(2015-09-21, 10:24)Karandras Wrote: [ -> ]Is it correct that Eminence 2.0 only use on Background per Movie? At the "old version" they use extra fanart. Change the Background at the movie selection etc ...
WOW! Your very fast! I like the Mediaflags. Looks nice! But all my movies are SD 480P ?
The Mediaflag for 3D works great. Now i see what movie 3D. And at some movies i see Blu-ray flag and some movies not?
Currently, yes. However, extrafanart option will come soon
Fixed the resolution flag - was a typo in the code
Blu-ray flag shows if the filename has either "bluray" "bdrip" "bd25" or "bd50" in the filename.
HD-DVD flag will show if file has "hddvd" in filename.
DVD flag will show if file only has "dvd" in file name.
Also added the option to hide the widget info on home.
(2015-09-21, 11:13)KarmaMole Wrote: [ -> ]Ah! With the new release, the 'extra info' overlay is no longer dimmed out Thanks!
Strange that what I did fixed that. It wasn't happening on any of my machines - I know what fixed it, but it shouldn't have been happening in the first place -- oh well, glad its working now!
(2015-09-21, 11:16)KarmaMole Wrote: [ -> ]If you could add something similar (or identical even) to the 'Wide' view in Arctic: Zephyr that would be really cool. It's great for episode views..
Yeah, I'm working on something. Hard to get something that fits stylistically.
(2015-09-21, 11:19)-FuFu- Wrote: [ -> ]And i love this skin only 1 thing i missed from the previous version of the skin is to set a background overlay, that appears over all background, i realy liked this option and hope it will be integrated in the new skin.
Also i notice a bug, if i set a custom tile background color like "ff666666" the tile on homescreen just went black but by hover the tile it gets the custom color.
Unfortunately, you can only use the included tile colours if you are using the show colour for unfocused tiles option. Once the skin is ready, I will write a tutorial showing how you can add additional custom colours for this purpose.
Ah, the background overlay. Forgot about that one. Will add an option in
(2015-09-21, 15:26)stueeey Wrote: [ -> ]thanks for making those changes @jurialmunkey... adding a few more requests if I may.
1. consider an option to set Home Menu Icons as 'none' - not for all just a particular item (menu button)
>> reason being - I've added a few Home Menu Shortcuts that have no possible icon to suit the shortcut/button... currently the only way I have worked around not setting an icon is to add my own blank icon to the >Media >Icons folder is there an easier way I have missed?
2. I cannot help but miss the widget multiple poster widget from AZ (10 posters at one time)... don't get me wrong I love the featured widget you have implemented, its a joy to view ! (love the graphic style)
3. with the new 'skin shortcuts script' in mind I wondered whether it is actually possible to apply 2 different styles of widgets to 1 home screen?
4. Reloadskin button
1. Maybe a solution would be for me to include a blank icon with the other icons at the top of the list?
BTW - you can add custom icons to skin.eminence.2/extras/icons/ to have them show up.
2. I'm working on an idea for this
3. Definitely possible to have different widget styles on a per tile basis.
4. You can add a reload skin button by setting a home tile with the custom action ReloadSkin()
(2015-09-21, 22:16)rudrood Wrote: [ -> ]@jurialmunkey
Like the new Eminence look. Since you still need to work on the livetv section can you create a view that looks something like the Photoshop version attached sample I was working on for Artic Zephir?
It looks like the listing of settopboxes like the Dreambox etc. Important is that it contains as mutch channels as possible and mutch room for the plot.
http://imgur.com/CwDQnzS
I have an idea along these lines. I will keep you posted. BTW Most of the livetv section is now completed (except for a few management dialogs in the settings)
