Full Version: skin helper service
Been using Skin Helper Service Widgets for a Next Episodes widget on Kodi Matrix. It worked initially but now I'm getting errors: https://pastebin.com/AEK5uRVp.
(2021-03-04, 22:47)louisefindlay23 Wrote: [ -> ]Been using Skin Helper Service Widgets for a Next Episodes widget on Kodi Matrix. It worked initially but now I'm getting errors: https://pastebin.com/AEK5uRVp.
_database ERROR....somthing goes wrong in your simplecache.db
You need to delete databasse (or rename) to create new file in your
"C:\Users\Media\AppData\Roaming\Kodi\\userdata\addon_data\script.module.simplecache\"
I have now quickly reinstalled Kodi.
Then 1a.script.skin.helper.colorpicker-2.0.1.zip and at
1b.script.skin.helper.service-1.1.31.zip come isntallation errors
2021-03-06 10:03:15.748 T:8832     INFO <general>: -----------------------------------------------------------------------
2021-03-06 10:03:15.748 T:8832     INFO <general>: Starting Kodi (19.0 (19.0.0) Git:20210218-f44fdfbf67). Platform: Windows NT x86 64-bit
2021-03-06 10:03:15.748 T:8832     INFO <general>: Using Release Kodi x64
2021-03-06 10:03:15.748 T:8832     INFO <general>: Kodi compiled 2021-02-18 by MSVC 191627034 for Windows NT x86 64-bit version 10.0 (0x0A000007)
2021-03-06 10:03:15.748 T:8832     INFO <general>: Running on Windows 10 1909, kernel: Windows NT x86 64-bit version 10.0.18363.1379
2021-03-06 10:03:15.748 T:8832     INFO <general>: FFmpeg version/source: 4.3.1-Kodi
2021-03-06 10:03:15.748 T:8832     INFO <general>: Host CPU: Intel® Core™ i7-7700HQ CPU @ 2.80GHz, 8 cores available
2021-03-06 10:03:15.755 T:8832     INFO <general>: System has 16.0 GB of RAM installed
2021-03-06 10:03:15.756 T:8832     INFO <general>: Desktop Resolution: 1920x1080 32Bit at 60Hz
2021-03-06 10:03:15.756 T:8832     INFO <general>: Running with restricted rights
2021-03-06 10:03:15.756 T:8832     INFO <general>: Aero is enabled
2021-03-06 10:03:15.756 T:8832     INFO <general>: Display is not HDR capable or cannot be detected
2021-03-06 10:03:15.756 T:8832     INFO <general>: special://xbmc/ is mapped to: C:\Program Files\Kodi
2021-03-06 10:03:15.756 T:8832     INFO <general>: special://xbmcbin/ is mapped to: C:\Program Files\Kodi
2021-03-06 10:03:15.756 T:8832     INFO <general>: special://xbmcbinaddons/ is mapped to: C:\Program Files\Kodi/addons
2021-03-06 10:03:15.756 T:8832     INFO <general>: special://masterprofile/ is mapped to: C:\Users\Asus-NTB\AppData\Roaming\Kodi\userdata
2021-03-06 10:03:15.756 T:8832     INFO <general>: special://home/ is mapped to: C:\Users\Asus-NTB\AppData\Roaming\Kodi\
2021-03-06 10:03:15.756 T:8832     INFO <general>: special://temp/ is mapped to: C:\Users\Asus-NTB\AppData\Roaming\Kodi\cache
2021-03-06 10:03:15.756 T:8832     INFO <general>: special://logpath/ is mapped to: C:\Users\Asus-NTB\AppData\Roaming\Kodi\
2021-03-06 10:03:15.756 T:8832     INFO <general>: The executable running is: C:\Program Files\Kodi\kodi.exe
2021-03-06 10:03:15.762 T:8832     INFO <general>: Local hostname: Asus-NTB
2021-03-06 10:03:15.763 T:8832     INFO <general>: Log File is located: C:\Users\Asus-NTB\AppData\Roaming\Kodi\kodi.log
2021-03-06 10:03:15.763 T:8832     INFO <general>: -----------------------------------------------------------------------
2021-03-06 10:03:15.763 T:8832     INFO <general>: loading settings
2021-03-06 10:03:15.765 T:8832     INFO <general>: special://profile/ is mapped to: special://masterprofile/
2021-03-06 10:03:15.771 T:8832     INFO <general>: No settings file to load (special://xbmc/system/advancedsettings.xml)
2021-03-06 10:03:15.772 T:8832     INFO <general>: No settings file to load (special://masterprofile/advancedsettings.xml)
2021-03-06 10:03:15.772 T:8832     INFO <general>: Default Video Player: VideoPlayer
2021-03-06 10:03:15.772 T:8832     INFO <general>: Default Audio Player: paplayer
2021-03-06 10:03:15.772 T:8832     INFO <general>: Disabled debug logging due to GUI setting. Level 0.
2021-03-06 10:03:15.772 T:8832     INFO <general>: Log level changed to "INFO"
2021-03-06 10:03:15.773 T:8832     INFO <general>: creating subdirectories
2021-03-06 10:03:15.773 T:8832     INFO <general>: userdata folder: special://masterprofile/
2021-03-06 10:03:15.773 T:8832     INFO <general>: recording folder:
2021-03-06 10:03:15.773 T:8832     INFO <general>: screenshots folder:
2021-03-06 10:03:15.778 T:8832     INFO <general>: Running database version Addons33
2021-03-06 10:03:15.827 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: audioencoder.kodi.builtin.aac v1.0.2 installed
2021-03-06 10:03:15.827 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: audioencoder.kodi.builtin.wma v1.0.2 installed
2021-03-06 10:03:15.827 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: game.controller.default v1.0.9 installed
2021-03-06 10:03:15.827 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: game.controller.snes v1.0.9 installed
2021-03-06 10:03:15.828 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.global.audioengine v1.1.1 installed
2021-03-06 10:03:15.828 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.global.filesystem v1.1.6 installed
2021-03-06 10:03:15.828 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.global.general v1.0.5 installed
2021-03-06 10:03:15.828 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.global.gui v5.15.0 installed
2021-03-06 10:03:15.828 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.global.main v1.3.0 installed
2021-03-06 10:03:15.828 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.global.network v1.0.4 installed
2021-03-06 10:03:15.828 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.global.tools v1.0.4 installed
2021-03-06 10:03:15.828 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.audiodecoder v3.0.0 installed
2021-03-06 10:03:15.829 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.audioencoder v2.1.0 installed
2021-03-06 10:03:15.829 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.game v2.1.0 installed
2021-03-06 10:03:15.829 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.imagedecoder v2.1.1 installed
2021-03-06 10:03:15.829 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.inputstream v3.0.1 installed
2021-03-06 10:03:15.829 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.peripheral v2.0.0 installed
2021-03-06 10:03:15.829 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.pvr v7.1.0 installed
2021-03-06 10:03:15.829 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.screensaver v2.1.0 installed
2021-03-06 10:03:15.829 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.vfs v3.0.0 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.videocodec v2.0.2 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.binary.instance.visualization v3.0.0 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: kodi.resource v1.0.0 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.album.universal v3.1.4 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.artists.universal v4.3.3 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.common.allmusic.com v3.2.2 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.common.fanart.tv v3.6.3 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.common.imdb.com v3.1.6 installed
2021-03-06 10:03:15.830 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.common.musicbrainz.org v2.2.4 installed
2021-03-06 10:03:15.831 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.common.theaudiodb.com v2.0.3 installed
2021-03-06 10:03:15.831 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.common.themoviedb.org v3.2.13 installed
2021-03-06 10:03:15.831 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.generic.albums v1.0.14 installed
2021-03-06 10:03:15.831 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.generic.artists v1.0.14 installed
2021-03-06 10:03:15.831 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.local v1.0.1 installed
2021-03-06 10:03:15.831 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.themoviedb.org v5.2.6 installed
2021-03-06 10:03:15.831 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.themoviedb.org.python v1.3.1+matrix.1 installed
2021-03-06 10:03:15.832 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org v3.5.13 installed
2021-03-06 10:03:15.832 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org.python v1.4.0 installed
2021-03-06 10:03:15.832 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: peripheral.joystick v1.7.1 installed
2021-03-06 10:03:15.832 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: repository.xbmc.org v3.2.5 installed
2021-03-06 10:03:15.832 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: resource.images.weathericons.default v1.1.9 installed
2021-03-06 10:03:15.832 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: resource.language.en_gb v2.0.2 installed
2021-03-06 10:03:15.832 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: resource.uisounds.kodi v1.0.1 installed
2021-03-06 10:03:15.832 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: screensaver.xbmc.builtin.black v1.0.34 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: screensaver.xbmc.builtin.dim v1.0.64 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: script.module.pil v5.1.0 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: script.module.pycryptodome v3.4.3 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: service.xbmc.versioncheck v0.5.14+matrix.1 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: skin.estouchy v3.0.6 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: skin.estuary v3.0.5 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: webinterface.default v19.x-2.4.7 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: xbmc.addon v19.0.0 installed
2021-03-06 10:03:15.833 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: xbmc.core v0.1.0 installed
2021-03-06 10:03:15.834 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: xbmc.gui v5.15.0 installed
2021-03-06 10:03:15.834 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: xbmc.json v12.2.1 installed
2021-03-06 10:03:15.834 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: xbmc.metadata v2.1.0 installed
2021-03-06 10:03:15.834 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: xbmc.python v3.0.0 installed
2021-03-06 10:03:15.834 T:8832     INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddons: xbmc.webinterface v1.0.0 installed
2021-03-06 10:03:15.839 T:8832     INFO <general>: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
2021-03-06 10:03:15.850 T:2524     INFO <general>: Loading special://xbmc/system/IRSSmap.xml
2021-03-06 10:03:15.850 T:2524     INFO <general>: * Adding remote mapping for device 'Microsoft MCE'
2021-03-06 10:03:15.850 T:2524     INFO <general>: * Adding remote mapping for device 'Abstract'
2021-03-06 10:03:15.851 T:8832     INFO <general>: Primary mode: Generic PnP Monitor #1: 1920x1080 @ 60.00Hz
2021-03-06 10:03:15.851 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 320x200 @ 60.00Hz
2021-03-06 10:03:15.852 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 320x240 @ 60.00Hz
2021-03-06 10:03:15.852 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 400x300 @ 60.00Hz
2021-03-06 10:03:15.852 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 512x384 @ 60.00Hz
2021-03-06 10:03:15.852 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 640x400 @ 60.00Hz
2021-03-06 10:03:15.853 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 640x480 @ 60.00Hz
2021-03-06 10:03:15.853 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 800x600 @ 60.00Hz
2021-03-06 10:03:15.853 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1024x768 @ 60.00Hz
2021-03-06 10:03:15.853 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1152x864 @ 60.00Hz
2021-03-06 10:03:15.854 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1280x600 @ 60.00Hz
2021-03-06 10:03:15.854 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1280x720 @ 60.00Hz
2021-03-06 10:03:15.854 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1280x768 @ 60.00Hz
2021-03-06 10:03:15.855 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1280x800 @ 60.00Hz
2021-03-06 10:03:15.855 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1280x960 @ 60.00Hz
2021-03-06 10:03:15.855 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1280x1024 @ 60.00Hz
2021-03-06 10:03:15.855 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1360x768 @ 60.00Hz
2021-03-06 10:03:15.856 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1366x768 @ 60.00Hz
2021-03-06 10:03:15.856 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1400x1050 @ 60.00Hz
2021-03-06 10:03:15.857 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1440x900 @ 60.00Hz
2021-03-06 10:03:15.857 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1600x900 @ 60.00Hz
2021-03-06 10:03:15.858 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1680x1050 @ 60.00Hz
2021-03-06 10:03:15.858 T:8832     INFO <general>: Additional mode: Generic PnP Monitor #1: 1920x1080 @ 60.00Hz
2021-03-06 10:03:15.858 T:8832     INFO <general>: CApplication::CApplication::CreateGUI - using the default windowing system
2021-03-06 10:03:15.858 T:8832     INFO <general>: Checking resolution 16
2021-03-06 10:03:15.883 T:18176    INFO <general>: Found 2 Lists of Devices
2021-03-06 10:03:15.883 T:18176    INFO <general>: Enumerated DIRECTSOUND devices:
2021-03-06 10:03:15.883 T:18176    INFO <general>:     Device 1
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_deviceName      : {EA9A54A7-F125-4152-B3FF-849BF21DB15B}
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_displayName     : Speakers - Lautsprecher (Realtek High Definition Audio)
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_displayNameExtra: DIRECTSOUND: Lautsprecher (Realtek High Definition Audio)
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_deviceType      : AE_DEVTYPE_PCM
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_channels        : FL, FR
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_sampleRates     : 48000
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_dataFormats     : AE_FMT_FLOAT
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_streamTypes     : No passthrough capabilities
2021-03-06 10:03:15.883 T:18176    INFO <general>:     Device 2
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_deviceName      : default
2021-03-06 10:03:15.883 T:18176    INFO <general>:         m_displayName     : default
2021-03-06 10:03:15.883 T:18176    INFO <general>: Enumerated WASAPI devices:
2021-03-06 10:03:15.884 T:18176    INFO <general>:     Device 1
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_deviceName      : {EA9A54A7-F125-4152-B3FF-849BF21DB15B}
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_displayName     : Speakers - Lautsprecher (Realtek High Definition Audio)
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_displayNameExtra: WASAPI: Lautsprecher (Realtek High Definition Audio)
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_deviceType      : AE_DEVTYPE_PCM
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_channels        : FL, FR
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_sampleRates     : 192000,96000,48000,44100
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_dataFormats     : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_streamTypes     : No passthrough capabilities
2021-03-06 10:03:15.884 T:18176    INFO <general>:     Device 2
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_deviceName      : default
2021-03-06 10:03:15.884 T:18176    INFO <general>:         m_displayName     : default
2021-03-06 10:03:15.884 T:10656    INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-03-06 10:03:15.927 T:18176 WARNING <general>: CActiveAE::ActiveAE::CActiveAE::StateMachine - signal: 0 from port: OutputControlPort not handled for state: 7
2021-03-06 10:03:15.932 T:8832     INFO <general>: DX:Big GrineviceResources::CheckNV12SharedTexturesSupport: extended NV12 shared textures is supported
2021-03-06 10:03:15.933 T:8832     INFO <general>: DX:Big GrineviceResources::CreateDeviceResources: device is created on adapter 'Intel® HD Graphics 630' with D3D_FEATURE_LEVEL_12_1
2021-03-06 10:03:15.937 T:8832     INFO <general>: DX:Big GrineviceResources::ResizeBuffers: 8 bit swapchain is used with 6 flip discard buffers and SDR output
2021-03-06 10:03:15.962 T:8832     INFO <general>: RetroPlayer[PROCESS]: Registering process control for Windows
2021-03-06 10:03:15.962 T:8832     INFO <general>: RetroPlayer[RENDER]: Registering renderer factory for DirectX
2021-03-06 10:03:16.057 T:8832     INFO <general>: load keymapping
2021-03-06 10:03:16.058 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/appcommand.xml
2021-03-06 10:03:16.059 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.AppleRemote.xml
2021-03-06 10:03:16.059 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.Harmony.xml
2021-03-06 10:03:16.060 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.SiriRemote.xml
2021-03-06 10:03:16.060 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/gamepad.xml
2021-03-06 10:03:16.061 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/joystick.xml
2021-03-06 10:03:16.063 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/keyboard.xml
2021-03-06 10:03:16.064 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/mouse.xml
2021-03-06 10:03:16.065 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/remote.xml
2021-03-06 10:03:16.066 T:8832     INFO <general>: Loading special://xbmc/system/keymaps/touchscreen.xml
2021-03-06 10:03:16.067 T:8832     INFO <general>: GUI format 1920x1080, Display Generic PnP Monitor #1: 1920x1080 @ 60.00Hz
2021-03-06 10:03:16.067 T:8832     INFO <general>: CLangInfo: loading resource.language.en_gb language information...
2021-03-06 10:03:16.103 T:8832     INFO <general>: global locale set to en-us
2021-03-06 10:03:16.103 T:8832     INFO <general>: CLangInfo: loading resource.language.en_gb language strings...
2021-03-06 10:03:16.141 T:1252     INFO <general>: Running database version Addons33
2021-03-06 10:03:16.143 T:1252     INFO <general>: Running database version ViewModes6
2021-03-06 10:03:16.145 T:1252     INFO <general>: Running database version Textures13
2021-03-06 10:03:16.147 T:1252     INFO <general>: Running database version MyMusic82
2021-03-06 10:03:16.150 T:1252     INFO <general>: Running database version MyVideos119
2021-03-06 10:03:16.152 T:1252     INFO <general>: Running database version TV37
2021-03-06 10:03:16.153 T:1252     INFO <general>: Running database version Epg13
2021-03-06 10:03:16.189 T:8832     INFO <general>: Unloaded skin
2021-03-06 10:03:16.189 T:8832     INFO <general>:   load skin from: C:\Program Files\Kodi\addons\skin.estuary\ (version: 3.0.5)
2021-03-06 10:03:16.189 T:8832     INFO <general>:   load fonts for skin...
2021-03-06 10:03:16.190 T:8832     INFO <general>: Loading skin includes from C:\Program Files\Kodi\addons\skin.estuary\xml\includes.xml
2021-03-06 10:03:16.218 T:8832     INFO <general>: Loading fonts from C:\Program Files\Kodi\addons\skin.estuary\xml\Font.xml
2021-03-06 10:03:16.243 T:8832     INFO <general>:   load new skin...
2021-03-06 10:03:16.243 T:8832     INFO <general>: Loading custom window XMLs from skin path C:\Program Files\Kodi\addons\skin.estuary\xml
2021-03-06 10:03:16.248 T:8832     INFO <general>:   initialize new skin...
2021-03-06 10:03:16.248 T:8832     INFO <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2021-03-06 10:03:16.250 T:8832     INFO <general>: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
2021-03-06 10:03:16.251 T:8832     INFO <general>: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
2021-03-06 10:03:16.252 T:8832     INFO <general>: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
2021-03-06 10:03:16.253 T:8832     INFO <general>: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
2021-03-06 10:03:16.259 T:8832     INFO <general>: Loading skin file: DialogNotification.xml, load type: LOAD_ON_GUI_INIT
2021-03-06 10:03:16.259 T:8832     INFO <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2021-03-06 10:03:16.260 T:8832     INFO <general>: Loading skin file: Custom_1109_TopBarOverlay.xml, load type: LOAD_ON_GUI_INIT
2021-03-06 10:03:16.265 T:8832     INFO <general>: Loading resource://resource.uisounds.kodi/sounds.xml
2021-03-06 10:03:16.277 T:8832     INFO <general>:   skin loaded...
2021-03-06 10:03:16.278 T:8832     INFO <general>: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
2021-03-06 10:03:16.278 T:8832     INFO <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2021-03-06 10:03:16.377 T:8832  WARNING <general>: JSONRPC: Could not parse type "Setting.Details.SettingList"
2021-03-06 10:03:16.377 T:8832     INFO <general>: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
2021-03-06 10:03:16.377 T:8832     INFO <general>: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
2021-03-06 10:03:16.386 T:8832     INFO <general>: JSONRPC v12.2.1: Successfully initialized
2021-03-06 10:03:16.393 T:8832     INFO <general>: AddOnLog: peripheral.joystick: Enabling joystick interface "xinput"
2021-03-06 10:03:16.396 T:8832     INFO <general>: AddOnLog: peripheral.joystick: Enabling joystick interface "directinput"
2021-03-06 10:03:16.400 T:8832     INFO <general>: PERIPHERALS::CPeripheralBus::Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2021-03-06 10:03:16.400 T:8832     INFO <general>: PERIPHERALS::CPeripheralBus::Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2021-03-06 10:03:16.401 T:8832     INFO <general>: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2021-03-06 10:03:16.401 T:8832     INFO <general>: Loaded playercorefactory configuration
2021-03-06 10:03:16.401 T:8832     INFO <general>: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2021-03-06 10:03:16.401 T:8832     INFO <general>: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2021-03-06 10:03:16.401 T:8832     INFO <general>: removing tempfiles
2021-03-06 10:03:16.405 T:8832     INFO <general>: initialize done
2021-03-06 10:03:16.405 T:8832     INFO <general>: Running the application...
2021-03-06 10:03:16.405 T:17920    INFO <general>: initializing python engine.
2021-03-06 10:03:16.407 T:11652    INFO <general>: ES: Starting UDP Event server on port 9777
2021-03-06 10:03:16.408 T:11652    INFO <general>: UDP: Listening on port 9777 (ipv6 : false)
2021-03-06 10:03:16.408 T:8832     INFO <general>: JSONRPC Server: Successfully initialized
2021-03-06 10:03:18.854 T:8832     INFO <general>: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
2021-03-06 10:03:19.869 T:2524     INFO <general>: CIRServerSuite:Tonguerocess: failed to connect to irss, will keep retrying every 5 seconds
2021-03-06 10:03:20.405 T:8832     INFO <general>: Loading skin file: AddonBrowser.xml, load type: KEEP_IN_MEMORY
2021-03-06 10:03:21.804 T:17920    INFO <general>: CPythonInvoker(0, C:\Users\Asus-NTB\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck\resources\lib\runner.py): script successfully run
2021-03-06 10:03:21.812 T:17920    INFO <general>: Python interpreter stopped
2021-03-06 10:03:22.737 T:8832     INFO <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2021-03-06 10:03:24.720 T:8832     INFO <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2021-03-06 10:03:30.336 T:14348    INFO <general>: CAddonMgr::ADDON::CAddonMgr::FindAddon: script.skin.helper.colorpicker v2.0.1 installed
2021-03-06 10:03:34.968 T:8832     INFO <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2021-03-06 10:03:45.767 T:14348   ERROR <general>: CAddonInstallJob[script.skin.helper.service]: The dependency on script.module.metadatautils version 1.0.31 could not be satisfied.
2021-03-06 10:03:51.693 T:8832     INFO <general>: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
2021-03-06 10:03:53.159 T:8832     INFO <general>: Stopping player
2021-03-06 10:03:53.159 T:8832     INFO <general>: Storing total System Uptime
2021-03-06 10:03:53.159 T:8832     INFO <general>: Saving settings
2021-03-06 10:03:53.175 T:8832     INFO <general>: Saving skin settings
2021-03-06 10:03:53.183 T:8832     INFO <general>: Stopping all
2021-03-06 10:03:53.183 T:8832     INFO <general>: ES: Stopping event server
2021-03-06 10:03:53.426 T:11652    INFO <general>: ES: UDP Event server stopped
2021-03-06 10:03:53.427 T:8832     INFO <general>: CServiceAddonManager: failed to stop service.xbmc.versioncheck (may have ended)
2021-03-06 10:03:53.701 T:8832     INFO <general>: Application stopped
2021-03-06 10:03:53.902 T:8832     INFO <general>: XBApplicationEx: destroying...
2021-03-06 10:03:53.927 T:8832     INFO <general>: AddOnLog: peripheral.joystick: Disabling joystick interface "directinput"
2021-03-06 10:03:53.927 T:8832     INFO <general>: AddOnLog: peripheral.joystick: Disabling joystick interface "xinput"
2021-03-06 10:03:53.927 T:8832     INFO <general>: ADDON: Dll Destroyed - Joystick Support
2021-03-06 10:03:53.927 T:8832     INFO <general>: unload skin
2021-03-06 10:03:53.937 T:8832     INFO <general>: Unloaded skin
2021-03-06 10:03:53.987 T:8832     INFO <general>: unload sections
2021-03-06 10:03:53.994 T:8832     INFO <general>: XBApplicationEx: application stopped!
Hello! I use kodi matrix and skin helper service give me error. No matter if i ununstall and reinstall.
Error Type: <class 'AttributeError'>
                                                   Error Contents: module 'pkg_resources' has no attribute 'declare_namespace'
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/service.py", line 10, in <module>
                                                       from resources.lib.main_service import MainService
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/main_service.py", line 15, in <module>
                                                       from resources.lib.webservice import WebService
                                                     File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/webservice.py", line 12, in <module>
(2021-03-06, 11:05)Tenker Wrote: [ -> ]you need skin.helper.service 1.33 and script.module.metadatautils 1.0.38
(2021-03-06, 11:05)Tenker Wrote: [ -> ]I have now quickly reinstalled Kodi.
19.5.2021
Please use this github for newest verion
https://github.com/kodi-community-addons
You can't instal only script, need to install all needing module.....
Use this list for install with that order and from link(download and install from zip)
          script.module.cherrypy  Link
          script.module.musicbrainz Link
          script.module.thetvdb Link
          script.module.metadatautils Link
          script.skin.helper.service Link
          script.skin.helper.widgets Link
          script.skin.helper.skinbackup Link
          script.skin.helper.backgrounds Link
          script.tv.show.next.aired Link
(2021-03-06, 14:02)marius37bv Wrote: [ -> ]Hello! I use kodi matrix and skin helper service give me error. No matter if i ununstall and reinstall.
Your log isn't complited...missing some part.Line 12 in webservice.py is
import cherrypy
That module have some isue, What version you use?
(2021-03-06, 20:50)Angelinas Wrote: [ -> ]
import cherrypy
I use 17.4.2-2 zip. But i just installed the module again from the link above version is 12.0.2 and no error so far. Thank You!
Hi @marcelveldt
I use Aeon Mq Skin 8 Matrix Mod by Latt's on Nvidia Shield.
latts9923 tell me to write in this thread and report the log.
I report you the error i receive, form Skin Helper Service and from TvShow Next Aired.
Hope can help to find a future solution.
How to reproduce:
For TvShow is random, i enter on series menu and sometimes give me the error.
For SkinHelper is random, i select information menu from a series, sometimes error and the info is empty, or no error and all the information.
https://paste.kodi.tv/korotahudu.kodi
(2021-03-09, 10:35)christofdarkan Wrote: [ -> ]Hi @marcelveldt
How to reproduce:
Actually is should be the skin maintainer tracking down and reporting the bug.
How to reproduce:
That isn't SHS isue, try to test this version of script.module.arrow....I just include changes from Authors github (systemcatch)
https://github.com/arrow-py/arrow
I tested and no more annoying message "ERROR - script.skin.helper.service", keep testing for log "AttributeError: 'bytes' object has no attribute 'tzinfo'"
https://mega.nz/file/XVgXAYYZ#PyTK4RpHMF...G4AUmjHna8
Edit....
script.tv.show.next.aired...now is down...grrrrrrr
(2021-03-10, 00:08)Angelinas Wrote: [ -> ]
How to reproduce:
Edit....
Hi and thanks, i try it, and here is the new log: https://paste.kodi.tv/ikerilabev.kodi
Hope this can help Smile
(2021-03-10, 11:09)christofdarkan Wrote: [ -> ]Hi and thanks, i try it, and here is the new log: https://paste.kodi.tv/ikerilabev.kodi
In your log I can't see what is your tvdb module, but if you use from latts9923 repo, pleae use from https://github.com/kodi-community-addons
That module and other script are old with error.
Reinstall all from this source (link) and "reset all data" in setings for script.tv.show.next.aired
https://forum.kodi.tv/showthread.php?tid...pid3020831
script.module.arrow with latest changes fixed all mine error on Win10 and android box
(2021-03-10, 22:08)Angelinas Wrote: [ -> ]
Thanks, i use the last script and script, but i don't reset data; i've done it and the error is solved.
For TvShow something is wrong, it take a long time to update info when i scroll the series.
@Angelinas
I am using Matrix and MQ8 skin mod by Latts. I use your scripts from this threat. TV Next Aired was working but now it looks like this?
Can you help me?
