Full Version: Enabling subtitles by default
This appears to have been broken for several versions but as I was on beta's I didn't bother to flag this, however I'm now 15.1 which is the current release version and I still can't enable subtitles and set that as default for all videos.
You can do it via the video OSD...
http://kodi.wiki/view/Video_playback
Look at point 3 "3 OSD audio and subtitle settings"
Do your settings and then hit "Set as default for all videos "
done
Doesn't work that's my point selecting it does nothing
post a Debug Log while playing a video and setting the subtitles, please
22:09:45 T:15580   DEBUG: ------ Window Init (VideoOSDSettings.xml) ------
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (audio.volume) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (audio.volumeamplification) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (audio.delay) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (audio.stream) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (audio.outputtoallspeakers) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (audio.digitalanalog) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (subtitles.enable) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (subtitles.delay) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (subtitles.stream) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (subtitles.browser) was not found.
22:09:45 T:15580   DEBUG: CSettingsManager: requested setting (audio.makedefault) was not found.
22:09:47 T:15580   DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
22:09:47 T:15580   DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
22:09:48 T:15580   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
22:09:48 T:15580   DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
22:09:50 T:15580   DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:09:50 T:15580   DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
22:09:51 T:15580   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
22:09:51 T:15580   DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
22:09:51 T:15580   DEBUG: ------ Window Init (DialogYesNo.xml) ------
22:09:52 T:15580   DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
22:09:52 T:15580   DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
22:09:53 T:15580   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
22:09:53 T:15580   DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
22:09:53 T:15580   DEBUG: ------ Window Deinit (DialogYesNo.xml) ------
22:09:53 T:15580    INFO: Deleting settings information for all files
22:09:54 T:2512   DEBUG: Thread JobWorker 2512 terminating (autodelete)
22:13:24 T:15580   DEBUG: CInputManager::ProcessMouse: unknown mouse command 57608
22:13:24 T:15580   DEBUG: CInputManager::ProcessMouse: unknown mouse command 57607
22:13:24 T:15580   DEBUG: Previous line repeats 3 times.
22:13:24 T:15580   DEBUG: CInputManager::ProcessMouse: trying mouse action Back
22:13:25 T:15580   DEBUG: ------ Window Deinit (VideoOSDSettings.xml) ------
22:13:26 T:15580   DEBUG: CInputManager::ProcessMouse: unknown mouse command 57608
22:13:27 T:15580   DEBUG: CInputManager::ProcessMouse: unknown mouse command 57607
22:13:27 T:15580   DEBUG: CInputManager::ProcessMouse: trying mouse action Back
22:13:27 T:15580   DEBUG: ------ Window Deinit (VideoOSD.xml) ------
22:13:29 T:15580   DEBUG: CInputManager::ProcessMouse: unknown mouse command 57608
22:13:29 T:15580   DEBUG: CInputManager::ProcessMouse: unknown mouse command 57607
22:13:29 T:15580   DEBUG: CInputManager::ProcessMouse: trying mouse action Back
22:13:29 T:15580   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
22:13:29 T:15580   DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
22:13:29 T:15580   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
22:13:29 T:15580   DEBUG: ------ Window Init (Home.xml) ------
22:13:30 T:13264 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
22:13:30 T:15580 WARNING: Previous line repeats 2 times.
22:13:30 T:15580   DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
22:13:30 T:15580   DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
22:13:30 T:15800  NOTICE: Thread JobWorker start, auto delete: true
22:13:31 T:13264   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
22:13:31 T:15580   DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
22:13:31 T:15580   DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
22:13:31 T:15580   DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
22:13:31 T:15580   DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
22:13:32 T:15580   DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
22:13:32 T:15580   DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
22:13:32 T:13264 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
22:13:33 T:13264 WARNING: Previous line repeats 2 times.
22:13:33 T:13264   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
22:13:33 T:15580   DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
22:13:33 T:15580   DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
22:13:34 T:15580   DEBUG: CInputManager::ProcessMouse: trying mouse action Select
22:13:34 T:15580   DEBUG: Activating window ID: 10004
22:13:34 T:13264 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
22:13:34 T:15580 WARNING: Previous line repeats 2 times.
22:13:34 T:15580   DEBUG: ------ Window Deinit (Home.xml) ------
22:13:34 T:15580   DEBUG: ------ Window Init (Settings.xml) ------
22:13:38 T:13264   DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
22:13:42 T:15580   DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
22:13:42 T:15580   DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
22:13:43 T:15580   DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
22:13:43 T:15580   DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
22:13:44 T:15580   DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
22:13:44 T:15580   DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
22:13:45 T:15580   DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
22:13:45 T:15580   DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
22:13:46 T:15580   DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:13:46 T:15580   DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
22:13:47 T:15580   DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:13:47 T:15580   DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
22:13:47 T:15580   DEBUG: CInputManager::ProcessMouse: trying mouse action Select
22:13:47 T:15580   DEBUG: Activating window ID: 10016
22:13:48 T:15580   DEBUG: ------ Window Deinit (Settings.xml) ------
22:13:48 T:15580   DEBUG: ------ Window Init (SettingsCategory.xml) ------
22:13:49 T:15580   DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:13:49 T:15580   DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
22:13:50 T:15580   DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:13:50 T:15580   DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
22:13:51 T:15580   DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
22:13:51 T:15580   DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
22:13:54 T:15580   DEBUG: CInputManager::ProcessMouse: trying mouse action Select
22:13:54 T:15580  NOTICE: Disabled debug logging due to GUI setting. Level 0.
Full log from boot please
I went digging around and found this (../userdata/guisettings.xml) which appears that the default setting is true, will give you full log shortly
<defaultvideosettings>
        <deinterlacemode>1</deinterlacemode>
        <interlacemethod>1</interlacemethod>
        <scalingmethod>1</scalingmethod>
        <noisereduction>0.000000</noisereduction>
        <postprocess>false</postprocess>
        <sharpness>0.000000</sharpness>
        <viewmode>0</viewmode>
        <zoomamount>1.000000</zoomamount>
        <pixelratio>1.000000</pixelratio>
        <verticalshift>0.000000</verticalshift>
        <volumeamplification>0.000000</volumeamplification>
        <outputtoallspeakers>false</outputtoallspeakers>
        <showsubtitles>true</showsubtitles>
        <brightness>50.000000</brightness>
        <contrast>50.000000</contrast>
        <gamma>20.000000</gamma>
        <audiodelay>0.000000</audiodelay>
        <subtitledelay>0.000000</subtitledelay>
        <nonlinstretch>false</nonlinstretch>
        <stereomode>0</stereomode>
    </defaultvideosettings>
I've had to post the log here due to it's size
http://xbmclogs.com/ps0c7vy0t#line-5
