(2021-01-14, 23:30)rafikW Wrote: [ -> ] (2021-01-14, 23:23)rafikW Wrote: [ -> ] (2021-01-14, 23:21)vdb86 Wrote: [ -> ]You need to disable weather information in screensaver settings.
It should work fine then.
I have it disabled already since the beginning when I start using your screensaver: Enable weather information checkbox is not enabled.
With that setting previous version of your screensaver was working properly.
What I did is: I have installed Weather add-on and enabled Weather Information in screensaver - now it works.
But anyway its easy to reproduce: uncheck Weather Information in screensaver while no Weather addon is installed and you get the error.
settings.xml:
<settings version="2">
<setting id="additionalinformation">true</setting>
<setting id="albumartshow">true</setting>
<setting id="ampmcolor" default="true">false</setting>
<setting id="ampmtr" default="true">false</setting>
<setting id="aspectratio" default="true">0</setting>
<setting id="backgroundchoice" default="true">0</setting>
<setting id="batterylevel" default="true">false</setting>
<setting id="colonblink">true</setting>
<setting id="coloncolor" default="true">false</setting>
<setting id="colontr" default="true">false</setting>
<setting id="combinesonginfo" default="true">false</setting>
<setting id="cputemp">true</setting>
<setting id="cpuusage">true</setting>
<setting id="cuptime" default="true">false</setting>
<setting id="customdateformat" default="true"></setting>
<setting id="customx">1</setting>
<setting id="customy">1</setting>
<setting id="datecolor" default="true">false</setting>
<setting id="dateformat">1</setting>
<setting id="datetr" default="true">false</setting>
<setting id="dimlevel">50</setting>
<setting id="file" default="true">images</setting>
<setting id="folder" default="true">images</setting>
<setting id="fps" default="true">false</setting>
<setting id="freememory" default="true">false</setting>
<setting id="gputemp" default="true">false</setting>
<setting id="hddtemp" default="true">false</setting>
<setting id="hourcolor" default="true">false</setting>
<setting id="hourtr" default="true">false</setting>
<setting id="iconcolor" default="true">false</setting>
<setting id="icontr" default="true">false</setting>
<setting id="imagetimer" default="true">0</setting>
<setting id="informationcolor" default="true">false</setting>
<setting id="informationtr" default="true">false</setting>
<setting id="infoswitch">5</setting>
<setting id="label0" default="true"></setting>
<setting id="label1" default="true"></setting>
<setting id="label14" default="true"></setting>
<setting id="label15" default="true"></setting>
<setting id="label16" default="true"></setting>
<setting id="label2" default="true"></setting>
<setting id="label3" default="true"></setting>
<setting id="label4" default="true"></setting>
<setting id="logout" default="true">false</setting>
<setting id="logoutplaying" default="true">false</setting>
<setting id="logouttime">10</setting>
<setting id="minutecolor" default="true">false</setting>
<setting id="minutetr" default="true">false</setting>
<setting id="movementspeed">0</setting>
<setting id="movementtype">1</setting>
<setting id="movies" default="true">false</setting>
<setting id="music" default="true">false</setting>
<setting id="nowplayinginfoshow">true</setting>
<setting id="randomimages" default="true">false</setting>
<setting id="rss" default="true">false</setting>
<setting id="showonlynowplaying" default="true">false</setting>
<setting id="skinhelper">3</setting>
<setting id="stayinplace">10</setting>
<setting id="timeformat" default="true">0</setting>
<setting id="tuptime" default="true">false</setting>
<setting id="tvshows" default="true">false</setting>
<setting id="weathericonformat">1</setting>
<setting id="weatherinfoshow" default="true">false</setting>
<setting id="zoomlevel" default="true">100</setting>
</settings>
