Full Version: Shutdown in main menu
I was searching for an option to bring a shutdown (Kodi) button or Menu to the main menu in the refocus skin. But i can't found this option. Is there an option for this or ecxiste a addon for it?
Please can you help me, thanks
Looks
Simply add a menu entry and select a shortcut from "Kodi Command".
You should be able to select individual shutdown options, or set it to open the shutdown menu (the first "Quit" entry, which should set "ActivateWindow(shutdownmenu)" into the "Action" field).
