either set vnsiserver setting "avoid egp scan while streaming" to true or set priority in vnsi configuration setting to zero
Did what you ask and this morning, at the reboot, te message is gone, but vdr is still crashing, with this message :
ao��t 22 09:16:36 BIBI_SERVER kernel: traps: VDR VNSI Server[6086] trap divide error ip:7f860fb83ada sp:7f860d127d80 error:0 in libvdr-vnsiserver.so.2.2.0[7f860fb64000+46000]
ao��t 22 09:16:34 BIBI_SERVER vdr[6073]: [6073] ERROR: Channel locked (recording)!
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6086] VNSI: Welcome client 'XBMC Media Center' with protocol version '8'
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6083] VNSI: Client with ID 0 connected: 192.168.0.12:58828
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6083] loading /etc/vdr/plugins/vnsiserver/allowed_hosts.conf
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] ERROR: no OSD provider available - using dummy OSD!
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] OSD size changed to 720x480 @ 1
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6082] Streamdev: Listening (HTTP) on port 3000
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6082] Streamdev: Listening (VTP) on port 2004
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6082] streamdev server thread started (pid=6073, tid=6082, prio=high)
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6083] VDR VNSI Server thread started (pid=6073, tid=6083, prio=high)
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] switching to channel 1 (TF1 HD)
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] skin "EnigmaNG" not available - using "lcars" instead
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] VNSI: Channel streaming timeout: 10 seconds
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] VNSI: VNSI Server started
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] VNSI: Starting vnsi server at port=34890
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] starting plugin: vnsiserver
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6080] frontend 1/0 tuner thread started (pid=6073, tid=6080, prio=high)
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6081] device 1 section handler thread started (pid=6073, tid=6081, prio=low)
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] loading /etc/vdr/plugins/streamdev-server/streamdevhosts.conf
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] starting plugin: streamdev-server
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] SVDRP listening on port 6419
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] assuming manual start of VDR
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] setting primary device to 1
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] ERROR: no primary device found - using first device!
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] ERROR: invalid primary device number: 2
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] initializing plugin: vnsiserver (1.2.1): VDR-Network-Streaming-Interface (VNSI) Server
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] initializing plugin: streamdev-server (0.6.1-git): VDR Streaming Server
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] found 1 DVB device
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] cTimeMs: using monotonic clock (resolution is 1 ns)
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] frontend 1/0 provides DVB-T with QPSK,QAM16,QAM64 ("Philips TDA10046H DVB-T")
ao��t 22 09:16:33 BIBI_SERVER vdr[6073]: [6073] DVB API version is 0x050A (VDR was built with 0x050A)
ao��t 22 09:16:32 BIBI_SERVER kernel: tda1004x: found firmware revision 20 -- ok
ao��t 22 09:16:32 BIBI_SERVER kernel: tda1004x: setting up plls for 48MHz sampling clock
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6076] video directory scanner thread ended (pid=6073, tid=6076)
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6078] epg data reader thread ended (pid=6073, tid=6078)
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6077] video directory scanner thread ended (pid=6073, tid=6077)
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6076] video directory scanner thread started (pid=6073, tid=6076, prio=high)
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6077] video directory scanner thread started (pid=6073, tid=6077, prio=high)
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6078] reading EPG data from /var/cache/vdr/epg.data
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6078] epg data reader thread started (pid=6073, tid=6078, prio=high)
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] new device number 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] creating cDvbDevice
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] probing /dev/dvb/adapter1/frontend0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] registered source parameters for 'T - DVB-T'
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] registered source parameters for 'S - DVB-S'
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] registered source parameters for 'C - DVB-C'
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] registered source parameters for 'A - ATSC'
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] loading /etc/vdr/svdrphosts.conf
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] loading /etc/vdr/timers.conf
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] loading /etc/vdr/channels.conf
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: VerboseLNBlog = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: UseVidPrefer = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: UseSyncEarlyPatch = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: UseSoftOsd = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: UseFriendlyFNames = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: UseDolbyInRecordings = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: SupportTeletext = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: SoftOsdRate = 50
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: SoftOsdPaletteOnly = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: SoftOsdFadeoutSteps = 16
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: SoftOsdFadeinSteps = 6
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: ShowValidInput = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: ReloadMarks = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: RecordingsSortMode = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: RecordingsSortDirsFirst = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: RecordDolbyDigital = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: PrimaryLimit = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: PlayJump = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: PauseLastMark = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: nVidPrefer = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: noEPGMode = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: noEPGList =
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: MixEpgAction = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: MenuCmdPosition = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: MemBufSize = 5
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: MaxRecordingSize = 100
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: MainMenuTitle = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: LRVolumeControl = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: LRForwardRewind = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: LRChannelGroups = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: LiveBufferSize = 100
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: LiveBuffer = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: KeepPaused = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: JumpSecondsSlow = 10
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: JumpSeconds = 60
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: JumpPlay = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: InRAM = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: HardLinkCutter = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: ExtendBuffer = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: DvdTrayMode = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: DvdSpeedLimit = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: DvdDisplayZeros = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: DvdDisplayMode = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: DoubleEpgTimeDelta = 15
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: DoubleEpgAction = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: DolbyTransferFix = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: DisableVPS = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: CutTimePatchEnabled = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: CutTime = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: CutterAutoDelete = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: CustomMainMenuTitle = Video Disk Recorder
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: ChannelBlockerMode = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: ChannelBlockerList =
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: ChannelBlocker = 0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: Card3usesLNBnr = 3
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: Card2usesLNBnr = 2
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] ERROR: unknown config parameter: Card1usesLNBnr = 1
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] loading /etc/vdr/setup.conf
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] loading plugin: /usr/lib/vdr/plugins/libvdr-vnsiserver.so.2.2.0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] loading plugin: /usr/lib/vdr/plugins/libvdr-streamdev-server.so.2.2.0
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] found 28 locales in /usr/share/locale
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] codeset is 'UTF-8' - known
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] running as daemon (tid=6073)
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] switched to user 'vdr'
ao��t 22 09:16:32 BIBI_SERVER vdr[6073]: [6073] VDR version 2.2.0 started
In kodi log, i see nothing. Everytime in the log it says something about a channel locked (recording) even if nothing is recording...
I fixed a div by zero in vnsiserver. Could you try again with current master?
I found the issue, the partition Where i record tv shows were full.
bibi
