Full Version: Clean Mediaportal NFO Files on Import
Hi there,
i started using TMM when i made the switch from Mediaportal to Kodi beginning this year and it was a great help.
I had all my Movies setup with Mediaportal NFO Files which also were imported without any problem, at the first look.
The simple problem is that Mediaportal uses pipes, as delimiter in the NFO Files, and so do the programs which write NFO's for MePo.
So TMM imports that but does not translate that to Kodi standard.
If there is something like that in the Genre Tag of the NFO: |Fanatsy|Comedy|Drama| this is treated as one Genre, not as three seperate ones.
There is the same problem with director, Original Title etc.
It would be great if TMM could directly filter that on import, so that an exported Kodi NFO is really standard compliant.
If you need any sample NFO's i would be happy to supply them.
