2018-05-04, 16:23
2018-06-19, 01:13
This is what I did to build for Fedora 28
your rpms will spit out in the ~/rpmbuild/RPMS folder
wget http://download1.rpmfusion.org/free/fedo...28.src.rpm
sudo dnf install rpm-build -y
rpm -i kodi-17.6-9.fc28.src.rpm
cd ~/rpmbuild/SPECS
sudo dnf builddep kodi.spec -y
cd ~/rpmbuild/SOURCES
wget -O kodi-libdvdnav-master.tar.gz https://github.com/xbmc/libdvdnav/archive/master.tar.gz
wget -O kodi-libdvdread-master.tar.gz https://github.com/xbmc/libdvdread/archi...ter.tar.gz
wget -O kodi-libdvdcss-master.tar.gz https://github.com/xbmc/libdvdcss/archive/master.tar.gz
cd ~/rpmbuild/SPECS
rpmbuild -bb kodi.spec --with dvd
2018-07-08, 21:55
Thanks grim85.
I've now got kodi 17.6 running on Fedora 28 according to your instructions.
But there's a problem, DVD playback doesn't work. Bluray playback works fine though.
When I try to start the playback of a DVD film I get following in the logs
https://paste.ubuntu.com/p/tGQn3kYzTk/
2018-08-30, 23:14
For anyone else that is using Fedora 28 and the rpmfusion Kodi packages (17.6.9 at time of writing) If you use the default Wayland compositor for your display then you may see some issues with Kodi. The menu's and OSD were 'jittery' and it appeared that my remote (mce_usb) wasn't quite working correctly. The video playback seemed fine but if you had subtitles then they would suffer the same issue as the OSD. The remote seemed to be slow to respond and sometimes in menus it would jump around as if the keys had been pressed multiple times. I switched to X.org instead and all the issues disappeared.
For reference I am using an AMD RadeOn HD6450 for graphics.
If you follow the guide https://kodi.wiki/view/HOW-TO:Install_Ko...n_packages then you should be fine as it doesn't recommend using the default Wayland...
2020-09-17, 06:25
(2017-01-10, 19:53)wirerydr Wrote: [ -> ]The Kodi installation RPMs as built by RPMFusion do not, for various reasons, include DVD playback capability (including TS_VIDEO folders).Is there an updated page with the instructions, by any chance? The above link brings up a page that says it contains no text.
For those desiring DVD playback capability, the HOW-TO:Install Kodi on Fedora 25 using RPMFusion packages wiki has been updated to include a new section showing how to rebuild Kodi from the RPMFusion Source RPM with DVD Playback capability enabled. It is a little more involved, but still relatively straightforward.
Feedback is appreciated.
Cheers - WireRydr
2020-09-17, 06:43
(2020-09-17, 06:25)SilkBC Wrote: [ -> ]The above link brings up a page that says it contains no text.All redirects (which is what that link was) were deleted. The actual page has been archived but can be found here... https://kodi.wiki/view/Archive:Install_K...n_packages
