2022-06-15, 10:54
(2022-06-15, 10:25)DiMag Wrote: [ -> ]@vdb86
Feature Requests:
1. Make font (-)scaleable (reduceable by %).
It would help (a) improve looks and (b) reduce energy consumption. Plus it would be (I suppose) easy to implement since (+)scaleability is already a feature.
2. A more granular weather information:As long as these data are actually provided by the weather add-on in use and can be as easily exported to your add-on. (NOTE that "dew point" is the most scientifically accurate, and thus the only needed, measurement of humidity. Also note that in practice "temperature feels like" is never accurately measured/reported by weather stations, and is thus --in practice not theory-- redundant.)
- Wind direction.
- Temperature feels like.
- Dew point.
Other than that no other information is needed (although many are indeed provided). This is an excellent and very much essential add-on: the screensaver screen as a giant clock/weather panel.
Thank you for your message!
Both FRs are not possible, and let me provide the reasoning behind this:
- First of all, I'm not a developer, it's a miracle I managed to get this Screen Saver where it is today, I learned Python and how to use github on my own.
- Kodi is not really meant to have screensavers, screensavers are actually addons that are taking over your screen, and that whole implementation causes quite a few complications. Screensavers can't define their own fonts etc and rely completely on the current Skin and whatever data Kodi allows you to use.
- The weather information is received though InfoLabels:
Weather.Conditions Current weather conditions – this is looked up in a background process.
Weather.Temperature Current weather temperature
Weather.Location City/town which the above two items are for
Weather.fanartcode Current weather fanartcode.
Weather.plugin Current weather plugin.
As you can see the data you'd want is not available to the screensaver, the weather addon might have this data, but Kodi doesn't allow me to access it.
- The font can't be scalable as it would look completely broken if each part of the screensaver was separately scalable.
Right now I need to apply zoom (or scalability) to the whole package when the screensaver is started, doing it for each element is something that can be done, but then we end up in a problem where the package doesn't have a properly defined size, and this is a problem even with the current zoom, but it kinda works.
If you'd like to try developing these features by yourself and you manage to get something working well I'll gladly accept a pull request.
