Full Version: failed to install dependency/ URL Resolver
Hello every one,
As the title said both Problems i got them since days i tried to clean install and it is same .
On Android/windows.
any suggest or solution.
Thanks in Advance.
Sorry for My English !
(2015-09-01, 20:48)kasias Wrote: [ -> ]Hello every one,
On Android/windows.
Thanks in Advance.
Need more info pls. Modi version and add on name u get errors.
Kodi 15.1
last stable version
Errors on
Kodi 15.1 Fire Tv stick
kodi 15.1 Samsung s5 Android 5.0
Kodi 15.1 Win 10
kodi 15.1 win 8.1
i'm facing the same problem when i try to load something from zip file. any solution please.
there are many ADD-Ons, when i try to download most of them by ZIP file from my laptop(windows) got same issue of failed to install a dependency.
don't crosspost and spam your problem everywhere bajwa82mna
so i'll repeat again
this is for both of you
do the official add-ons install without any issues ?
if yes,
if the add-on has a support topic on this forum you could ask there for help.
if not then contact the developer of that add-on with your issue.
or where you got the add-on from.
looking add your debug log you got allot of add-ons running that we don't support here.
if the add-on is supported here and it gives issue you will need to start with a clean userdata without any unsupported add-ons running that could cause problems.
if you're using any of these banned add-ons (wiki) you need to look for help somewhere else.
(2015-09-02, 18:33)TRaSH Wrote: [ -> ]don't crosspost and spam your problem everywhere bajwa82mna
if yes,
Dear Friend Thanxs
But this Problem connected with URL Resolver just with 15.1 Kodi version.
If u have solution or smth good to say plz Speard it.
Have a Nice Day.
and i will try to contact with Developers.
On Android/windows.
Thanks in Advance.
Try reinstalling kodi 14.2 on windows and see if u get same errors.
(2015-09-04, 04:06)lordfire00 Wrote: [ -> ]
On Android/windows.
Thanks in Advance.
Still the Same!
(2015-09-06, 19:17)kasias Wrote: [ -> ]
On Android/windows.
Thanks in Advance.
Still the Same!
OK, now delete repo sources and reinstall them..if u don't want to do that, ur gonna have to submit a log file
