Full Version: V14.2
I updated ouya to 15.1 but now know there are issues with this version, can I download my previous kodi 14.2? Thank you
Yes. Old versions are still available on the download page: http://kodi.tv/download/
if possible could you type out a step by step guide for me, i'm useless at this but if you can help i will donate, thank you Ned
Try this.
HOW-TO:Install_Kodi_for_Android (wiki)
I will PM you with details of where to send me your donation, lol.
I give up, i should never have reset it. I have XBMC now but Fusion won't connect to server for some reason. What other platforms can i use that allow me to stream via wifi? Thanks
(2015-08-22, 15:51)jw8174 Wrote: [ -> ]I give up, i should never have reset it. I have XBMC now but Fusion won't connect to server for some reason. What other platforms can i use that allow me to stream via wifi? Thanks
Doesn't look like I am going to get rich anytime soon. I suggest the following:
1. Read the forum's rules.
2. Don't ask about banned repositories.
3. Don't try and stream via WiFi, use an Ethernet cable or powerline adapters to connect your router to your box.
