2015-08-21, 00:44
Since updating kodi to 15.0 (and 15.1, and 16.0 alpha) from 14.2 I've had issues watching tv with the HDHomeRun video add-on. It does not appear to be a HDHR issue so I've decided to post my problem here.
A problem with HDHR in general is that it sometimes drops out for a few seconds or becomes very weak. This is a semi-common issue I see on the SiliconDust forums. Now, in 14.2 this would be handled by pausing the stream and I'd see 'buffering' with a percentage. when it got to 100 I'd get some skips in the stream then it would be playing live. I'd miss a few seconds of TV but everything played smoothly other than those pauses. In 15.0 the video tries to continue playing and never pauses, but I get horrible pixelation in the stream and audio cuts in and out. This generally lasts much longer than the simple pause did before, I'm guessing because kodi is trying to keep up with the live stream.
So I guess my question is did something change in the way kodi buffers network streams (I'm also assuming HDHR over my local network is considered a network stream), and is there something I can change in settings or advancedsettings to help this? I updated my main machine to 15.1 and it has been horrible as I have to exit out of the plugin and restart it to reset the cache and have the video play normally (this is typically much faster than 'waiting it out' when the video goes bad). I have tested 15.0 and 15.1 on windows 10 as well as 15.1 and 16.0 alpha on android and all give me these issues. 14.2 on windows 10 and 14.2 on android both work as I described above; it pauses the stream for a few moments then jumps back to live. Is there anything I can do to regain this functionality? I can't stay on 14.2 forever, but the livetv experience on it is so far ahead of 15 onward...
