Full Version: custom internet radio on kodi
Hey all,
So the wife and I basically live on http://www.hit107.com/listen/ and I would LOVE to add this to kodi, I have done some reading on this and have tried.
create txt document put http://www.hit107.com/listen/ in it save it as hit107.strm open it in kodi but I am getting.
13:47:56 T:96904 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, http://www.hit107.com/listen/
13:47:56 T:96904 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
13:47:56 T:96904 NOTICE: CDVDPlayer::OnExit()
13:47:56 T:102612 DEBUG: Thread FileCache 102612 terminating
13:47:56 T:96904 DEBUG: CApplication::OnPlayBackStopped: play state was 1, starting 1
13:47:56 T:96904 DEBUG: Thread DVDPlayer 96904 terminating
13:47:56 T:101380 DEBUG: CApplication::OnPlayBackStopped: play state was 3, starting 0
13:47:56 T:101380 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
13:47:56 T:101380 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
13:47:56 T:101380 ERROR: Playlist Player: skipping unplayable item: 0, path [http://www.hit107.com/listen/]
13:47:56 T:101380 DEBUG: Playlist Player: one or more items failed to play... aborting playback
13:47:56 T:101380 DEBUG: ------ Window Init (DialogOK.xml) ------
13:47:56 T:101380 NOTICE: CDVDPlayer::CloseFile()
13:47:56 T:101380 NOTICE: DVDPlayer: waiting for threads to exit
13:47:56 T:101380 NOTICE: DVDPlayer: finished waiting
I have a feeling its because the <http://www.hit107.com/listen/> is not the right link or something with adobe im not to sure.. Hopefully someone can give me a hand here....
I did have it running with XBMC about a year ago but have completely forgot how I got it going
thanks everyone
anyone got any ideas?
If you had it working previously, then you need to examine the set-up and .strm files and see if the path is still the same. I believe there is quite a few older threads and forums on this subject to help you out, the trick is finding the proper URL and path as most of these links dry up quickly. Internet video and audio streams (wiki) Search using Google prefaced with the words Kodi Live Streaming.
Hey all so I have figured out how to get this working... in google chrome I did CTRL + SHIFT + C and searched through there till I found http://wms2.scahw.com.au/live/safm.stream/playlist.m3u8 open notepad paste the link in there save it, rename to filename.strm add it into KODI in music and it works Smile
