Full Version: Kodibuntu - black screen after TV has been off for awhile. Hitting multiple dead ends
So I've hit an issue I can't seem to resolve on my own. I've been googling like mad but cant seem to get it licked. I'm also not very proficient in Linux, which isn't helping things.
Setup: Intel NUC DC3217BY runnng Kodibuntu 15.1
A/V Receiver: Onkyo TX-SR606
TV: Samsung UN60D8000
Issue: I leave the media center on 24/7, and turn off the receiver and tv when not in use. When turning back on after X amount of time (typically overnight), there is no picture displayed. The box is still running, as I can SSH in. It appears to be an HDMI handshake issue. Rebooting the box restores the picture.
Troubleshooting: I have attempted two different paths to resolution.
1) Stop the behavior outright. It appears the the problem is caused by the EDID being dropped. There should be a way to statically define the EDID to resolve the issue. The problem that I've ran into is that my box does not have an xorg.conf file to edit. Without xorg, I cant statically set the EDID, and I'm stuck.
2) Start turning the box off with the TV and receiver, that way when everything turns on theres a fresh round of HDMI handshakes going on. The problem here is that the box doesnt resume from standby from USB IR. It will resume from a keyboard though. It seems the USB IR receiver isnt receiving power when the machine is in standby, as I cannot see the light inside responding to any IR signals. Apparently to enable wake from usb ir you can enable the usb ports in /proc/acpi/wakeup. The problem I'm having here is that when I run the commands to enable the usb, they dont seem to take. IE, I run sudo sh -c 'echo "USB1" > /proc/acpi/wakeup' but then when i check it with cat /proc/acpi/wakeup it still shows the usb disabled.
Help!
(2015-09-02, 05:17)SickIcarus Wrote: [ -> ]So I've hit an issue I can't seem to resolve on my own. I've been googling like mad but cant seem to get it licked. I'm also not very proficient in Linux, which isn't helping things.
Help!
Use the forum search, please. Search for drm_kms_helper I have answered this ~5 times last month.
