Full Version: Digital Clock Screensaver 6.0.4 (Update 16.8.2023)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Digital clock screensaver
I have stopped supporting Kodi 15 and 16, only Kodi 17+ will be supported.
You can find this screensaver in the official Kodi repo.
These are the options in settings:
Movement
- Movement on the screen (Random position, Bounce movement, Fixed in the center, Custom position)
- Bounce movement speed
- Number of seconds to stay in place (Number of seconds that the clock will stay in place before moving to a random location)
Format
- Time format (17:14, 05:14, 05:14 PM, 5:14 No hour zero padding Windows, 5:14 PM No hour zero padding Windows, 5:14 No hour zero padding Unix, 5:14 PM No hour zero padding Unix)
- Colon blink
- Date format (Hide date, Saturday 30. May 2015, 30.05.2015, 05.30.2015, Custom)
- Custom date format:
- Day: d(1-31) dd(01-31) ddd(Mon-Sun) DDD(Monday-Sunday)
- Month: m(1-12) mm(01-12) mmm(Jan-Dec) MMM(January-December)
- Year: yy(2-digit year) yyyy(4-digit year)
Additional Information
- Enable additional information
- Number of seconds for information switch (Number of seconds before the information will be switched with another one, i.e. Artist - Song - Weather information)
- Enable now playing information
- Combine song artist and title (Song artist - song title)
- Show only music information (If this is enabled and a song is playing, only song info will be shown)
- Enable album art
- Enable weather information
- Weather icons
- Enable CPU usage information
- Enable battery level information
- Enable free memory information
- CPU temperature (Depends on the system if it will work or not)
- GPU temperature (Depends on the system if it will work or not)
- HDD temperature (Depends on the system if it will work or not)
- FPS
- Current uptime
- Total uptime
- Enable movie library information (Total, Watched, Unwatched)
- Enable TV show library information (Total, Watched, Unwatched)
- Enable music library information (Artists, Albums, Songs)
Color | Opacity (Users can choose color and opacity for every element, along with random color and random opacity) - Implemented using script.skin.helper.colorpicker - Thanks Marcel!
- Choose hour color and opacity
- Random hour color
- Random hour opacity
- Choose colon color and opacity
- Random colon color
- Random colon opacity
- Choose minute color and opacity
- Random minute color
- Random minute opacity
- Choose AM/PM color and opacity
- Random AM/PM color
- Random AM/PM opacity
- Choose date color and opacity
- Random date color
- Random date opacity
- Choose additional information color and opacity
- Random additional information color
- Random additional information opacity
- Choose icon color and opacity
- Random icon color
- Random icon opacity
Background
- Choose text shadow color
- Chose background image aspect ratio
- Choose background (One color, Single image, Slideshow, Skin Helper, Dim)
- Choose background color
- Choose image
- Choose slideshow directory
- Random images (Screensaver chooses a random image from the folder for the background)
- Change background picture every
- Choose Skin Helper background (Movie random fanart, TV show random fanart, Music artist random fanart, Random fanart of all media types)
- Brightness level
Extra Options
- Element Size Increase (%) (Users can increase the size of text and icons)
- Log out
- Stop now playing media
- Log out after (minutes)
- Enable RSS (The screensaver will show the same RSS Kodi shows, so make sure it's properly configured and enabled in Kodi)
This screensaver is configured for every skin separately since it has to use Fonts defined by the skin!
If there is no appropriate xml file it will use skin.default.xml
List of supported skins (If the skin is in the official repository it will be supported):
- Ace2
- Adonic
- Aeon Nox 5
- Aeon Nox Silvo
- Aeon Tajo
- Aeon MQ5
- Aeon MQ5
- Aeon MQ6
- Aeon MQ8
- Amber
- AppTV
- Arctic: Zephyr
- Arctic: Zephyr 2
- Aura
- Bello 6
- Bello 7
- Black Glass Nova
- Box
- CarPc-Carbon
- Chroma
- Confluence
- Embuary-Leia
- Eminence.2
- Estouchy
- Estuary
- Ftv
- (Fuse)neue
- Grid
- Horizon
- Madnox
- Metropolis
- Mimic
- Nebula
- Omni
- OSMC
- Pellucid
- Phenomenal
- Quartz
- Rapier
- Retouched
- Reestuarized
- Revolve
- Titan
- Transparency
- Unity
- Xperience1080
If your skin is not on the list, and you would like it to be - send me a message.
Change log:
6.0.4
- Translations and a visual improvement for ftv skin - thanks Kevin!
6.0.3
- Bug fixes and translations​​​​​​​
6.0.2
- Got the script.skin.helper.backgrounds to work again with the screensaver
6.0.1
- Fixed a bug connected to weather icon and now playing icon
- Added support for several skins
6.0.0
- Updated the screensaver to work with Kodi 19 and Python 3
- Fixed settings quite a bit
- Added options:
- No padding for hours
- Dim for the background
- RSS
5.0.3
- Added support for Aeon Nox 5: SiLVO skin
5.0.2
- Added support for Adonic and (Fuse)neue skins
5.0.1
- Fixed the weather icon not updating bug
5.0.0
- Updated the screensaver to follow Krypton updates
4.0.3
- Better representation of CPU usage on multiple core systems
4.0.2
- Added background image aspect ratio control
- Added additional information:
- FPS
- Current uptime
- Total uptime
4.0.0
- Added log out option
- Added support for script.skin.helper.colorpicker (Thanks Marcel!)
- Rewritten color and transparency options, now users can pick their color instead of choosing one of the few predefined ones
- CPU usage
- Battery level
- Free memory
- Movie library info (Total, Watched, Unwatched)
- TV Show library info (Total, Watched, Unwatched)
- Music library info (Artists, Albums, Songs)
3.9.0
- Got the screensaver to transifex
- Fixed the zoom bug (when part of the information gets off the screen)
- Added custom date format
- Added Skin Helper background option
- Added colon blink option
3.8.0
- Repacked the options
- Added custom position option and showing of thumbnail for now playing media
- Fixed up a slideshow bug
3.7.0
- Fixed up the code a bit and added support for Skins Estouchy and Estuary
3.6.0
- Added more zoom values and removed unnecessary weather updating, added support for skin Eunique and KOver
3.5.0
- Added zoom effect for increasing text and icons
3.4.0
- Fixed some xml loading bugs
3.3.0
- Added fixed position
3.2.0
- Fixed the sorting bug for slideshow
3.1.0
- Added support for OSMC skin
3.0.0
- Added bounce effect for on screen movement
2.9.0
- Removed xbmc.sleep and added monitor.waitForAbort
2.8.0
- Changed the way screensaver deals with custom xml files
2.7.0
- Added support for text shadow color
2.6.0
- Added support for Chroma skin
2.5.0
- Added weather icon support (Thanks to Mario and the rest of the Titan skin crew)
2.4.0
- Added skin.custom for skin developers and skin.default for skins that are not directly supported
2.3.0
- Added weather information and reworked current options
2.2.0
- Added now playing info options
2.1.0
- Setting up the screensaver so it works with most of the skins
2.0.0
- Added random option for transparency
1.9.0
- Added random option for colors
1.8.0
- Added random option for slideshow
1.7.0
- Added slideshow
1.6.0
- Added transparency for date
1.5.0
- Added transparency for time
1.4.0
- Added date colors
1.3.0
- Added time colors
1.2.0
- Added date format
1.1.0
- Added time format
1.0.0
- Initial version
Possible issues:
Depending on your language and selected date format the date text might become ... that means that the text for the date is too long, I can fix that easily, just let me know if it happens. (Screenshot would be great including which language you are using and how many letters are supposed to be on the screen).
Everything else should work just fine, let me know if you encounter any bugs or issues.
We're on Transifex!
Feel free to translate screensaver.digitalclock to your language: https://www.transifex.com/teamxbmc/kodi-...italclock/
Download:
The source is available here: https://github.com/vdb86/screensaver.digitalclock
Cool! Nice work so far.
I didn't know how to install it so I just grabbed the source from Github, unzipped into .kodi\addons\screensaver.digitalclock, rebooted and it worked. Hope I did that correctly. ☺
Is there any way to:
1. Make the clock move smoothly around the screen instead of jumping from spot to spot.
2. Show what's playing in addition to the time if you happen to be playing music, a radio stream, etc.
Hi UberNewf, I'm glad you like it.
Yes that is the correct way, I haven't sent it to the Kodi official repository yet, I'm waiting for some skins to update and then it'll be easier to install - directly from Kodi.
1. I made it like that, but didn't like how it looked. To me it felt a bit "jerky" to be honest, I tested it on my laptop with Intel i5 CPU and on my Raspberry Pi 2.
I removed that feature since I wasn't satisfied with it.
To be able to make it feel more fluid I would have to increase CPU load and that was something I wanted to avoid.
2.That can be done, although as far as I know Kodi uses Dim screensaver when movies/tv shows are playing even if you selected some other screensaver.
I'm not sure what happens with music and radio.
Where should this text be?
For # 2 I was suggesting showing the name of the current track if you're playing music\radio (not TV\Movie). There is a setting under screen saver to play the selected SSaver instead of a visualization when in music, and I use that instead of viz's because I'm on a Pi2. So maybe under the date you could put the track\song title (and the image, if you want to get fancy).
Unfortunately since screensavers can't define their own fonts adding stuff is pretty complicated (on top of other stuff).
I'm not to keen on the image, but I'll take a look at the track\artist\song title and I'll let you know if I can do it.
How do you listen to the radio?
Hi UberNewf, I've updated the scrrensaver, now it shows whatever gets played in Kodi.
Give it a try and let me know what you think.
Download the zip again and replace all the files.
Hi vdb86, I'm in love with this screensaver. I was wondering:
- is it possible to have the clock stay in one position?
- increase the font size of the time?
- this may be asking too much - is it possible to show the weather/temp alongside with the time?
Many thanks for your amazing work!
Hi lady0421, glad you like it.
1) I made the clock move so it doesn't "burn in" into your screen, so there is no option to keep it in one place.
Any static image can literally screw up pixels on your monitor or tv, so after you change it you see a "ghost image" of the previous one.
2) At this point Kodi doesn't allow addons to use their own fonts, therefore I have to rely on skins to provide fonts and font sizes which I later use.
I had to setup the screensaver for every skin separately, and test it so it works as it should.
Until addons can define their own fonts there won't be an option to increase or decrease certain aspects of this screensaver.
3)It is possible, but I'll have to take a look and see how complicated it is to implement it.
It would probably use the same line as the now playing information, since I don't plan on adding any more lines of text
I'll let you know when I figure it out.
Any chance for a CTU 24 clock ? Smile
@lady0421
I've added the option for weather, it's not added to the official repository yet, but you can get it from the github and test it out.
@Jönke
What's a CTU 24 clock?
(2015-09-24, 20:15)vdb86 Wrote: [ -> ]@lady0421
You are a legend! It worked amazingly well. I love it, thank you!!
Small request - do you think you can draw the icon of the weather forecast, like, when it's sunny, it has the sunny - it looks a lot cuter with the icon! It's not that important, really, with or without it, I'm not changing my screensaver for a long long time!
(2015-09-27, 14:04)lady0421 Wrote: [ -> ]
Sorry lady0421, but this screensaver is text based (except for the image slideshow).
At the same time putting in graphics based on weather condition would be pretty complicated.
Glad you like it, enjoy Smile
Ok, got the idea now.
Add-ons can't define their own fonts, so that's the first no.
Second of all I don't like the idea of having seconds on the screen too, it feels too crowded.
Sorry Jönke
