2017-09-08, 17:57
2017-09-11, 10:22
(2017-09-08, 17:57)vdb86 Wrote: [ -> ]They changed font sizes, I'll have to get in touch with Sam and get them to put back the font sizes.
hi,
i have the same problem, only i use the new horizon skin: https://forum.kodi.tv/showthread.php?tid=317395
2017-09-11, 23:08
(2017-09-11, 10:22)fijasko Wrote: [ -> ](2017-09-08, 17:57)vdb86 Wrote: [ -> ]They changed font sizes, I'll have to get in touch with Sam and get them to put back the font sizes.
hi,
I'll provide support for that skin when it becomes available in the Kodi repo
2017-10-23, 11:14
(2017-09-11, 23:08)vdb86 Wrote: [ -> ](2017-09-11, 10:22)fijasko Wrote: [ -> ](2017-09-08, 17:57)vdb86 Wrote: [ -> ]They changed font sizes, I'll have to get in touch with Sam and get them to put back the font sizes.
hi,
The Horizon skin is now available in the Kodi repository.
Could you take a look please?
2017-10-28, 12:34
I'll look into it!
2017-10-31, 10:33
Hi vdb86,
I love your screensaver very much.
But after a new install with OpenElec 8.0.4 the size of the digits are too small.
And I miss the seconds! There is now only hours and minutes.
I cannot find the version 3.6.0, which I had use.
It is possible, that I had Openelec 7.0.1 before my actual installation but I forgot it. My system runs flawless for more than i year and I forgot the rule "Don't touch a running system". :-((
This is what I now have:
Could you upload the version 3.6.0?
2017-11-06, 17:49
(2017-10-23, 11:14)fijasko Wrote: [ -> ](2017-09-11, 23:08)vdb86 Wrote: [ -> ](2017-09-11, 10:22)fijasko Wrote: [ -> ]hi,
This is done, when you update you should have it working properly!
2017-11-06, 17:51
(2017-10-31, 10:33)miles59 Wrote: [ -> ]Hi vdb86,
Everything should be working fine even now, your current photo looks ok to me...
Maybe you need to adjust the zoom option?
Let me know if that fixed your issue.
2017-11-08, 13:45
Hello vdb86,
thanks for your reply.
The zoom option is set to 200%.
But for me it is too small.
My wishes for this Add-on:
- 400% would be cool.
[font='Open Sans', sans-serif]- And I miss the seconds. I don't find it in the time format section.
- The bouncing speed could be slower.
[/font]
I use this RasPi only for hearing music. While the music plays, on the display I use the "Spectrum" visualization of the Confluence skin.
If I do not do that, this modded Cube is the Clock for us near the TV. ;-)
So I don't need any additional information, but only a good readable Digital Clock.
Anyway - thank for you nice work. ;-)
[/font]
2017-11-08, 14:24
(2017-11-06, 17:49)vdb86 Wrote: [ -> ](2017-10-23, 11:14)fijasko Wrote: [ -> ](2017-09-11, 23:08)vdb86 Wrote: [ -> ]I'll provide support for that skin when it becomes available in the Kodi repo
Thank you, it's working now
2017-11-08, 14:55
(2017-11-08, 13:45)miles59 Wrote: [ -> ]Hello vdb86,
[/font]
Interesting.
Which skin are you using?
Let me know about your resolution as well.
Are you running the newest version of digital clock?
Unfortunately the 3.6.0 version can't be found any longer, at the same time I never supported the seconds, so you might be referring to some other addon which had a similar name.
Bouncing speed can be changed.
I limited the zoom to 200 since going above that looks very ugly on most of the systems.
2017-11-08, 18:59
Hi vdb86,
as you wrote, that there were never seconds, I knew, it must be another Add-on.
Finally, I found it here
Banned addon (wiki) repo link removed
I`m so sorry about my stupid questions.
Take care
Miles59
Take care
Miles59
2017-11-08, 19:03
Now it looks like this:
https://picload.org/view/draddlgw/cubeclock.jpg.html
2017-11-08, 19:03
(2017-11-08, 18:59)miles59 Wrote: [ -> ]As you wrote, that there were never seconds, I knew, it must be another Add-on.Please don't recommend anything from banned repositories... I'm sure the digital clock addon is available in other more legal repositories
Finally, I found it here:
2017-11-08, 20:12
Excuse me. Will not happen again.
