Full Version: skin helper service
(2021-03-18, 06:18)melons2 Wrote: [ -> ]@Angelinas
I am using Matrix and MQ8 skin mod by Latts. I use your scripts from this threat. TV Next Aired was working but now it looks like this?
Can you help me?
Just delete file in your skin folder .....
script-NextAired-TVGuide.xml
(2021-03-18, 14:16)Angelinas Wrote: [ -> ]
Can you help me?
I deleted "script-NextAired-TVGuide.xml" from the C:\Users\xxxxxx\AppData\Roaming\Kodi\addons\skin.aeonmq8.matrix.mod\xml directory. I shutdown KODI and restarted it and went to TV Next Aired settings and did a "REST ALL DATA". I shutdown and restarted KODI again but it still looks the same as the image in my last post.
I tried a second time and got this error:
2021-03-18 14:24:06.435 T:38564   ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                   Error Type: <class 'AttributeError'>
                                                   Error Contents: 'datetime.timedelta' object has no attribute 'tzinfo'
                                                     File "C:\Users\iblong\AppData\Roaming\Kodi\addons\script.tv.show.next.aired\default.py", line 9, in <module>
                                                       from resources.lib.main_module import MainModule
                                                     File "C:\Users\iblong\AppData\Roaming\Kodi\addons\script.tv.show.next.aired\resources\lib\main_module.py", line 14, in <module>
                                                       from thetvdb import TheTvDb
                                                     File "C:\Users\iblong\AppData\Roaming\Kodi\addons\script.module.thetvdb\lib\thetvdb.py", line 23, in <module>
                                                       import arrow
                                                     File "C:\Users\iblong\AppData\Roaming\Kodi\addons\script.module.arrow\lib\arrow\__init__.py", line 3, in <module>
                                                       from .api import get, now, utcnow
                                                     File "C:\Users\iblong\AppData\Roaming\Kodi\addons\script.module.arrow\lib\arrow\api.py", line 10, in <module>
                                                       from arrow.factory import ArrowFactory
                                                     File "C:\Users\iblong\AppData\Roaming\Kodi\addons\script.module.arrow\lib\arrow\factory.py", line 19, in <module>
                                                       from arrow.arrow import Arrow
                                                     File "C:\Users\iblong\AppData\Roaming\Kodi\addons\script.module.arrow\lib\arrow\arrow.py", line 1396, in <module>
                                                       Arrow.max = Arrow.fromdatetime(datetime.max)
                                                     File "C:\Users\iblong\AppData\Roaming\Kodi\addons\script.module.arrow\lib\arrow\arrow.py", line 217, in fromdatetime
                                                       if dt.tzinfo is None:
                                                   AttributeError: 'datetime.timedelta' object has no attribute 'tzinfo'
2021-03-18 14:24:06.927 T:38564    INFO <general>: Python interpreter stopped
Do you have any other suggestions?
(2021-03-18, 21:26)melons2 Wrote: [ -> ]Do you have any other suggestions?
You use mine zip version from this thread, please use one from github....
There is some changes in skin folder...
https://github.com/kodi-community-addons...fault/720p
(2021-03-18, 22:44)Angelinas Wrote: [ -> ]
 Before your answer I reinstalled all of the scripts from the post #4266 and put the "script-NextAired-TVGuide.xml" back in the skins folder and now it works!
Thank you!
Should I still install your new "script.tv.show.next.aired.zip" ?
(2021-03-18, 23:13)melons2 Wrote: [ -> ]Should I still install your new "script.tv.show.next.aired.zip" ?
No, you have good version now.Thats from github keep using that version.
(2021-03-18, 23:20)Angelinas Wrote: [ -> ]
Thank you!
Hey there guys I had this issue before with sorting boxset movies with sort titles but thanks to @Angelinas help I was able to do it in a previouse version of kodi (leia Aeion mq 7) but now that I updated to to Kodi matrix aeion mq 7, I tried using the method that angelinas showed me before but it didn't work. Maybe y'all or @Angelinas  might be able help me out since i'm still somewhat of a novice with this stuff.
Anyway, I'm trying to sort my movies in my boxset by sort titles instead of by years so that my movies can be sorted canonically.
In the extended plot, extended consensus and the movie cases animation...
All three of those are sorted by year, which I don't want. Is there a way to tweak things so that they are sorted by sort title?
Thank you for your time.
I report a bug on GitHub regarding skin backup two weeks ago, anyone having the same issues?
https://github.com/kodi-community-addons.../issues/14
@Angelinas 1.0.19 skin backup, when I run and try to create backup, the addon does nothing.
Also nothing on the logs
(2021-03-20, 20:47)djhifi Wrote: [ -> ]@Angelinas 1.0.19 skin backup, when I run and try to create backup, the addon does nothing.
That was fixed today....
https://github.com/kodi-community-addons...d2c51dc2fe
(2021-03-19, 07:18)nomnom27 Wrote: [ -> ]All three of those are sorted by year, which I don't want. Is there a way to tweak things so that they are sorted by sort title?
I don't want to change sorted by year, if you want to change I only can show in code what to change,
and after your changes need to delete simplecache.db to make effect this change.
change this
https://github.com/kodi-community-addons...ils.py#L85
in this....
movieset_movies = sorted(movieset['movies'], key=itemgetter("label"))
(2021-03-20, 21:00)Angelinas Wrote: [ -> ]
I thought the latest versions were the ones you posted in some pages ago "SHS pack"
I tested the newer version "c671440" and still nothing is happening. Am I downloading the right one?
Btw when will the auto-update of all the modules be pushed into the repo? Its so confusing right now
(2021-03-20, 22:11)djhifi Wrote: [ -> ]
For all script and module is same download address like in this post
https://forum.kodi.tv/showthread.php?tid...pid3020831
New version is always "Master"...
https://github.com/kodi-community-addons...master.zip
(2021-03-20, 23:35)Angelinas Wrote: [ -> ]
(2021-03-20, 21:00)Angelinas Wrote: [ -> ]That was fixed today....
So I downloaded the correct version...I just downloaded again, from the link you provided and it's not working. It's not doing anything.
Do I need to install/update anything else to get this working?
I need to backup my skin because I'm going to nuke KODI and reinstall everything Tongue
(2021-03-21, 00:42)djhifi Wrote: [ -> ]So I downloaded the correct version...I just downloaded again, from the link you provided and it's not working. It's not doing anything.
For win10 working...creating from addon with "run" command.
