Full Version: sbs on demand and sbs catchup tv not working
07:48:41 T:140679078696704 NOTICE: -->Python Interpreter Initialized<--
07:48:41 T:140679078696704 NOTICE: getting: http://www.sbs.com.au/ondemand/js/video-menu
07:48:41 T:140679078696704 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: Extra data: line 1 column 31 - line 278 column 1 (char 30 - 32413)
File "/home/derek/.kodi/addons/plugin.video.sbsondemand/default.py", line 16, in <module>
SCRAPER = resources.scraper.MenuItems()
File "/home/derek/.kodi/addons/plugin.video.sbsondemand/resources/scraper.py", line 44, in __init__
self.main = orderedjson.loads(self.main_txt)
File "/home/derek/.kodi/addons/plugin.video.sbsondemand/resources/orderedjson/__init__.py", line 63, in loads
return json.loads(*args, **kwargs)
File "/usr/lib/python2.7/json/__init__.py", line 351, in loads
return cls(encoding=encoding, **kw).decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 369, in decode
raise ValueError(errmsg("Extra data", s, end, len(s)))
ValueError: Extra data: line 1 column 31 - line 278 column 1 (char 30 - 32413)
07:48:41 T:140679899109312 ERROR: GetDirectory - Error getting plugin://plugin.video.sbsondemand/
07:48:41 T:140679899109312 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.sbsondemand/) failed
07:48:41 T:140679078696704 NOTICE: Thread BackgroundLoader start, auto delete: false
07:51:53 T:140677509781248 NOTICE: Thread JobWorker start, auto delete: true
07:55:54 T:140676813010688 NOTICE: Previous line repeats 1 times.
07:55:54 T:140676813010688 NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:54 T:140676813010688 NOTICE: -->Python Interpreter Initialized<--
07:55:54 T:140676813010688 NOTICE: menulist
07:55:54 T:140676813010688 NOTICE: Thread BackgroundLoader start, auto delete: false
07:56:05 T:140676813010688 NOTICE: Thread LanguageInvoker start, auto delete: false
07:56:05 T:140676813010688 NOTICE: -->Python Interpreter Initialized<--
07:56:05 T:140676813010688 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'group'
File "/home/derek/.kodi/addons/plugin.video.catchuptv.au.sbs/addon.py", line 28, in <module>
plugin.Main()
File "/home/derek/.kodi/addons/plugin.video.catchuptv.au.sbs/resources/lib/menu.py", line 14, in __init__
if len(m.group(1)) == 0: raise
AttributeError: 'NoneType' object has no attribute 'group'
07:56:05 T:140679899109312 ERROR: GetDirectory - Error getting plugin://plugin.video.catchuptv.au.sbs/?menuId=default
07:56:05 T:140679899109312 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.catchuptv.au.sbs/?menuId=default) failed
07:56:05 T:140676813010688 NOTICE: menulist
07:56:05 T:140676813010688 NOTICE: Thread BackgroundLoader start, auto delete: false
The errors seem different but, the result is the same.
Any ideas on where the problem lies.
Hi
have a look here http://forum.kodi.tv/showthread.php?tid=125746&page=12
you will have a better chance of a reply and/or finding a solution...The sbs plugin gets broken all the time, Ive found it easier to use chrome browser and the web interface, though you do end up with adds it works 95% of the time
