looking to buy anG Box Q, but what do I buy to have it work as a pvr
?? I need to record my sports when I am not home. Please help. Thanks
So I can buy a tv tuner use stick??mcan I just use an external hard drive connected to the g box?? Thanks for your reply
I seriously doubt any backend Software will work with Android. OpenELEC/Linux yes. Not Android.
Backend Software needs to run on Windows or Linux.
If I buy a weetek play, will that solve my issue
That will connect to my tv and also record as a PVR??
If not...then what windows based box should I buy that will let me watch Jodi on my tv and also record like a dvr?? Thanks again for your help
Yes a Wetek Play would best suit your needs. Especially running OpenELEC. You will get great support as well which is the most important.
