes of all required addons from the kodi-community-addons github repo to the Kodi addons repo to be available for automatic download for everyone?
(2021-03-01, 10:36)Chillbo Wrote: [ -> ]
Nope! In fact the KODI Matrix repo is pretty bare
I'm aware, but maybe @Angelinas has made some progress on this besides what's visible in the Kod repo.
(2021-02-21, 13:55)Angelinas Wrote: [ -> ]@Maxi
I don't have Matrix Android, I can't made test....OK, this is first test and looking good Smile
- ModuleNotFoundError: No module named 'PIL..... I was thinking that is part of Kodi....need to dig more
- NameError: name 'traceback' is not defined
In Windows worrking PIL ,I don't have that 'traceback'  error.I will add in utils.py "import traceback" in row 10.That will fix isue with log_exception.
@Angelinas
I checked the code, ad seems I was wrong... it looks like Pillow is being used. Also I saw an old Bug reporting that Pillow was missing from Matrix, and the PR that close the bug only talks about including Pillow with the Windows packages...
I am asking on the Android section of the forum if it could be that Pillow was not included when creating the APK packages
