Full Version: MythTV Frontend Wrong Channel Listing
I have the myth backend setup and capturing the video from my HDHomerun Prime. I can watch TV and everything appears normal except the channel listing. I have subscribed to SD and have the correct listing from SD and I see the channel listing correctly on the backend of the MythTV setup gui. When using the MythTV PVR (frontend) the guide listing shows up in a completely different order. Any ideas why the backend is correct and the frontend is not? Please help!
This is a kodi option
Goto System>Settings>TV>General
(TV might be LiveTV, depending on your version of kodi)
and make sure "Use channel numbers from backend" is selected, then restart kodi
Note Settings Level must be set to Advanced or Expert to see the option "Use channel numbers from backend"
Mike
Thank you! Why does the client not do this by default?
