Full Version: Kodi don't save Provider Whitelist
Hi Guys,
i have a little problem with Kodi and the pvr.vnsi addon.
I use kodi as frontend to a vdr backend. all works fine but if i create a provider whitelist in Kodi client specific settings, that list don't store after restarts kodi or restarts vdr. I think kodi reloads the channels from backend and reset all lists.
What can i do to fix that problem.
Martin
hi,
i think i found the solution in src of vnsiserver.
the codi vnsiclient save the lists over a vnsiserver api. That store the lists in the plugindir of vnsiserver of vdr in a file with the name videowhitelist.vnsi.
I think vdr works with a user vdr but the user vdr has no read or write access to the directory. The serverplugin don't log that problems if they can't read or write that file.
I will test that at home today.
Martin
(2015-09-03, 14:04)oimel Wrote: [ -> ]The serverplugin don't log that problems if they can't read or write that file.
good point. I will add some logging next time I touch this. thanks
after set right permissions all works well.
