Arrgh, can't edit my post:
Edit: The same thing happened to me. GitHub's code -> download zip downloads v3.0.5, not v4.0.1 which is the matrix-alpha version.
Jurialmunkey
When I play movies, there is only the audio. The video don't display. There is difficulty to stop playing...
(2021-09-21, 11:25)chitridang Wrote: [ -> ]Jurialmunkey
Same issue here. It seems like a black overlay is being applied to the video for some reason.
(2021-09-22, 02:02)st0nedpenguin Wrote: [ -> ] (2021-09-21, 11:25)chitridang Wrote: [ -> ]Jurialmunkey
Ah yep I see the issue. For some reason there was a fullscreen texture overlay. No idea why it was there - only guess is that it was a leftover from ExtendedInfo window.
Should be fixed in v4.0.2
https://github.com/jurialmunkey/skin.emi...tag/v4.0.2
I'll try and fix up some other things over the weekend like TMDbHelper as replacement for ExtendedInfo
(2021-09-22, 09:53)jurialmunkey Wrote: [ -> ] (2021-09-22, 02:02)st0nedpenguin Wrote: [ -> ] (2021-09-21, 11:25)chitridang Wrote: [ -> ]Jurialmunkey
Thanks for the quick fix. Apparently I picked a good day to just randomly check for updates on here.
FYI - Moved development of Matrix version onto the Master branch (and Leia version has been moved to its own Leia branch for archive purposes). This will mean main zip download will now work - but I'll still push releases too for easy zip downloads from the releases section.
(2021-09-22, 11:12)jurialmunkey Wrote: [ -> ]FYI - Moved development of Matrix version onto the Master branch (and Leia version has been moved to its own Leia branch for archive purposes). This will mean main zip download will now work - but I'll still push releases too for easy zip downloads from the releases section.
Working perfectly now, although I haven't tried much. I didn't even realize how much I'd missed this skin until this update. Many thanks.
Jurialmunkey
In the list view, is it possible to have an option for bigger font size?
(2021-09-23, 04:48)chitridang Wrote: [ -> ]Jurialmunkey
Sorry, only focusing on fixing bugs and missing features for the time being. Not adding anything new at the moment.
If you want to change font sizes, you can edit the 16x9/Font.xml file.
(2021-09-23, 09:46)jurialmunkey Wrote: [ -> ] (2021-09-23, 04:48)chitridang Wrote: [ -> ]Jurialmunkey
I have found the Font.xml file. But I can't find the font name which is used for the list. Can you give me the name...
Can you keep an option in to use Extendinfo? It was just completely redone and uses TMDBH as players and looks fantastic..https://github.com/henryjfry/repository.thenewdiamond/tree/main/zips/script.extendedinfo
**Edit** Are you going to skin the TMDBH Info menu to look more like ExtendedInfo?? If so I guess it would be fine without Extendedinfo.
