2015-08-23, 00:45
I'm a new user running Isengard, Windows 10. I added USTVNow and I get an error when it launches. I checked the log:
16:28:58 T:7760 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named pyxbmctmanager.window
File "C:\Users\Dad\AppData\Roaming\Kodi\addons\plugin.video.ustvnow.tva\setup.py", line 130, in <module>
Setup()
File "C:\Users\Dad\AppData\Roaming\Kodi\addons\plugin.video.ustvnow.tva\setup.py", line 18, in Setup
from pyxbmctmanager.window import Window
ImportError: No module named pyxbmctmanager.window
It looks like there was an error in setup.py, line 18 (last line below):
import os
import sys
import xbmc
import xbmcaddon
import xbmcgui
addon = xbmcaddon.Addon()
addonname = addon.getAddonInfo('name')
addonid = addon.getAddonInfo('id')
root = addon.getAddonInfo('path')
settings = os.path.join(xbmc.translatePath( root ), 'resources/settings.xml')
def Setup():
sys.path.append(os.path.join(xbmc.translatePath( "special://home/addons/script.module.beautifulsoup/" ), 'lib'))
sys.path.append(os.path.join(xbmc.translatePath( "special://home/addons/script.module.pyxbmct/" ), 'lib'))
sys.path.append(os.path.join(xbmc.translatePath( "special://home/addons/script.module.pyxbmctmanager/" ), 'lib'))
from resources.lib import ustvnow
So I'm missing the pyxbmctmanager module/sub-module?
Help please!
Setup()
import os
import sys
import xbmc
import xbmcaddon
import xbmcgui
def Setup():
Help please!
