Full Version: Ubuntu 14 and RTMP librtmp.so.1
Good Morning all,
Can anyone tell me why kodi isengard in Ubuntu 14 refuses to play RTMP streams. I have the ubuntu restricted extras and flash installed. Im thinking that maybe... the librtmp.so.0 needs to be updated but not sure. Any guidance please, thanks community
extracts from the log file
10:02:51 T:139723437090752  NOTICE: Starting Kodi (15.1 Git:d496682). Platform: Linux x86 64-bit
10:02:51 T:139723437090752  NOTICE: Using Release Kodi x64 build
10:02:51 T:139723437090752  NOTICE: Kodi compiled Aug 16 2015 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
10:02:51 T:139723437090752  NOTICE: Running on Ubuntu 14.04.3 LTS, kernel: Linux x86 64-bit version 3.19.0-25-generic
10:02:51 T:139723437090752  NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
10:02:51 T:139723437090752  NOTICE: Host CPU: Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz, 4 cores available
10:06:35 T:139723437090752 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
10:06:35 T:139722711594752  NOTICE: Thread DVDPlayer start, auto delete: false
10:06:35 T:139722711594752  NOTICE: Creating InputStream
10:06:35 T:139722711594752   ERROR: Unable to load librtmp.so.1, reason: librtmp.so.1: cannot open shared object file: No such file or directory
sudo apt-get dist-upgrade should fix it. If not install librtmp1 manually.
Take care of illegal streams.
Hi there fritsch,
i have done that and got this -
usuario@usuario-Aspire-5742G:~$ sudo apt-get dist-upgrade
[sudo] password for usuario:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  gnome-video-effects
Use 'apt-get autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
is this the expected result?
if not, could you please explain how to install librtmp1 manually. thanks for your help
i took a leap of faith and did this
sudo apt-get install librtmp1
this was the result
usuario@usuario-Aspire-5742G:~$ sudo apt-get install librtmp1
  gnome-video-effects
The following NEW packages will be installed:
  librtmp1
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 54,0 kB of archives.
After this operation, 155 kB of additional disk space will be used.
Get:1 http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ trusty/main librtmp1 amd64 2.4+20150114.gita107cef9b~trusty [54,0 kB]
Fetched 54,0 kB in 0s (98,5 kB/s)
Selecting previously unselected package librtmp1:amd64.
(Reading database ... 212408 files and directories currently installed.)
Preparing to unpack .../librtmp1_2.4+20150114.gita107cef9b~trusty_amd64.deb ...
Unpacking librtmp1:amd64 (2.4+20150114.gita107cef9b~trusty) ...
Setting up librtmp1:amd64 (2.4+20150114.gita107cef9b~trusty) ...
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
Hopefully that has done it.
Yeah, that's it.
Great - fixed it for me after days of searching
Hallo, this is my result : (sorry about Polish lang.) :
[sudo] hasło użytkownika aleksander:
Czytanie list pakietów... Gotowe
Budowanie drzewa zależności
Odczyt informacji o stanie... Gotowe
librtmp1 is already the newest version (2.4+20151223.gitfa8646d-1build1).
Następujące pakiety zostały zainstalowane automatycznie i nie są już więcej wymagane:
fonts-roboto fonts-roboto-hinted libavfilter-ffmpeg5 libavformat-ffmpeg56
libavresample-ffmpeg2 libbs2b0 libcec-platform1v5 libflite1 libfstrcmp0
libgme0 libhdhomerun2 libjs-iscroll libmodplug1 libmpeg2-4
libopencv-core2.4v5 libopencv-imgproc2.4v5 libpango1.0-0 libpangox-1.0-0
libpostproc-ffmpeg53 libsdl2-2.0-0 libsndio6.1 libsodium18 libssh-gcrypt-4
libswscale-ffmpeg3 libtbb2 libzmq5
Aby je usunąć należy użyć "sudo apt autoremove".
0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 1 nieaktualizowanych.
The most important is : librtmp1 is already the newest version (2.4+20151223.gitfa8646d-1build1)
and can make autoremove as well.
But for me Kodi is still not working (live streaming TV) and even if I find some channel that work - after buffering the whole screen stops as well as sound in a moment later.
I reinstalled Kodi several times, and diffrent versions, and at the end whole Linux Ubuntu but it didn't help.
Kodi don't produce A crash log, although this option is active in my Kodi.
This all is SOME FUC.... MESS Sad
Has anyone any ideas? Any help would be appreciated.
Best Regards,Aleksander.
