Of note: I use it kodi media center in linux. In today's update I had I left the terminal:
[arescorpio@
arescorpio ~]$ kodi
/usr/bin/kodi: línea 165: 990 Violación de segmento (`core' generado) "$LIBDIR/${bin_name}/${bin_name}.bin" $SAVED_ARGS
Crash report available at /home/arescorpio/kodi_crashlog-20150820_001354.log
Actually I have the version: kodi-15.1-1.parabola1, but the launch is locked and closed, NOT work for me. Need to solve the problem from the terminal if possible, I thank the help. (I am Spanish and I am writing this message with a translator.)
Install proper GPU drivers and use a fully tested GCC ...
[arescorpio@
arescorpio ~]$ dmesg
[ 170.977874] kodi.bin[913]: segfault at 2d9 ip 00000000008b0320 sp 00007ffc610ba9c8 error 4 in kodi.bin[400000+1df0000]
[ 1990.047960] gnote[1521]: segfault at 0 ip 00007f2cd52188d0 sp 00007ffcebecc118 error 4 in libgtk-3.so.0.1600.6[7f2cd5115000+6d9000]
[ 2298.116504] gnote[1629]: segfault at 0 ip 00007f3e7ebaa8d0 sp 00007ffe6cf212d8 error 4 in libgtk-3.so.0.1600.6[7f3e7eaa7000+6d9000]
[ 2312.810617] kodi.bin[1652]: segfault at 2d9 ip 00000000008b0320 sp 00007ffd95a0d108 error 4 in kodi.bin[400000+1df0000]
I use Parabola GNU / Linux-libre or arch-linux but is free, so any package that incorporates must belong to the database: pacman. Thanks for the help . I did not find my database in any package related to what you are indicating me
(2015-08-30, 10:07)fritsch Wrote: [ -> ]Install proper GPU drivers and use a fully tested GCC ...
GL_VENDOR = nouveau <-- not supported
[arescorpio@
arescorpio ~]$ pacman -Ss nouveau
extra/mesa 10.6.5-1 [instalado]
an open-source implementation of the OpenGL specification
extra/xf86-video-nouveau 1.0.11-3 (xorg-drivers xorg) [instalado]
Open Source 2D acceleration driver for nVidia cards
(2015-09-03, 05:30)arescorpio Wrote: [ -> ][arescorpio@arescorpio ~]$ pacman -Ss nouveau
Stop that. Use a distro for beginners, one you can manage. You miss the nvidia binary drivers.
Dont use nouveau, it wont work properly with Kodi and sadly the NVIDIA driver is indeed the ONLY choice for Kodi users. As for nouveau remove it, block it or whatever you need to do in your distro to properly install the NVIDIA driver and libvdpau.
I come utilizandp Kodi media center in my Parabola GNU / Linux-libre since 2010 (even using the program: nouveau) without problems. But as I have been explaining ago Kodi about 4 updates fails. why I put this paste.No is a problem of my system because I utiizo 4 operativo.Simplemente hardware with GNU / Linux-libre parabola using Kodi and only on this team is failing Kodi.
http://4f593159c2f2cbf0.paste.se/
you have been told 3 times that nouveau is NOT SUPPORTED. Arguing about it won't change that.
