2015-08-29, 17:21
2015-08-29, 17:21
2015-08-29, 20:09
SYSTEM > Live TV > General. Disable it there
2015-09-02, 22:08
I have disabled it in SYSTEM > Live TV > General, but it still keeps showing up.
2015-09-03, 12:37
Make sure all your pvr clients are disabled and pvr manager is... Whatever that is never seen it before
2015-09-03, 14:52
I have no PVR clients, no PVR devices and no cable feed to supply said non-existent device. After I uninstalled and reinstalled Kodi, I do not see the issue any longer. I must have made a change somewhere in the past that caused this and eradicated it with a clean install.
2015-09-03, 15:26
just as a hint, as I read it very often....mostly there is no need of a fresh install. In most cases it's absolutely enough to remove the kodi folder....locations are:
windows: %appdata%\Kodi
linux: ~/.kodi
openelec: ~/storage/.kodi
if you remove this "kodi" folder, all settings and addons are gone. It's like a factory reset and a restart/reboot will create a new "Kodi" folder with plain settings. So there is no need of a fresh install.
linux: ~/.kodi
