2015-08-18, 20:15
Hi, just curious to know if this is normal behavior or bug. When using <textoffsetx> for the spincontrolex label, label shifts OK from left but spins images also shift the same value from right and label2 shifts the same value from spins. I'm using the offset to include an icon front of the label but the result looks weird with label2 and spins shifted the other side ?
EDIT : Using Jarvis dev builds. Didn't try with Isengard
