(2015-10-19, 21:43)Tgxcorporation Wrote: [ -> ] (2015-10-19, 19:47)marcelveldt Wrote: [ -> ]OK, It's now added on Git. Please have a look at the readme how it works. You can use the webservice to do this.
Thanks, perfect!
Is it possible to make it work in MusicPlayer/MusicVisualisation screen too?
Thank you very much!
Tgx
Should work, I think you can use player.dbid for that, if not I will make sure that the window props will also be filled in the music player.
EDIT: Hmm MusicPlayer.DBID is not available as it looks like. I will extend the code to also fill the window props for the player tomorrow.
Hi Marcel.
The wall views are working well, will you be adding TV Show support to it?
Possibly an option for a collage view aka Emby may look good to.
(2015-10-19, 22:52)marcelveldt Wrote: [ -> ] (2015-10-19, 22:13)tomer953 Wrote: [ -> ]http://pastebin.com/rQ3sQTEn
OK, not sure if this is going to fix it but please try latest Git.
I will report about it tomorrow.
meanwhile, I see in my own log:
http://pastebin.com/jkVrNJNs
i'm did not enable any PVR options.
Edit:
about the backup problem from the Rpi2 - latest git was helpful.
He is keep to get error, but I think it because he's trying to backup to external hdd and has permission problems. 10x
Thanks, perfect!
Tgx
Now added... See the readme because I've added a few additional properties that you can use in the player.
Also nice to know is that the script now also provides extrafanart for both music and pvr artwork.
(2015-10-20, 18:07)im85288 Wrote: [ -> ]Hi Marcel.
TVshows wall has been added. What do you mean with a collage view?
(2015-10-22, 02:48)marcelveldt Wrote: [ -> ]Now added... See the readme because I've added a few additional properties that you can use in the player.
Hi Marcel,
thanks for your work.
I've just tested the latest commit and i've found these properties not working:
Window(Home).Property(SkinHelper.Player.Music.Banner)
Window(Home).Property(SkinHelper.Player.Music.FanArt)
Window(Home).Property(SkinHelper.Player.Music.ClearLogo)
Window(Home).Property(SkinHelper.Player.Music.ExtraFanArt)
Window(Home).Property(SkinHelper.Player.Music.AlbumList)
The images cause a warning in Kodi log such as:
WARNING: CreateLoader - unsupported protocol(http) in
http://www.theaudiodb.com/images/media/a...358612.jpg
DEBUG: GetImageHash - unable to stat url
Tgx
Stupid question Marcel ... but How do you get into the script settings. I'm trying the common way by the addons browser but your script isn't in the list ? Did I miss something ?
It is under "Add-ons" - "system" - "Running"
marcelveldt love this project, keep up the great work...
(2015-10-22, 18:26)tomer953 Wrote: [ -> ]It is under "Add-ons" - "system" - "Running"
Sure ... Thanks.
Usually use "My-addons" but not showing there.
Can you add looking up similar movies to a specific film?
ex:
plugin://script.skin.helper.service/?action=similarmovies&imdbid=tt0796366&limit=25
