Full Version: How to change shell size
I was using kodibuntu on my NUC without any problem.
Then tonight I rebooted the NUC and suddendly there was no internet connection anymore.
So I can't ssh to the NUC nor control Kodi with the remote.
Then I tried to investigate the problem changing the shell with ctrl-alt-F1 and logging in, but there is some major problem: the shell is outside my tv screen on the left side, I can only read long commands, the first bunch of letters are out screen.
Is there some way I can resize the shell to fit my screen?
On a side note: if anyone has some ideas on why the connection stopped please point me in the right direction, thanks.
disable overscan on your TV
I'll try, thanks.
