Full Version: Multi fanart background based on playlist
Hi, I'm trying to make the background in Ace's main menu randomizes based on its playlist..
e.g
Action Playlist, background randomizes from Action movies backdrops...
After some googling i found this :
223529 (thread)
So.. i tried it for Ace, but it doesn't seem to be working, it gave me black screen in background..
guisettings.xml
<setting type="string" name="skin.ace.vpl1.MultiFanart">special://profile/playlists/video/Barat.xsp</setting>
IncludesVIPmenu.xml
<item id="31">
            <!-- Vpl 1 -->
            <label>FILM BARAT</label>
            <label2>West Movie</label2>
            <icon>special://skin/backgrounds/vplaylist.jpg</icon>
            <thumb>$INFO[Skin.String(vpl1.MultiFanart)]</thumb>
            <onclick>Skin.SetBool(playlists)</onclick>
            <onclick>Skin.SetString(playlist,v1)</onclick>
            <onclick condition="Container(9000).HasFocus(31) + SubString(skin.string(mfvpl1_list),latest)">ActivateWindow(videolibrary,$INFO[skin.string(vpl1.path)],return)</onclick>
            <onclick condition="Container(9000).HasFocus(31) + SubString(skin.string(mfvpl1_list),random)">ActivateWindow(videolibrary,$INFO[skin.string(vpl1a.path)],return)</onclick>
            <property name="dropdown">not_empty</property>
            <property name="widget">Playlist</property>
            <property name="widget2">Playlist2</property>
            <property name="widgetPlaylist">C:/Users/Downloader/AppData/Roaming/Kodi/userdata/playlists/video/Barat.xsp</property>
            <property name="widgetPlaylist2">C:/Users/Downloader/AppData/Roaming/Kodi/userdata/playlists/video/Recommended_Barat.xsp</property>
            <visible>!IsEmpty(skin.string(vpl1))</visible>
        </item>
Is there anything else that i need to get this to work?
The thread mentioned script playlist but i can't find such script
thanks
make a hidden list with <content> that contain your playlist, give it an ID. and set autoscroll for it, so the list will move from one item to another....
then in your multiimage control set the path for that list.
see here for more info:
https://github.com/sualfred/Bello-Kodi-1...18958b3f99
(2015-08-29, 10:15)tomer953 Wrote: [ -> ]make a hidden list with <content> that contain your playlist, give it an ID. and set autoscroll for it, so the list will move from one item to another....
Thanks, will give it a try,
Is it heavy on resources though?
I'm aiming for lightest version of my custom skins.. if it's too heavy i might just skip it..
the more lists are loaded the slower the skin, but afaik one hidden list won't effect so much... Im loading about dozens scripts,widgets and services when my skin is loading, and it take 2-5 seconds... so..
