2015-08-20, 23:20
I have been using ESPN3 add on for long time and it has been working great until I started having issues last week. Every time I start the ESPN3 add onand click on load live stream first and then entire Kodi program collapses (closes itself). I am using Kodi Helix on android TV set up box with android 4.1. . I tried to uninstall and install ESPN3 add on and also entire Kodi . I also did factory reset of my Android box but same issue is still happening. I was wondering if anyone experienced this before and if there is anything I can do do get the ESPN 3 back. Unfortunately I can't upgrade Kodi since my box has 4.1 version of android and 4.2 and up is needed to install latest Kodi upgrade Isengard . I am guessing this can be an issue, but don'tt see why I wouldn't be able to still use Helix when it worked good in the past. Any help is appreciated.
Max
Max
