Hi, just noticed that the weather widget doesn't fill if you've not opened MyWeather.xml first.
Is there a command line <onload> to include in Home to preload the forecast ? Or Startup ?
$INFO[Window(Weather).Property(foo)]
(2015-08-21, 16:49)nessus Wrote: [ -> ]$INFO[Window(Weather).Property(foo)]
Thanks Nessus but that's not what I meant. My list is set correctly and displays fine ... But only if I open MyWeather.xml first. It seems that MyWeather.xml fills the properties or launches datas downloading. If I don't launch MyWeather.xml, my widget remains empty.
Got it, I've set a dummy property with $INFO[Weather.Conditions]. Missed this "Can be used to load/refresh" in the wiki.
