2015-08-21, 16:45
Pages: 1 2
2015-08-21, 16:45
2015-08-21, 17:15
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install kodi kodi-bin
one(!) after(!) the other.
After that: give us:
apt-cache policy kodi
And some hint: Mint is not Ubuntu
sudo apt-get update
2015-08-21, 20:16
(2015-08-21, 17:15)fritsch Wrote: [ -> ]sudo add-apt-repository ppa:team-xbmc/ppaI Paste Now in terminal
sudo apt-get update
and later enter
and later
sudo apt-get update
and later enter
and later
but still but i do not find the kodi 15?
why?
Mint is not by Ubuntu?
how to give here in Exactly, the apt-cache policy kodi?
thanks
2015-08-21, 21:53
what do you mean, kodi not found? its _installed_ in the 2nd last line of your screen shot...
2015-08-21, 22:07
(2015-08-21, 21:53)wsnipex Wrote: [ -> ]what do you mean, kodi not found? its _installed_ in the 2nd last line of your screen shot...So how do Exactly I get the kodi?
in software Manager that i write in Search the word kodi,
there is A lot of software of kodi, so What of them to install?
& way Even also that Some of these programs is marked In a sign of installed, in my downloads folder i do not find Them, why?
thanks.
2015-08-21, 22:28
You already installed kodi Your screenshot shows that!
Just enter:
and see
Just enter:
kodi
and see
2015-08-21, 23:16
(2015-08-21, 22:28)fritsch Wrote: [ -> ]You already installed kodi Your screenshot shows that!i wrote the word kodi in terminal it's run good.
Just enter:
Code:kodi
and see
thanks
& how to add repository to kodi in Manually?
how it's work Instead navigation in option of kodi of system-addons-install from zip file, via software of winrar, in windows?
How is it in linux?
& in linux how to do from the terminal from the Certain software, Shortcut in Desktop?
& where is Exactly it's find in the desktop the file to run of kodi? to make from the desktop, Shortcut to run the kodi.
2015-08-22, 06:53
Please put those question to the mint forum. We are not the place to teach you using your operating system.
2015-08-22, 14:45
About It
"& how to add repository to kodi in Manually?
How is it in linux?"
in other forums They wrote me it belongs to forum kodi.
2015-08-22, 14:52
Seems you might be doing yourself a major favor by using kodibuntu instead?
2015-08-22, 17:20
(2015-08-22, 14:52)brendansound Wrote: [ -> ]Seems you might be doing yourself a major favor by using kodibuntu instead?how Exactly to use in kodibuntu?
& Where Exactly to download it?
thanks.
2015-08-22, 17:26
Download the ISO best suited to your computer (x32 or x64):
http://kodi.tv/download/
Create a bootable USB (personally i use LiLi USB Creator to make mine: http://www.linuxliveusb.com/)
Put USB key into machine you want to be server, Fresh partition and install
Perhaps this will help:
http://kodi.wiki/view/First_time_user
2015-08-23, 02:53
i'll try this.
" 3 Prerequisites
To create a USB installation disk, you will need:
Your favorite bootable USB creator tool[1]
A 2GB or bigger USB flash drive. Files on this USB disk will be erased, so back up your data first. Make sure this USB disk is properly formatted and mounted.
A Kodibuntu ISO file. See Kodi Download to download it.
Note: If you're installing Kodi on top of Ubuntu, use the Ubuntu ISO instead of the Kodibuntu ISO. The ISO-to-flash drive process is similar for both Kodibuntu.iso and Ubuntu.iso -- see next line
A Ubuntu image file. See [Download] to download it. "
but the page of the Download this is eror
http://www.ubuntu.com/download/alternati...ads|Ubuntu
" 3 Prerequisites
2015-08-23, 09:20
Is there a reason you want to install Kodi on top of Ubuntu? Are you planning on using the Ubuntu machine outside of Kodi?
2015-08-24, 06:03
(2015-08-23, 09:20)brendansound Wrote: [ -> ]Is there a reason you want to install Kodi on top of Ubuntu? Are you planning on using the Ubuntu machine outside of Kodi?i need os linux also.
so
why the kodi is crashed?
Even this question from the Linux forum, They asked me to write About this problem here.
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: ב' אוג 24 07:00:35 IDT 2015
Kodi Options:
Arch: i686
Kernel: Linux 3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 09:44:48 UTC 2015
Release: Ubuntu 14.04.3 LTS, Trusty Tahr
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/rami/core (2015-08-24 07:00:35.800731834 +0300)
[New LWP 3349]
[New LWP 3350]
[New LWP 3352]
[New LWP 3306]
[New LWP 3305]
[New LWP 3308]
[New LWP 3309]
[New LWP 3314]
[New LWP 3311]
[New LWP 3317]
[New LWP 3321]
[New LWP 3320]
[New LWP 3322]
[New LWP 3325]
[New LWP 3326]
[New LWP 3323]
[New LWP 3324]
[New LWP 3327]
[New LWP 3310]
[New LWP 3333]
[New LWP 3334]
[New LWP 3335]
[New LWP 3307]
[New LWP 3353]
[New LWP 3342]
[New LWP 3302]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0xb611890f in std:tring::assign(std:tring const&) () from /usr/lib/i386-linux-gnu/libstdc++.so.6
Thread 26 (Thread 0xb2662740 (LWP 3302)):
#0 0xb4d29063 in ?? () from /usr/lib/nvidia-340/libnvidia-glcore.so.340.76
#1 0xb4907d7c in ?? () from /usr/lib/nvidia-340/libnvidia-glcore.so.340.76
#2 0x084b7799 in CGUIFontTTFGL::LastEnd() ()
#3 0x084868a0 in CGUIFontTTFBase::End() ()
#4 0x084df272 in CGUIFont::End() ()
#5 0x08518beb in CGUITextLayout::Render(float, float, float, unsigned int, unsigned int, unsigned int, float, bool) ()
#6 0x084eb8e3 in CGUILabel::Render() ()
#7 0x08490cf0 in CGUIListLabel::Render() ()
#8 0x084be408 in CGUIControl:oRender() ()
#9 0x084c927b in CGUIControlGroup::Render() ()
#10 0x084be408 in CGUIControl:oRender() ()
#11 0x0848ecae in CGUIListItemLayout::Render(CGUIListItem*, int) ()
#12 0x08522644 in CGUIBaseContainer::RenderItem(float, float, CGUIListItem*, bool) ()
#13 0x08525a61 in CGUIBaseContainer::Render() ()
#14 0x084be408 in CGUIControl:oRender() ()
#15 0x084c927b in CGUIControlGroup::Render() ()
#16 0x084be408 in CGUIControl:oRender() ()
#17 0x084c927b in CGUIControlGroup::Render() ()
#18 0x084be408 in CGUIControl:oRender() ()
#19 0x0849bcb0 in CGUIWindow:oRender() ()
#20 0x084a1f94 in CGUIWindowManager::RenderPass() const ()
#21 0x084a2184 in CGUIWindowManager::Render() ()
#22 0x089f5ac0 in CApplication::RenderNoPresent() ()
#23 0x089fbb1e in CApplication::Render() ()
#24 0x08aa3d38 in CXBApplicationEx::Run() ()
#25 0x08aaa767 in XBMC_Run ()
#26 0x08356486 in main ()
Thread 25 (Thread 0x9dbf6b40 (LWP 3342)):
#0 0xb7703d50 in __kernel_vsyscall ()
#1 0xb5f81e31 in select () at ../sysdeps/unix/syscall-template.S:81
#2 0xb6ed0781 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#3 0xb6eadf29 in PyCFunction_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#4 0xb6eeea07 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#5 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#6 0xb6eef16c in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#7 0xb6eef242 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#8 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#9 0xb6f587f3 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#10 0xb6f01844 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#11 0xb6eec9c4 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#12 0xb6eef242 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#13 0xb6eef242 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#14 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#15 0xb6f5870e in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#16 0xb6f01844 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#17 0xb6e22561 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#18 0xb6f01844 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#19 0xb6ea3c72 in PyEval_CallObjectWithKeywords () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#20 0xb6e1dc80 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#21 0xb72d2f70 in start_thread (arg=0x9dbf6b40) at pthread_create.c:312
#22 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 24 (Thread 0xa6168b40 (LWP 3353)):
#0 0xb6b61c11 in ?? () from /usr/lib/i386-linux-gnu/libsqlite3.so.0
#1 0xb6b62937 in ?? () from /usr/lib/i386-linux-gnu/libsqlite3.so.0
#2 0xb6b88691 in ?? () from /usr/lib/i386-linux-gnu/libsqlite3.so.0
#3 0xb6b8da66 in sqlite3_step () from /usr/lib/i386-linux-gnu/libsqlite3.so.0
#4 0xb6b834ec in sqlite3_exec () from /usr/lib/i386-linux-gnu/libsqlite3.so.0
#5 0x086876d7 in dbiplus::SqliteDatabase:tart_transaction() ()
#6 0x0868aa43 in dbiplus::SqliteDataset::make_query(std::list<std:tring, std::allocator<std:tring> >&) ()
#7 0x086873fd in dbiplus::SqliteDataset::make_insert() ()
#8 0x0867b59f in dbiplus:ataset::post() ()
#9 0x0867180a in CDatabase::CommitInsertQueries() ()
#10 0x086c967d in EPG::CEpg:ersist() ()
#11 0x086cea1b in EPG::CEpgContainer:ersistAll() ()
#12 0x086cee07 in EPG::CEpgContainer:rocess() ()
#13 0x097aef85 in CThread::Action() ()
#14 0x097af69d in CThread:taticThread(void*) ()
#15 0xb72d2f70 in start_thread (arg=0xa6168b40) at pthread_create.c:312
#16 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 23 (Thread 0xb1cffb40 (LWP 3307)):
#1 0xb5f7ac8b in poll () at ../sysdeps/unix/syscall-template.S:81
#2 0xb667fbbd in ?? () from /usr/lib/i386-linux-gnu/libpulse.so.0
#3 0xb666e4ee in pa_mainloop_poll () from /usr/lib/i386-linux-gnu/libpulse.so.0
#4 0xb666ed1d in pa_mainloop_iterate () from /usr/lib/i386-linux-gnu/libpulse.so.0
#5 0xb666edf4 in pa_mainloop_run () from /usr/lib/i386-linux-gnu/libpulse.so.0
#6 0xb667fb5c in ?? () from /usr/lib/i386-linux-gnu/libpulse.so.0
#7 0xb35e94dd in ?? () from /usr/lib/i386-linux-gnu/pulseaudio/libpulsecommon-4.0.so
#8 0xb72d2f70 in start_thread (arg=0xb1cffb40) at pthread_create.c:312
#9 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 22 (Thread 0x9c1bfb40 (LWP 3335)):
#1 0xb72d712d in pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/i386/i686/../i486/pthread_cond_timedwait.S:245
#2 0x08ad530b in NPT_PosixSharedVariable::WaitUntilEquals(int, int) ()
#3 0x08abd4d5 in NPT_HttpConnectionManager::Run() ()
#4 0x08ad4f92 in NPT_PosixThread::Run() ()
#5 0x08ad54f6 in NPT_PosixThread::EntryPoint(void*) ()
#6 0xb72d2f70 in start_thread (arg=0x9c1bfb40) at pthread_create.c:312
#7 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 21 (Thread 0xa5967b40 (LWP 3334)):
#1 0xb72da0a8 in connect () at ../sysdeps/unix/sysv/linux/i386/socket.S:95
#2 0xb6e7ee55 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#3 0xb6eadeb4 in PyCFunction_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#6 0xb6f5870e in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#7 0xb6f01844 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#8 0xb6e8f098 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#9 0xb6f01844 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#10 0xb6eec011 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#11 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#12 0xb6eef16c in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#14 0xb6eef242 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#15 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#16 0xb6eef16c in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#17 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#18 0xb6eef16c in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#19 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#20 0xb6eef16c in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#21 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#22 0xb6eef16c in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#23 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#24 0xb6eef16c in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#25 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#26 0xb6eef16c in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#27 0xb6eef242 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#28 0xb6ef063c in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#29 0xb6ef07a3 in PyEval_EvalCode () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#30 0xb6f588d5 in PyRun_FileExFlags () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#31 0x087c9644 in CPythonInvoker::executeScript(void*, std:tring const&, void*, void*) ()
#32 0x087cb7d0 in CPythonInvoker::execute(std:tring const&, std::vector<std:tring, std::allocator<std:tring> > const&) ()
#33 0x087b5353 in ILanguageInvoker::Execute(std:tring const&, std::vector<std:tring, std::allocator<std:tring> > const&) ()
#34 0x087cc62e in CPythonInvoker::Execute(std:tring const&, std::vector<std:tring, std::allocator<std:tring> > const&) ()
#35 0x087b4d4e in CLanguageInvokerThread:rocess() ()
#36 0x097aef85 in CThread::Action() ()
#37 0x097af69d in CThread:taticThread(void*) ()
#38 0xb72d2f70 in start_thread (arg=0xa5967b40) at pthread_create.c:312
#39 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 20 (Thread 0x9cbf4b40 (LWP 3333)):
#1 0xb5f53826 in nanosleep () at ../sysdeps/unix/syscall-template.S:81
#2 0xb5f8288d in usleep (useconds=100000) at ../sysdeps/unix/sysv/linux/usleep.c:32
#3 0x08b7ce05 in Sleep(unsigned int) ()
#4 0x087cbc54 in CPythonInvoker::execute(std:tring const&, std::vector<std:tring, std::allocator<std:tring> > const&) ()
#5 0x087b5353 in ILanguageInvoker::Execute(std:tring const&, std::vector<std:tring, std::allocator<std:tring> > const&) ()
#6 0x087cc62e in CPythonInvoker::Execute(std:tring const&, std::vector<std:tring, std::allocator<std:tring> > const&) ()
#7 0x087b4d4e in CLanguageInvokerThread:rocess() ()
#8 0x097aef85 in CThread::Action() ()
#9 0x097af69d in CThread:taticThread(void*) ()
#10 0xb72d2f70 in start_thread (arg=0x9cbf4b40) at pthread_create.c:312
#11 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 19 (Thread 0xb02fdb40 (LWP 3310)):
#2 0x097446a8 in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#3 0x09744780 in PERIPHERALS::CPeripheralBusUSB:rocess() ()
#4 0x097aef85 in CThread::Action() ()
#5 0x097af69d in CThread:taticThread(void*) ()
#6 0xb72d2f70 in start_thread (arg=0xb02fdb40) at pthread_create.c:312
Thread 18 (Thread 0x9ebf8b40 (LWP 3327)):
#2 0x08b930db in JSONRPC::CTCPServer:rocess() ()
#3 0x097aef85 in CThread::Action() ()
#4 0x097af69d in CThread:taticThread(void*) ()
#5 0xb72d2f70 in start_thread (arg=0x9ebf8b40) at pthread_create.c:312
#6 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 17 (Thread 0xa03fbb40 (LWP 3324)):
#3 0x08ae7272 in PLT_ThreadTask::IsAborting(int) ()
#4 0x09774283 in PLT_CtrlPointHouseKeepingTask:oRun() ()
#5 0x08ae9060 in PLT_ThreadTask::Run() ()
#6 0x08ad4f92 in NPT_PosixThread::Run() ()
#7 0x08ad54f6 in NPT_PosixThread::EntryPoint(void*) ()
#8 0xb72d2f70 in start_thread (arg=0xa03fbb40) at pthread_create.c:312
Thread 16 (Thread 0xa0bfcb40 (LWP 3323)):
#2 0x08ad1b42 in NPT_BsdSocketFd::WaitForCondition(bool, bool, bool, int) ()
#3 0x08ad3b1d in NPT_BsdTcpServerSocket::WaitForNewClient(NPT_Socket*&, int, unsigned int) ()
#4 0x08ad455a in NPT_TcpServerSocket::WaitForNewClient(NPT_Socket*&, int, unsigned int) ()
#5 0x0977cb9b in PLT_HttpListenTask:oRun() ()
#6 0x08ae9060 in PLT_ThreadTask::Run() ()
#7 0x08ad4f92 in NPT_PosixThread::Run() ()
#8 0x08ad54f6 in NPT_PosixThread::EntryPoint(void*) ()
#9 0xb72d2f70 in start_thread (arg=0xa0bfcb40) at pthread_create.c:312
#10 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 15 (Thread 0x9f3f9b40 (LWP 3326)):
#2 0x08b90b11 in SOCKETS::CSocketListener::Listen(int) ()
#3 0x08b855c8 in EVENTSERVER::CEventServer::Run() ()
#4 0x08b85b50 in EVENTSERVER::CEventServer:rocess() ()
#5 0x097aef85 in CThread::Action() ()
#6 0x097af69d in CThread:taticThread(void*) ()
#7 0xb72d2f70 in start_thread (arg=0x9f3f9b40) at pthread_create.c:312
#8 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 14 (Thread 0x9fbfab40 (LWP 3325)):
#3 0x08ad202a in NPT_BsdSocketFd::WaitUntilReadable() ()
#4 0x08ad2573 in NPT_BsdUdpSocket::Receive(NPT_DataBuffer&, NPT_SocketAddress*) ()
#5 0x08ad4402 in NPT_UdpSocket::Receive(NPT_DataBuffer&, NPT_SocketAddress*) ()
#6 0x0979aaf0 in PLT_InputDatagramStream::Read(void*, unsigned int, unsigned int*) ()
#7 0x08aed166 in NPT_BufferedInputStream::FillBuffer() ()
#8 0x08aecdf0 in NPT_BufferedInputStream::ReadLine(char*, unsigned int, unsigned int*, bool) ()
#9 0x08aed3a0 in NPT_BufferedInputStream::ReadLine(NPT_String&, unsigned int, bool) ()
#10 0x08abaa49 in NPT_HttpResponse:arse(NPT_BufferedInputStream&, NPT_HttpResponse*&) ()
#11 0x08ac0fa7 in NPT_HttpClient::ReadResponse(NPT_Reference<NPT_InputStream>&, bool, bool, NPT_HttpResponse*&, NPT_Reference<NPT_HttpClient::Connection>*) ()
#12 0x0977f34f in PLT_SsdpSearchTask:oRun() ()
#13 0x08ae9060 in PLT_ThreadTask::Run() ()
#14 0x08ad4f92 in NPT_PosixThread::Run() ()
#15 0x08ad54f6 in NPT_PosixThread::EntryPoint(void*) ()
#16 0xb72d2f70 in start_thread (arg=0x9fbfab40) at pthread_create.c:312
#17 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 13 (Thread 0xa13fdb40 (LWP 3322)):
#10 0x08aba286 in NPT_HttpRequest:arse(NPT_BufferedInputStream&, NPT_SocketAddress const*, NPT_HttpRequest*&) ()
#11 0x0977d413 in PLT_HttpServerSocketTask::Read(NPT_Reference<NPT_BufferedInputStream>&, NPT_HttpRequest*&, NPT_HttpRequestContext*) ()
#12 0x0977d039 in PLT_HttpServerSocketTask:oRun() ()
#16 0xb72d2f70 in start_thread (arg=0xa13fdb40) at pthread_create.c:312
Thread 12 (Thread 0xa23ffb40 (LWP 3320)):
#2 0xb7685819 in ?? () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#3 0xb768528c in avahi_simple_poll_run () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#4 0xb76854e8 in avahi_simple_poll_iterate () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#5 0xb7685790 in avahi_simple_poll_loop () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#6 0xb7685884 in ?? () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#7 0xb72d2f70 in start_thread (arg=0xa23ffb40) at pthread_create.c:312
Thread 11 (Thread 0xa1bfeb40 (LWP 3321)):
#2 0x08bf2b66 in CJobManager::GetNextJob(CJobWorker const*) ()
#3 0x08bf2e9b in CJobWorker:rocess() ()
#6 0xb72d2f70 in start_thread (arg=0xa1bfeb40) at pthread_create.c:312
Thread 10 (Thread 0xa5166b40 (LWP 3317)):
#6 0xb72d2f70 in start_thread (arg=0xa5166b40) at pthread_create.c:312
Thread 9 (Thread 0xafafcb40 (LWP 3311)):
#2 0x097adaa4 in XbmcThreads::CEventGroup::wait(unsigned int) ()
#3 0x08b3276d in CRemoteControl:rocess() ()
#6 0xb72d2f70 in start_thread (arg=0xafafcb40) at pthread_create.c:312
Thread 8 (Thread 0xaf067b40 (LWP 3314)):
#2 0x097af527 in CThread::Sleep(unsigned int) ()
#3 0x08998ae7 in MEDIA_DETECT::CDetectDVDMedia:rocess() ()
#6 0xb72d2f70 in start_thread (arg=0xaf067b40) at pthread_create.c:312
Thread 7 (Thread 0xb0afeb40 (LWP 3309)):
#2 0x097466d0 in PERIPHERALS::CPeripheralBus:rocess() ()
#5 0xb72d2f70 in start_thread (arg=0xb0afeb40) at pthread_create.c:312
Thread 6 (Thread 0xb12ffb40 (LWP 3308)):
#2 0xb1473404 in CEC::CCECClient:rocess() () from /usr/lib/i386-linux-gnu/libcec.so.3.0
#3 0xb1477b89 in PLATFORM::CThread::ThreadHandler(void*) () from /usr/lib/i386-linux-gnu/libcec.so.3.0
#4 0xb72d2f70 in start_thread (arg=0xb12ffb40) at pthread_create.c:312
#5 0xb5f89bee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 5 (Thread 0xae628b40 (LWP 3305)):
#2 0x0861ccc0 in ActiveAE::CActiveAE:rocess() ()
#5 0xb72d2f70 in start_thread (arg=0xae628b40) at pthread_create.c:312
Thread 4 (Thread 0xb2630b40 (LWP 3306)):
#1 0xb72d6d1d in pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/i386/i686/../i486/pthread_cond_wait.S:145
#2 0xb35e885b in pa_cond_wait () from /usr/lib/i386-linux-gnu/pulseaudio/libpulsecommon-4.0.so
#3 0xb668034e in pa_threaded_mainloop_wait () from /usr/lib/i386-linux-gnu/libpulse.so.0
#4 0x0863f746 in CAESinkPULSE::AddPackets(unsigned char**, unsigned int, unsigned int) ()
#5 0x08620c97 in ActiveAE::CActiveAESink::OutputSamples(ActiveAE::CSampleBuffer*) ()
#6 0x086220c0 in ActiveAE::CActiveAESink::StateMachine(int, Actor:rotocol*, Actor::Message*) ()
#7 0x08622b42 in ActiveAE::CActiveAESink:rocess() ()
#10 0xb72d2f70 in start_thread (arg=0xb2630b40) at pthread_create.c:312
Thread 3 (Thread 0xa417bb40 (LWP 3352)):
#3 0x089494a6 in PVR::CPVRGUIInfo:rocess() ()
#6 0xb72d2f70 in start_thread (arg=0xa417bb40) at pthread_create.c:312
Thread 2 (Thread 0x9d3f5b40 (LWP 3350)):
#3 0x08c9befc in PVR::CPVRClients:rocess() ()
#6 0xb72d2f70 in start_thread (arg=0x9d3f5b40) at pthread_create.c:312
Thread 1 (Thread 0xa3190b40 (LWP 3349)):
#1 0x0868a94b in dbiplus::SqliteDataset::make_query(std::list<std:tring, std::allocator<std:tring> >&) ()
#2 0x086873fd in dbiplus::SqliteDataset::make_insert() ()
#3 0x0867b59f in dbiplus:ataset::post() ()
#4 0x0867180a in CDatabase::CommitInsertQueries() ()
#5 0x086d5219 in EPG::CEpgDatabase:ersist(std::map<unsigned int, EPG::CEpg*, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, EPG::CEpg*> > > const&) ()
#6 0x086ce8e0 in EPG::CEpgContainer:ersistTables() ()
#7 0x08916ef4 in PVR::CPVRChannelGroupInternal::CreateChannelEpgs(bool) ()
#8 0x089180d8 in PVR::CPVRChannelGroups::CreateChannelEpgs() ()
#9 0x0891ceef in PVR::CPVRChannelGroupsContainer::CreateChannelEpgs() ()
#10 0x08935ecc in PVR::CPVRManager::CreateChannelEpgs() ()
#11 0x08939dfc in PVR::CPVREpgsCreateJob:oWork() ()
#12 0x08936068 in PVR::CPVRManager::ExecutePendingJobs() ()
#13 0x0893afcf in PVR::CPVRManager:rocess() ()
#14 0x097aef85 in CThread::Action() ()
#15 0x097af69d in CThread:taticThread(void*) ()
#16 0xb72d2f70 in start_thread (arg=0xa3190b40) at pthread_create.c:312
############# END STACK TRACE ###############
################# LOG FILE ##################
07:00:05 T:2993039168 NOTICE: special://profile/ is mapped to: special://masterprofile/
07:00:05 T:2993039168 NOTICE: -----------------------------------------------------------------------
07:00:05 T:2993039168 NOTICE: Starting Kodi (15.1 Git:d496682). Platform: Linux x86 32-bit
07:00:05 T:2993039168 NOTICE: Using Release Kodi x32 build
07:00:05 T:2993039168 NOTICE: Kodi compiled Aug 16 2015 by GCC 4.8.4 for Linux x86 32-bit version 3.13.11 (199947)
07:00:05 T:2993039168 NOTICE: Running on Ubuntu 14.04.3 LTS, kernel: Linux x86 32-bit version 3.16.0-38-generic
07:00:05 T:2993039168 NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
07:00:05 T:2993039168 NOTICE: Host CPU: Pentium® Dual-Core CPU E5400 @ 2.70GHz, 2 cores available
07:00:05 T:2993039168 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
07:00:05 T:2993039168 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
07:00:05 T:2993039168 NOTICE: special://masterprofile/ is mapped to: /home/rami/.kodi/userdata
07:00:05 T:2993039168 NOTICE: special://home/ is mapped to: /home/rami/.kodi
07:00:05 T:2993039168 NOTICE: special://temp/ is mapped to: /home/rami/.kodi/temp
07:00:05 T:2993039168 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
07:00:05 T:2993039168 NOTICE: Local hostname: rami-System-Product-Name
07:00:05 T:2993039168 NOTICE: Log File is located: /home/rami/.kodi/temp/kodi.log
07:00:05 T:2993039168 NOTICE: load settings...
07:00:05 T:2993039168 NOTICE: Found 1 Lists of Devices
07:00:05 T:2993039168 NOTICE: Enumerated PULSE devices:
07:00:05 T:2993039168 NOTICE: Device 1
07:00:05 T:2993039168 NOTICE: m_deviceName : Default
07:00:05 T:2993039168 NOTICE: m_displayName : Default
07:00:05 T:2993039168 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
07:00:05 T:2993039168 NOTICE: m_deviceType : AE_DEVTYPE_PCM
07:00:05 T:2993039168 NOTICE: m_channels : FL,FR
07:00:05 T:2993039168 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
07:00:05 T:2993039168 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
07:00:05 T:2993039168 NOTICE: Device 2
07:00:05 T:2993039168 NOTICE: m_deviceName : alsa_output.pci-0000_00_1b.0.analog-stereo
07:00:05 T:2993039168 NOTICE: m_displayName : צליל פנימי סטראו אנלוגי
07:00:05 T:2993039168 NOTICE: m_displayNameExtra: פלט אנלוגי (PULSEAUDIO)
07:00:05 T:2993039168 NOTICE: Device 3
07:00:05 T:2993039168 NOTICE: m_deviceName : alsa_output.usb-Bel_Canto_Bel_Canto_2496_USB-00-USB.iec958-stereo
07:00:05 T:2993039168 NOTICE: m_displayName : 1.1 root hub סטראו דיגיטלי (IEC958)
07:00:05 T:2993039168 NOTICE: m_displayNameExtra: פלט דיגיטלי (S/PDIF) (PULSEAUDIO)
07:00:05 T:2993039168 NOTICE: Device 4
07:00:05 T:2993039168 NOTICE: m_deviceName : alsa_output.pci-0000_05_00.0.analog-stereo
07:00:05 T:2993039168 NOTICE: m_displayName : X-Fi Platinum סטראו אנלוגי
07:00:05 T:2993039168 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
07:00:05 T:2993039168 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
07:00:05 T:2993039168 NOTICE: Default DVD Player: dvdplayer
07:00:05 T:2993039168 NOTICE: Default Video Player: dvdplayer
07:00:05 T:2993039168 NOTICE: Default Audio Player: paplayer
07:00:05 T:2993039168 NOTICE: Disabled debug logging due to GUI setting. Level 0.
07:00:05 T:2993039168 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
07:00:05 T:2993039168 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
07:00:05 T:2993039168 NOTICE: Loaded playercorefactory configuration
07:00:05 T:2993039168 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
07:00:05 T:2993039168 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
07:00:05 T:2925693760 NOTICE: Thread ActiveAE start, auto delete: false
07:00:05 T:2992835392 NOTICE: Thread AESink start, auto delete: false
07:00:05 T:2992835392 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
07:00:05 T:2993039168 NOTICE: Running database version Addons19
07:00:05 T:2993039168 NOTICE: ADDONS: Using repository repository.xbmc.org
07:00:05 T:2993039168 NOTICE: ADDONS: Using repository repository.xbmc-israel
07:00:05 T:2964319040 NOTICE: Thread PeripBusCEC start, auto delete: false
07:00:05 T:2955926336 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
07:00:05 T:2947533632 NOTICE: Thread RemoteControl start, auto delete: false
07:00:05 T:2993039168 NOTICE: Setup SDL
07:00:05 T:2993039168 NOTICE: Checking resolution 15
07:00:05 T:2993039168 NOTICE: Using visual 0x28
07:00:05 T:2993039168 NOTICE: GL_VENDOR = NVIDIA Corporation
07:00:05 T:2993039168 NOTICE: GL_RENDERER = GeForce 9500 GT/PCIe/SSE2
07:00:05 T:2993039168 NOTICE: GL_VERSION = 3.3.0 NVIDIA 340.76
07:00:05 T:2993039168 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
07:00:05 T:2993039168 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 1048576
07:00:05 T:2993039168 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 1048576
07:00:05 T:2993039168 NOTICE: GL_EXTENSIONS = GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
07:00:05 T:2993039168 NOTICE: Running database version ViewModes6
07:00:05 T:2993039168 NOTICE: Running database version Textures13
07:00:05 T:2993039168 NOTICE: Running database version MyMusic52
07:00:05 T:2993039168 NOTICE: Running database version MyVideos93
07:00:05 T:2993039168 NOTICE: Running database version TV29
07:00:05 T:2993039168 NOTICE: Running database version Epg10
07:00:05 T:2993039168 NOTICE: start dvd mediatype detection
07:00:05 T:2936437568 NOTICE: Thread DetectDVDMedia start, auto delete: false
07:00:05 T:2993039168 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
07:00:05 T:2993039168 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
07:00:05 T:2993039168 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
07:00:05 T:2993039168 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
07:00:05 T:2993039168 NOTICE: initialize done
07:00:05 T:2993039168 NOTICE: Running the application...
07:00:05 T:2786495296 NOTICE: Thread LanguageInvoker start, auto delete: false
07:00:05 T:2769709888 NOTICE: Thread JobWorker start, auto delete: true
07:00:05 T:2778102592 NOTICE: Thread LanguageInvoker start, auto delete: false
07:00:05 T:2769709888 NOTICE: PVRManager - starting up
07:00:05 T:2753018688 NOTICE: Thread PVRManager start, auto delete: false
07:00:05 T:2736327488 NOTICE: Thread PVRClient start, auto delete: false
07:00:05 T:2736327488 NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 1054 channels.
07:00:05 T:2993039168 NOTICE: starting zeroconf publishing
07:00:05 T:2993039168 NOTICE: starting upnp client
07:00:05 T:2713709376 NOTICE: Thread JobWorker start, auto delete: true
07:00:05 T:2993039168 NOTICE: ES: Starting event server
07:00:05 T:2663353152 NOTICE: Thread TCPServer start, auto delete: false
07:00:05 T:2671745856 NOTICE: Thread EventServer start, auto delete: false
07:00:05 T:2671745856 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
07:00:05 T:2671745856 NOTICE: UDP: Listening on port 9777
07:00:05 T:2936310592 NOTICE: Thread RSSReader start, auto delete: false
07:00:06 T:2786495296 NOTICE: -->Python Interpreter Initialized<--
07:00:06 T:2646567744 NOTICE: Previous line repeats 1 times.
07:00:06 T:2646567744 NOTICE: Thread LanguageInvoker start, auto delete: false
07:00:06 T:2629782336 NOTICE: Previous line repeats 2 times.
07:00:06 T:2629782336 NOTICE: -->Python Interpreter Initialized<--
07:00:06 T:2629782336 WARNING: CPythonInvoker(3): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
07:00:06 T:2646567744 NOTICE: -->Python Interpreter Initialized<--
07:00:06 T:2646567744 WARNING: CPythonInvoker(2): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
07:00:06 T:2778102592 NOTICE: -->Python Interpreter Initialized<--
07:00:06 T:2778102592 WARNING: CPythonInvoker(4): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
07:00:07 T:2629782336 NOTICE: Livestreamer: Server Starts - localhost:65007
07:00:08 T:2638175040 NOTICE: Thread BackgroundLoader start, auto delete: false
07:00:08 T:2638175040 NOTICE: Thread PVRGUIInfo start, auto delete: false
07:00:15 T:2786495296 NOTICE: Thread EPGUpdater start, auto delete: false
07:00:15 T:2753018688 NOTICE: Start - EPG thread started
07:00:16 T:2786495296 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
07:00:17 T:2786495296 WARNING: EPG - UpdateFromScraper - channel not found, can't update
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'AKA'
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'MBC4'
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'MBC2'
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'MBC MAX'
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'Planet POP'
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'NOW THATS WHAT I CALL MUSIC'
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'MBC3'
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'Fox Movies'
07:00:17 T:2786495296 ERROR: EPG - Update - failed to update table 'CLUBLAND'
07:00:26 T:2993039168 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
07:00:26 T:2993039168 ERROR: Texture manager unable to load image from memory
07:00:26 T:2713709376 NOTICE: PVRManager - stopping
07:00:26 T:2713709376 NOTICE: PVRManager - starting up
07:00:26 T:2736327488 NOTICE: Thread PVRManager start, auto delete: false
07:00:26 T:2638175040 NOTICE: Thread PVRClient start, auto delete: false
07:00:26 T:2638175040 NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 1054 channels.
07:00:27 T:2993039168 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
07:00:27 T:2993039168 ERROR: Texture manager unable to load image from memory
07:00:31 T:2753018688 NOTICE: Thread PVRGUIInfo start, auto delete: false
07:00:31 T:2786495296 NOTICE: Thread EPGUpdater start, auto delete: false
07:00:31 T:2736327488 NOTICE: Start - EPG thread started
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
Pages: 1 2
