Full Version: Need help with adding Movies.
Hello!
I recently installed Kodi and Mimic, but I can´t seem to add sources for my movies/TV-shows. In the standard skin I can simply add the files (file sources) directly from the "Video" menu, but in the Mimic skin I can´t find where to do this. Can you help me?
One way is instead of entering TV Shows go to Videos > Files > Add Videos..
After selecting a folder you will be able to set its content as usual.
There it is! Works perfectly! Thank you for the quick reply, much appreciated! Smile
