Full Version: Movie list position value?
Hi
I'm looking if theres a boolean condition to display the position value of a movie while browsing down the list.
E.g. if i have 400 movies. would like it to show 137/400 when im on the 137th movie down the list.
I'm using $info[window(0).property(movies.count)] for movies count
Not sure on code for position. I'm using wraplist.
Thanks for any info Smile
Container(id).CurrentItem
(2015-08-25, 16:56)Hitcher Wrote: [ -> ]Container(id).CurrentItem
Thanks Hitcher Smile
You can also use this instead of your current item info you mentioned before:
Container().NumItems
(Dont fill the id, leave it blank)
so something like:
$INFO[Container().CurrentItem] / $INFO[Container().NumItems]
Will be more global and will work in every screen (pvr,movies,addons etc..)
